CLB label files
VASTech
Zalau, SJ, RO
C?ID=345137
Hi
Is there some trick seeing the CLB label files descriptions?
I`m missing something here?
Please let me know how can I see that bytes description, because it is not the first time when I see that popup but the label file is CLB not LBL.
Thank`s!
Saturday,08,June,2019,10:21:50:52276
VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
Dealer/Shop Name: VASTech Auto Diagnostics
Workshop Code: 444 03743 000001
VIN: WVGZZZ1TZ5W008514   License Plate:
Mileage: 234400km-145649mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W008514   Mileage: 234400km-145649miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 EH    HW: 028 101 145 0
   Component: R4 2,0L EDC G000SG  5687
   Revision: 12345678    Serial number: VWZ7Z0D9972339
   Coding: 0000072
   Shop #: WSC 10133 133 12345
   VCID: ED92B1EFF45D4A27CA-80B8
18104 - Powertrain Data Bus
            P1696 - 000 - Implausible Message from Steering Column Controller
                    RPM: 798 /min
                    Torque: 36.0 Nm
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 1 1 1
   Part No: 1K0 907 379 D
   Coding: 0056006
   Shop #: WSC 10133 133 45725
   VCID: B3266797D2F9DCD7DC-80E6
   Part No: 1T0 907 044 S
   Component: ClimatronicPQ35 040 0202
   VCID: C0CC385B934F774F51-8094
   Part No SW: 1K0 937 049 G    HW: 1K0 937 049 G*
   Component: PQ35 BordnetzSG 1.0 0302
   Revision: 12345678    Serial number: 00000000027418
   Coding: 01898F000004100000120C000000000000
   Subsystem 1 - Part No: 1T0 955 119 A  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0101
   Coding: 16711700
   Part No SW: 1T0 909 605     HW: 1T0 909 605
   Component: 04 AIRBAG VW62 0102 2112
   Coding: 0012340
   Shop #: WSC 01324 785 00200
   VCID: F2A8A293ED6395DF17-80A6
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 007 0030
   Coding: 0000042
   Shop #: WSC 03743 444 00001
   VCID: B02C689B23EFE7CFA1-80E4
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No: 1T0 920 860 A
   Component: KOMBIINSTRUMENT VDD 1312
   Coding: 0007101
   Shop #: WSC 11111 111 11111
   VCID: AF2E6BE73ED1F837B8-80FA
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 A
   Component: Zuheizer            0506
   Revision:        B    Serial number: 09006207
   Coding: 0000011
   VCID: A30697D762194C572C-80F6
   Part No SW: 1K0 907 530 A    HW: 1K0 907 951
   Component: Gateway         H06 0020
   Revision: 06          Serial number: 00000133042D29
   Coding: 3D3F1340078002
   VCID: A50289CF6C2DB26742-80F0
   Component: IMMO                1312
   Shop #: WSC 06402 785 00200
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 B
   Component: Tuersteuergeraet 08 1915
   Coding: 0000116
   VCID: AD1271EF34DD8A278A-80F8
Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
   Part No: 1K1 909 143 K
   Component: EPS_ZFLS Kl.0       0308
   VCID: B22862932DE3D5DFD7-80E6
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0545
   Coding: 00E802087F2D8404084F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 B
   Coding: 0000116
   VCID: AE1076E339DBF13FB3-80FA
   Part No: 1K0 035 186 D
   Component: Radio BNO           0218
   Coding: 0020400
   VCID: A71E83C71621A07770-80F2
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 04 0014
   Coding: 0000048
            014 - Defective
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Component: Tuersteuergeraet 05 0107
   Coding: 0000048
   Shop #: WSC 67814 141 02114
End----------(Elapsed Time: 01:08, VBatt start/end: 14.1V/14.0V)-----------
Hmm.. The "See Label file" thing is kinda silly in a .CLB. :facepalm:
If you could see it, this is what you would see:
006,2,Pedal Monitoring,,See Label File
; xxxxxxx1 = Brake Light Switch operated
; xxxxxx1x = Brake Pedal Switch operated
; xxxxx1xx = Clutch Pedal Switch operated
; xxxx1xxx = CCS enabled
; xxx1xxxx = ACC enabled
; xx1xxxxx = Main Switch
; 00xxxxxx = ACC/CCS Mode not active
; 10xxxxxx = Status override
; 01xxxxxx = ACC/GRA active
; 11xxxxxx = ACC blocked
006,4,Switch Monitoring,,See Label File
; xxxxxxx? = Stuck ON
; xxxxxx?x = Pressed OFF
; xxxxx?xx = Decelerate (-)
; xxxx?xxx = Accelerate (+)
; xxx?xxxx = Set (SET)
; xx?xxxxx = Resume (RESET)
; ?xxxxxxx = Stuck ON (Hardware)
_Val
Latvia
C?ID=356659
Was checking Level control on A8 D3 measuring blocks and 4E0-910-553.clb shows on screen to see label file. 015, 024-028
024.1 - actually it was LEBEL file with an error.
As I understand, I need to open this file from older vcds version as it got cbl'ed in summer of 2018 and it lost comment lines afterwards.
tultalk
So what is the point? Why are there some clb and no corresponding lbl files containing info?
I'm not sure I understand what you are asking.
