08 S4 Avant Auto to manual module recoding help needed
wld101turkey
C?ID=29866
08 S4 Avant and we are removing the auto for a 6 speed manual.
The current ECU won't accept the coding from auto to 6 gang.
Will a 08 Manual ECU file example 8E2 910 560C flash into the current ECU 8E2 910 560 G ? I'm told the C version could be tweaked to load into G box, However some auto boxes brick when putting manual files in.
The car starts and in the steering wheel module I was able to turn off the Tip paddles. Cluster shows the push in clutch pedal to start message. The auto scan shows that it's still looking for the TCU.
Does the ABS module need a recoding as well? What about the Instrument cluster coding?
Or does the manual ECU file sort all of this?
First time swap on the B7, thank you for the help.
          67 69 75 76 77
VIN: WAUUL78E68A109454   Mileage: 105080km-65293miles
Address 01: Engine (   )       Labels: 079-910-560-BBK.lbl
   Part No SW: 8E2 910 560 G    HW: 8E2 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number: XXXXXXXXXXXXXX
   Coding: 0007771
   Shop #: WSC 06335 000 00000
   VCID: 2B16F76C8A41551258-807E
005670 - Powertrain Data Bus
               P1626 - 008 - Missing Message from TCU - MIL ON
                    Fault Status: 11101000
                    Mileage: 105084 km
                    Temperature: 26.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
Readiness: 0110 1101
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004902
   VCID: 2E10FE78B953203A7F-807A
                    Hex Value: 0x0040
                    Hex Value: 0x4002
                    Hex Value: 0x0013
                    Hex Value: 0x4494
                    Hex Value: 0x0001
            000 -  -  - Intermittent
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x0196
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6D92397425D59B2206-5118
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 11023
   Shop #: WSC 65536
   VCID: 3D32C9343535CBA2F6-4AA4
   Part No SW: 8E0 959 655 M    HW: 8E0 959 655 M
   Component:    Airbag 9.41  H01 4240
   Revision: 91H01424    Serial number: 003CS0000SK5
   Coding: 0032607
   VCID: 41CAB5C418CDAF4292-8014
   Subsystem 1 - Part No: 8E0 910 339 D
   Component: BF-Gewichtsens. H03 0080
   Subsystem 2 - Serial number: 01H57
   Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 6332DRB4063451158ÿ† 63
   Subsystem 5 - Serial number: 451158ÿ† 6342DRB4063C879F1ÿ† 63
   Subsystem 6 - Serial number: C879F1ÿ† 6352ARB402F87A6D0ÿ† 63
   Subsystem 7 - Serial number: 87A6D0ÿ† 6362ARB402F92D65Zÿ† 63
   Subsystem 8 - Serial number: 92D65Zÿ† 63729RB402B966AA.ÿ† 63
   Subsystem 9 - Serial number: 966AA.ÿ† 63829RB402B96717Rÿ
   Subsystem 10 - Serial number: 96717Rÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 04042
   Shop #: WSC 06335
   VCID: 41CAB5C449CDAF4292-4AA4
   Part No SW: 8E0 920 983 D    HW: 8E0 920 983 D
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0023268
   Shop #: WSC 04310 758 67144
   VCID: 302CE000A26736CA6D-5118
   Coding: 0023268
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71AA25043AED7FC222-4B3C
   Part No: 8E0 959 433 CP
   Component: Komfortgerát T7B    4336
   Coding: 12076
   Shop #: WSC 06335
   VCID: 014A75C4094D6F42D2-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 291A0D6480BD4702AA-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0063022
   Shop #: WSC 06435 000 00000
   VCID: 2A18F26887BB4C1AA3-5160
   Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005056613
   Coding: 0011877
   VCID: 45C2A1D40DE58362AE-50D0
End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
DrPeter
16.4905° S, 151.7375° W
The ECM [8E2 910 560 G] is for vehicles with Automatic transmissions only and will not accept the coding for the manual transmission.
Based on some research, the ECM [8E2 910 560 F] or [8E2 910 560 FX] should be the one you need. Please check with the manufacture's parts department to verify this information.
I believe the [8E2 910 560 C(X)] is for a 2007 and was dropped and replaced by the [8E2 910 560 F(X)]
Info based on engine code 'BHF' and PR-Code [7GA]
ABS coding should be changed to [0004901] (manual trans)
In the Instrument cluster, you will need to remove [00002] from the value stored in Adaptation channel [060] - CAN-Databus Powertrain (Installation List)
Then clear codes and see what comes back, post a new Auto-Scan if needed.
Hope this helps,
drpeter
