A4 20TFSI QUATRO 2010 OVER FUELING
audivwauto1
South Africa
C?ID=260881
Hi Guys Audi A4 20tfsi Q CDN came in over fueling badly only 105000km on the clock.
only fault was mixture to rich,we replaced new injectors from agents,and decated the exhaust still no luck
cold its ok then as she warms up starts puffing out black smoke until she cuts out and plugs are wet with fuel.
any suggestions ?
audivwauto1
South Africa
C?ID=260881
Monday,20,May,2019,10:50:42:16946
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: AUDI VW AUTO CLINIC
Workshop Code: 996 02232 000010
VIN: WAUZZZ8K6CA097093   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8K6CA097093   Mileage: 105510km-65560miles
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0009
   Revision: E1H20---
   Coding: 0104000C240F0160
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115P A01011
   ROD: EV_ECM20AVS.rod
   VCID: 3C34D153B72995AAC1-8068
Readiness: 1110 0101
   Part No SW: 8K1 927 156 G    HW: 0B5 927 156 F
   Component: 0B5 20TFSIRdW H10 0009
   Revision: --H10---    Serial number: 0000000645
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 393AC847B81BA082DA-806C
   Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
   Component: ESP8 quattro  H04 0020
   Coding: 090500
   VCID: 7F4EE65FEEBF4EB2A4-802A
   Part No SW: 8K0 907 064 CC    HW: 8K0 907 064 CC
   Component: BCM2 2.0      H05 0435
   Coding: 011100
   VCID: 73A63A6FD2F71AD2D0-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0811000184858007
   Serial number: 2311000239308006
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Revision: D0000000    Serial number: 01141120110232
   Coding: 64040000
   VCID: 76A0037BC1850FFAF7-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H30 0392
   Revision: 09030001    Serial number: 00000001123954
   Coding: 2600D0914034AF010001000000001D0D0F1D430802010141000000
   VCID: 3A38D74BB51DAB9AD3-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 061111  H06 0070
   Serial number: SWF11110065132
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11773079
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002810111272
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD0HDJL+
   Coding: 30533435363030303030554A3052384B3053
   VCID: 46C0B3BBF9E5DF7AA7-8012
   Serial number: 6334MSME671239359
   Serial number: 6344MSME65524F7CU
   Serial number: 6352QSME38643358H
   Serial number: 6362QSME38643D7AW
   Serial number: 63732SME40631270M
   Serial number: 63832SME40630E44Z
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KK9001AN
   Coding: 000036
   VCID: 3D32DC57A4339CA2F6-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
   Component: KOMBIINSTR.   H31 0258
   Revision: 00000000    Serial number: EJ84214CC
   Coding: 2F06090002000008010000
   VCID: 373ECE7F860FB6F22C-8062
   Part No SW: 8T0 907 468 AF    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0120
   Revision: GB901054    Serial number: 5400G11B0281CE
   Coding: 00C303
   VCID: 054274B78C631462EE-8050
   Component: J367-BDMHella  H03 8040
   Serial number: 5118785801
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C02204001410001
   VCID: 53E69AEF32B77AD230-8006
   Revision: 00002001    Serial number: 0163286618
   Coding: 011E062200B904008130013280000000
   Shop #: WSC 03163 996 87872
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010102
   VCID: 74A43973D7F91DEAC9-8020
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52E89FEB0DAD73DA3B-8006
   Revision: 00000003    Serial number: 20000000145102
   VCID: 3424F97397795DEA09-8060
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 111109-0002-034
   Coding: 1171A41010000200
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D12EC177C530C2246-8078
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H06 0350
   Revision: 00000011    Serial number: AUZ5Z6K1669305
   Coding: 0502008201018D000359070000
   VCID: 45C2B4B7CCE3D462AE-8010
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C02204001210001
   VCID: 56E063FB21456FFAD7-8002
   Component: TSG HR        H06 1501
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005447011
   Coding: 0010390
   VCID: 3D32DC5764339CA2F6-8068
End----------(Elapsed Time: 01:30, VBatt start/end: 12.7V/12.7V)-----------
audivwauto1
South Africa
C?ID=260881
first fault found
bank 1,system too rich at idle
P2188/00(101)
fault status 0000001
fault priority 2
fault frequency 2
engine speed 813.00/min
normal load value 12.9%
coolest temp 97deg
intake temp 39 deg
ambient air pressue 1010mbar
voltage terminal 30 14.065v
Scratching head. My first reaction was that the ECU might not be seeing the engine warming up (temperature sensor problem), but that seems to be shot down by the freeze-frame data of 97deg.
I would check fuel pressure next.
IDE00201 -- High fuel pressure: specified value
IDE00589-ENG167462 -- Fuel pressure OBD
