Adaptation Problem in 8E central electronics -09 with HEX V2 adapter
Egon
Sweden
C?ID=193181
Hey guys!
With my HEX V2 unlimited adapter i'm unable to change any adaptation values in central electronics and the security access block is grayed out,
with my friends AI adapter i'm able to access the security access block and change adaptation values on the same car with the same computer and vcds program!
please tell me what the problem is!
(Audi rs4 b7 8ec -2006)
Egon
Sweden
C?ID=193181
Wednesday,26,June,2019,14:58:27:20561
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WUAZZZ8E06N900140   License Plate:
          67 69 75 76 77
VIN: WUAZZZ8E06N900140   Mileage: 222020km-137956miles
Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560     HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ª0080
   Revision: --H03---    Serial number: XXXXXXXXXXXXXX
   Coding: 01040003180F0160
   Shop #: WSC 00000 000 02400
   VCID: 6393AE3B0750BD0FB77-8036
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure - Intermittent
                    Mileage: 221821 km
                    RPM: 964 /min
                    Load: 52.5 %
                    Speed: 7.0 km/h
                    Temperature: 42.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.335 V
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H04 0150
   Coding: 0004533
   Shop #: WSC 06325 000 00000
   VCID: 2B03061B2F00354F4F7-807E
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00001
   Shop #: WSC 06325
   VCID: 6D87C803D484FB7F113-50D0
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 01041
   Shop #: WSC 00012
   VCID: 3B23365BDA70A5CFDF7-4AA4
            30-00 - Open or Short to Plus
Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M007J2L.
   Coding: 0430712
   VCID: 3B23365BDF60A5CFDF7-806E
   Subsystem 1 - Serial number: 6332DRB402004993A
   Subsystem 2 - Serial number: 6342DRB4021E0C8DY
   Subsystem 3 - Serial number: 6352ARB400984CAC.
   Subsystem 4 - Serial number: 6362ARB400984190E
   Subsystem 5 - Serial number: 63729RB400B1452DJ
   Subsystem 6 - Serial number: 63829RB400B14359H
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenksáulenmodul     0201
   Coding: 14441
   Shop #: WSC 36256
   VCID: 44D14DA7A78EDA37AED-4AA4
01301 - Control Module for Voice Recognition (J507)
   Part No SW: 8E0 920 931 G    HW: 8E0 920 931 G
   Component: KOMBI+WFS 4     H12 0030
   Revision: 0030        Serial number: 00000000000000
   Coding: 0023101
   Shop #: WSC 80093 222 69422
   VCID: 2C0105072A1E327746D-50F4
   Coding: 0023101
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760 A
   Component: Sitzverstellung H01 0020
   Coding: 00001
   VCID: 323D1B7F0D0A64870C1-4B1E
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6B83C61BEA90F54F0F7-508A
   Part No: 8E0 959 433 CA
   Component: Komfortgerát T3B    3332
   Coding: 27224
   Shop #: WSC 06325
   VCID: 72BDDB7FCDBA2487CC1-4AA4
   Component: Tõrsteuer.FS BRM 0406
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0506
   Component: Tõrsteuer.HR BRM 0506
01134 - Alarm Horn (H12)
            49-00 - No Communications
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000019
   Shop #: WSC 40951 222 94900
   VCID: 2615F72F34E20827909-8072
   Component: AFS-Modul links H05 0030
   Component: AFS-Modul rechtsH05 0030
   Part No SW: 8E0 035 193 A    HW: 8E0 035 193 A
   Component: RNS-E PU EU SP  H06 0700
   Revision: 0000001S    Serial number: AUZBZ7N2900524
   Coding: 0301718
   VCID: 2313EE3B47F0FD0FF77-50D0
00878 - Connection to Speaker Front Left
                    Fault Status: 01101011
                    Reset counter: 87
                    Date: 2019.06.13
                    Time: 23:18:08
00879 - Connection to Speaker Front Right
                    Reset counter: 87
                    Date: 2019.06.13
                    Time: 23:18:08
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273     HW: 8E0 907 273
   Component: Reifendruck 3   H03 0110
   Coding: 0022523
   Shop #: WSC 40160 222 89032
   VCID: 698FBC13E55CE75F7DB-513C
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
                    Fault Status: 11100100
                    Reset counter: 40
                    (no units): 0.0
                    Voltage: 12.10 V
                    (no units): 130.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Resistance: 0.00 ohms
   Part No SW: 8P0 862 335 C    HW: 8P0 862 335 C
   Component: FSE_255x BT     H18 0160
   Revision: 00000001    Serial number: 00000000300895
   Coding: 0010822
   Shop #: WSC 67458 141 87521
   VCID: 3635276FE45278A7209-50D0
End----(Elapsed Time: 04:40, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
there you go
Hey guys!
The CECM at address 09 in this car uses the older KW-1281 protocol which does not support the Security Access function.
I do not see how that is possible. Please post screen shots.
Egon
Sweden
C?ID=193181
My friend is in greece right now so i will borrow his adapter again when he gets back
Egon
Sweden
C?ID=193181
how do i post pictures so i can show you screen shots?
Egon
Sweden
C?ID=193181
this is with the HEX adapter:
Egon
Sweden
C?ID=193181
this is with the AI adapter:
- channel 16, the only channel i still couldn't change, and the one i really really wanted to change right now!!
if the older, cheaper AI adapter can access more controllers and change more adaptation values than the HEX adapter in the car i'm going to use it in the most then i want to change mine right now..
_Val
Latvia
C?ID=356659
Does hex-net has latest firmware installed and can you test it again with 19.6.1 for equal comparison?
Didn't really see SA button in last screenshots :D
Egon
Sweden
C?ID=193181
yes i saw it now that i couldn't access the security access block in central electronics with the AI adapter either, but i was able to change the adaptation values and thats really the important thing for me.
with the HEX adapter and updating from 19.6.0 to 19.6.1 and updating adapter firmware to CB 0.4508 got worse for me!
this is the only channel i could change adaptation values in with the HEX adapter before the update:
this is the same channel after the update with the HEX:
What kind of computer is this?
What's up with: "This copy of Windows is not genuine"?
Unfortunately it's s 4th of July week both guys who need to look at this are on vacation.
Egon
Sweden
C?ID=193181
I don't really see how thats relevant at all when the AI adapter still kicks the HEX adapters ass on the exact same computer?!
but it's a laptop with windows 7, it's just not a genuin, licensed copy of the windows version but it makes no differens.
Okey then we just wait untill they come back and hope they have some answers for me
I've edited to the thread topic to reflect the actual problem you are experiencing rather than the non-problem of Security Access.
Egon
Sweden
C?ID=193181
Thank you very much
Egon
Sweden
C?ID=193181
How's it going with the support?
Did they have any answers for me?
Moving this to VCDS Support.
Mari
C?ID=150535
Maybe I'm stupid, bit in the second picture in post #11 you haven't selected "Assistance Light Sensor Correction"... reason that channel 21 isn't showing it's current value is likely because you haven't clicked on the "READ"-button. Most likely you need to select something to change something :D
I'm waiting for my new Hex-NET to arrive, so will give it a go as soon as I have it! :popcorn:
Egon
Sweden
C?ID=193181
Don't you think i've clicked the read button?
Mari
C?ID=150535
Don't know what you do or how you do things... Using a non genuine version of Windows isn't that smart either ;)
Try by selecting the item you want to change from the pull-down menu instead of changing channel-number(s)...
