HEX-NET Issue Changing Adaptation
Chimuel
Boston, MA
C?ID=274674
I am getting this message when inputting 0 as a value. Note that 0 is a valid and in my case the default value from factory:
Auto-scan and Channel 09 Admap available in the Retrofit thread I started here: https://forums.ross-tech.com/showthread.php?18447-MK7-Foglight-Check-Bulb
EDIT:
I have now updated to VCDS Beta 19.4.0
HEX-NET firmware updated to:
CB: 04504
FW: 0.256
CFB: 0.10
BL: 0.28
DS: 60000057
Eric
HC800000
Just enter 00 for now. I'll see why VCDS is complaining about needing the totality of the channel size (16 bytes) instead of just the required user input (1 byte).
Chimuel
Boston, MA
C?ID=274674
Thanks for the quick response --is 00 the same as 0 for the CECM? The reason I am setting 0 is to disable the fog light bulb check warning/error checking by setting that adaptation channel to 0 (as recommended by DV52 in my Retrofits thread).
I set it to 00 but I still get the notification pop up on my instrument cluster and in the infotainment car status screen.
Eric
HC800000
Can't speak to what 0/00 is supposed to do inside the CECM firmware, but since it's a numeric, they're both the same as far as the CECM is concerned. VCDS is just being extra-cautious validating your input: it wants to see a double "digit" number even if it's less than 10.
Chimuel
Boston, MA
C?ID=274674
Are there plans to fix this so that it can accept a single 0?
hmm......... odd indeed. As I have said, I was able to stop lamp monitoring on individual Leuchte-sets by changing the "DTC-DFCC" channel setting on my test-bench.
Last suggestion is to also turn-off the Lampendefektbitposition channel (again, by setting the value to "0" ) in each of the Leuchte-sets. Perhaps Uw's point about different firmware versions in our two hex09 modules enforces this additional requirement for your BCM- long shot, I admit
Chimuel
Boston, MA
C?ID=274674
Last suggestion is to also turn-off the channel (again, by setting the value to "0" ) in each of the Leuchte-sets. Perhaps Uw's point about different firmware versions in our two hex09 modules enforces this additional requirement for your BCM- long shot, I admit
No luck with that one... I now have:
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren > in Betrieb lassen
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 > 00
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 > 00
Lampendefektbitposition (both LB45 and RB5) > 00
Maybe in the CECM 00 =/= 0?
Chimuel
Boston, MA
C?ID=274674
Ugh, no. Again, we're not sending text, we're sending numbers. The CECM has no interest in how you as a human choose to represent that number.
Thanks. In my work, programming large scale energy SCADA systems, a 00 and a 0 do not represent the same thing which is why I kept going down that thought process.
I appreciate the responses! --cheers
