08 S4 Avant and we are removing the auto for a 6 speed manual.
The current ECU won't accept the coding from auto to 6 gang.
Will a 08 Manual ECU file example 8E2 910 560C flash into the current ECU 8E2 910 560 G ? I'm told the C version could be tweaked to load into G box, However some auto boxes brick when putting manual files in.
The car starts and in the steering wheel module I was able to turn off the Tip paddles. Cluster shows the push in clutch pedal to start message. The auto scan shows that it's still looking for the TCU.
Does the ABS module need a recoding as well? What about the Instrument cluster coding?
Or does the manual ECU file sort all of this?
First time swap on the B7, thank you for the help.
67 69 75 76 77
VIN: WAUUL78E68A109454 Mileage: 105080km-65293miles
Address 01: Engine ( ) Labels: 079-910-560-BBK.lbl
Part No SW: 8E2 910 560 G HW: 8E2 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0007771
Shop #: WSC 06335 000 00000
VCID: 2B16F76C8A41551258-807E
005670 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU - MIL ON
Fault Status: 11101000
Mileage: 105084 km
Load: 0.0 %
Temperature: 26.0°C
Temperature: 28.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004902
VCID: 2E10FE78B953203A7F-807A
Reset counter: 40
Hex Value: 0x0040
Hex Value: 0x4002
Hex Value: 0x0013
Hex Value: 0x4494
Hex Value: 0x0001
Fault Frequency: 7
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
VCID: 6D92397425D59B2206-5118
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 11023
Shop #: WSC 65536
VCID: 3D32C9343535CBA2F6-4AA4
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 M HW: 8E0 959 655 M
Component: Airbag 9.41 H01 4240
Revision: 91H01424 Serial number: 003CS0000SK5
Coding: 0032607
VCID: 41CAB5C418CDAF4292-8014
Subsystem 1 - Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Subsystem 2 - Serial number: 01H57
Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 6332DRB4063451158ÿ† 63
Subsystem 5 - Serial number: 451158ÿ† 6342DRB4063C879F1ÿ† 63
Subsystem 6 - Serial number: C879F1ÿ† 6352ARB402F87A6D0ÿ† 63
Subsystem 7 - Serial number: 87A6D0ÿ† 6362ARB402F92D65Zÿ† 63
Subsystem 8 - Serial number: 92D65Zÿ† 63729RB402B966AA.ÿ† 63
Subsystem 9 - Serial number: 966AA.ÿ† 63829RB402B96717Rÿ
Subsystem 10 - Serial number: 96717Rÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 04042
Shop #: WSC 06335
VCID: 41CAB5C449CDAF4292-4AA4
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 D HW: 8E0 920 983 D
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0023268
Shop #: WSC 04310 758 67144
VCID: 302CE000A26736CA6D-5118
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023268
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71AA25043AED7FC222-4B3C
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CP
Component: Komfortgerát T7B 4336
Coding: 12076
Shop #: WSC 06335
VCID: 014A75C4094D6F42D2-4AA4
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 291A0D6480BD4702AA-807C
Component: AFS-Modul links H05 0030
Component: AFS-Modul rechtsH05 0030
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0063022
Shop #: WSC 06435 000 00000
VCID: 2A18F26887BB4C1AA3-5160
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005056613
Coding: 0011877
VCID: 45C2A1D40DE58362AE-50D0
End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
