ABS Bosch 8.0 Seat ibiza 6L
Fuji-Specs
GR
Hi, I don't own a VCDS but I am thinking of buying one since I own a auto repair shop and I have a tough case now. A seat Ibiza 6L came in and needs an ABS replacement, it has the bosch 8.0 . So I want to ask can I copy the coding of this ABS unit to a new one with a VCDS so the new ABS be ok when installed on car? and if yes can someone give me a How-to? or video? or a detailed write-up of how i can do this procedure?(I am sorry if am asking a lot but since I don't usually work on group VAG I don't have this knowledge)
Thanks in advance
Assuming the old ABS "talks" and still has its original coding, copying that coding should be straightforward.
What model year is this car?
Fuji-Specs
GR
its 2005 also the abs can "talk" and I assume it has the original coding...
Fuji-Specs
GR
What about the how to instructions? do I need to be a verified member for someone to tell me?
thanks in advance
No, you don't need to be a verified member, but you do need to post an Auto-Scan to show you're using a legitimate VCDS system. :)
Fuji-Specs
GR
oh ok, I will post an auto-scan when I get one from the car and since you are saying the VCDS can copy the coding I will also buy a subscription
