Friday,19,July,2019,15:23:39:17347
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZAUZFW153245 License Plate: XXXXEJO
Mileage: 125791km-78162mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 47 52 55 5F
A9
VIN: WVWZZZAUZFW153245 Mileage: 125791km-78162miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EQ HW: 04L 907 309 A
Component: R4 2,0L EDC H22 7540
Revision: 81H22---
Coding: 011D0012036505083000
ASAM Dataset: EV_ECM20TDI01104L906021EQ 002008
ROD: EV_ECM20TDI01104L906021ER.rod
VCID: 78F8497EC390888FA1-802C
18111 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [096] - Pump Current Open Circuit
Mileage: 122366 km
Date: 2019.04.30
Time: 09:44:24
Engine speed: 3394.50 /min
Normed load value: 99.6 %
Vehicle speed: 79 km/h
Coolant temperature: 90 °C
Intake air temperature: 115 °C
Voltage terminal 30: 13.760 V
Unlearning counter according OBD: 27
Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 14
Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 6
O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
Oxygen sensor bank 1 before oxi cat: heater activation: 90.128 %
O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.4829 V
Oxygen sensor bank 1 before oxi cat: adjustable resistor: 74.1 Ohm
Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0000
Part No SW: 0D9 300 041 Q HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4504
Revision: 05853104 Serial number: TFK01410060431
ROD: EV_TCMDQ250021.rod
VCID: 2644570659A4CE7FC3-8072
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 62874000000185
Coding: 01FA8AA13425096F0379060441C82980512C90C0608294F5F8625078C209
VCID: 4684F786F9E42E7FE3-8012
Revision: 00021000 Serial number: 0349298287
Coding: 030C0C
VCID: 3A7C9376BD1C5A9F97-806E
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00120114202400011005000200101000
VCID: 73E27E52DAF6EBD794-8026
Air quality sensor:
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011428902739
Coding: 03111B66C20122FB0B244080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 0008219E9B40C04F99-8054
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 141010 042 0551
Serial number: 141013164524
Component: RLHS 037 0059
Serial number: S4Y14M10D23H15M38S35
Coding: 00A8EE
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1426125LA
Serial number: 00000000000060660992
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST00007HRF00000
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331428209346
Coding: 0071051011
VCID: 3D76986AAC326DA7B2-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 16101403272545
Coding: 001C1300FE0739
VCID: 3878897E8310488F61-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR09LPHG
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F0AA262E6BEBFB7E0-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169661C06101440307
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169662C02101470074
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 810 14
Serial number: 357670000008B420311F
Subsystem 4 - Part No SW: ----------- HW: 480 001 810 14
Serial number: 3586700000085781311K
Subsystem 5 - Part No SW: ----------- HW: 480 400 910 14
Serial number: 3516502A1175A9258251
Subsystem 6 - Part No SW: ----------- HW: 480 400 910 14
Serial number: 3526502C5175A9055231
Subsystem 7 - Part No SW: ----------- HW: 480 401 610 14
Serial number: 3556502AB18166B231EE
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 16101404220629
Coding: 0C10
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 7BF25672F2A6A397CC-802E
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Part No SW: 5G1 920 957 HW: 5G1 920 957
Component: KOMBI 301 4270
Coding: 27AD01182F80260001886A011400000000000000
VCID: 6DD6682ABCD23D2742-8038
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002605074
Coding: 030100040B087300EF00027E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 428CEB96D5CC125FCF-8016
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 29140002220950014414
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4522884703
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02028867727261565623393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B52A6324246F3171C-807E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000285865004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3460BD4E9F78ACEF4D-8060
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 26091402090200
Coding: 003F1220D001048100001000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 3566804A9402B5E77A-8060
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0060
Serial number: VWZ8Z1EC401SPW0
Coding: 120000008AAA8A0000
ASAM Dataset: EV_AMPMst12C1ALPI 001005
ROD: EV_AMPMst12C1ALPI.rod
VCID: 63C20E126A167B57E4-8036
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 06101401101769
Coding: 003F1020DE01048100801000
VCID: 418EE49AD0CA0947D6-8014
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029E01000B010200
VCID: 4088E19EDBC0004FD9-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 035 020 D HW: 5G0 035 020 D
Component: MU-H-ND-EU H43 0407
Serial number: A310J0EB006645
Coding: 027300010000000011111202000800031F0202F60100010057
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1A3C73F61DDC7A9F77-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H61 0030
Serial number: VWZ8Z9PS100WKE
Subsystem 2 - Part No SW: V03 959 806 ET HW: -----------
Component: ECE 2019 --- 0175
Compact Disc Database:
Component: Gracenote --- 1010
B2000 87 [009] - Missing message
Reset counter: 71
Mileage: 125791 km
Date: 2019.07.19
Time: 15:17:06
Voltage terminal 30: 12.4 V
Software module: status-SW_Status_Consistency: 00 20 00
Software module: status-SW_Status_DevName: Dab
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 140909200868
VCID: 6BD2663282C633175C-803E
End-------------------------(Elapsed Time: 04:53)--------------------------
