Results 1 to 10 of 16
Thread: MK7 Foglight Check Bulb
    Jan 2018
    Hi all,
    A little background on the car --it's a 2015 US Spec Sportwagen S. I had the CECM replaced to include the pinouts for the foglights and have fitted the following:
    CECM part 5Q0-937-087-S
    Front fog lights to pins B5 and B45
    Rear fog light to pin A72
    Euro switch 5GG-941-431-D WZU (with Auto setting and a piggyback light sensor) pin 5 to A29
    Enhanced Auto Dim/Homelink Mirror part 000-072-548-E (this connects to the headlight switch, more below)
    So I have the light switch wiring as follows:
    Euro switch then the piggyback light sensor plugged into it, then the homelink sensor piggyback, then the original plug that goes to the CECM.
    I've got everything adaptation coded and double checked with a bunch of my notes and posts online and DV52's lighting guide and I still get the "Check Fog Light Right/Left" when I am in the Auto setting of the switch and the ambient (sun/shade) lighting changes --typically will see the error pop up when the headlights are triggered on by the sensor.
    The behavior I would see with my first set of bulbs (Nokia H11 2500k) was the fog lights would come on but then flash a few times, stay on, then cut off. I can turn the front fogs on forcibly by having the switch pulled all the way out to turn on the rear fog lights. I then switched bulbs for PIAA H11 2500k ones and the flickering went away and the fog lights will stay on but I still get the Check Bulb warning.
    I've attached the faults here:
    Monday,29,April,2019,21:11:59:56357
    VCDS Version: 18.9.1.0 (x64)
    Dealer/Shop Name:
    VIN: 3VWC17AU3FM516313   License Plate:
    Mileage: 77056km-47880mi   Repair Order: lighting
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
    VIN: 3VWC17AU3FM516313   Mileage: 77056km-47880miles
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5GM 906 264     HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091A00122424002F0000
       Shop #: WSC 00066 790 00218
       ASAM Dataset: EV_ECM18TFS0205GM906264 001001
       ROD: EV_ECM18TFS_VW37.rod
       VCID: 844409AC0FC7BA6A79-80D0
    Readiness: 1010 1101
       Part No SW: 09G 927 749 D    HW: 09G 927 749 D
       Component: AISIN AG6 G3  129 2866
       Coding: 010100000C000000000000000000000000000000
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: EV_TCMAQ250031_002_VW25.rod
       VCID: BA38B7543D833C9A53-80EE
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 50875000000483
       Coding: 04FA6AA124210972007A020181C6292056249000408194B400430050C002
       Shop #: WSC 01383 790 50316
       VCID: C7DEDEA07E715172DC-8092
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 02020004100100000000000012000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 854214A804FD83626E-80D0
       Part No SW: 5Q0 937 087 S    HW: 5Q0 937 087 S
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 865805111602BP
       Coding: 000018424041805969E44000000403001000000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: CBD6E2906219B512F8-809E
       Component: WWS    150403  043 0581
       Serial number:         150521102520
    8714 - Bulb for Left Fog Lamp
              B121F 15 [009] - Open or Short to Plus
                        Reset counter: 78
                        Mileage: 77056 km
                        Date: 2019.04.29
                        Time: 20:23:41
    8970 - Bulb for Right Fog Lamp
              B1220 15 [009] - Open or Short to Plus
                        Reset counter: 78
                        Mileage: 77056 km
                        Date: 2019.04.29
                        Time: 20:23:47
       Serial number: 003GCR01LNV5
       ROD: EV_AirbaVW20SMEVW37X.rod
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH0000J150002PRED0N
       Coding: 303138
       Subsystem 2 - Part No SW: -----------    HW: 480 003 003 15
       Serial number: 35700000000DCCFCE31B
       Subsystem 3 - Part No SW: -----------    HW: 480 002 603 15
       Serial number: 35800000000C2951931F
       Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
       Serial number: 3510002C51941315D11O
       Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
       Serial number: 3520002A31A878548381
       Subsystem 6 - Part No SW: -----------    HW: 480 400 104 15
       Serial number: 3550002AB1A14CA2035+
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 104 15
       Serial number: 3560002AB1A14CA5F2CN
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150327500211
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: BFCEC64026A119B264-80EA
       Part No SW: 5G1 920 840     HW: 5G1 920 840
       Component: KOMBI         243 4270
       Coding: 0BB5110A2180CF0502087E001000000000000000
       VCID: E484292CEF871A6AD9-80B0
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 30041510000556
       Coding: 0101000820085900FF0000081C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07027
       ROD: EV_GatewConti_011_VW37.rod
       VCID: F1AA50782075BFC2A2-80A4
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0101
       Serial number: 27140002727850095154
       Coding: 31FFFF
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 18051506050GBN
       Coding: 003003208C00040000000000
       VCID: BE30BB4421AB10BA6F-80EA
       Serial number: 00000000000001182805
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: C3C6CAB04A497D5200-8096
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 1505150605098O
       VCID: BD32BC482CAD0BA276-80E8
       Serial number: 00000000000001160412
       Coding: 091000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0655
       Serial number: V7B01504153511
       Coding: 02730200FF00000021220001001800001F0206040100010002
       Shop #: WSC 47844 001 104857
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9RS501QCL
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06000000
       Shop #: WSC 00066 790 00323
       ROD: EV_OCULowMQB.rod
    End----------(Elapsed Time: 01:15, VBatt start/end: 12.1V/12.0V)-----------
    I've uploaded my Channel 09 Adaptations here: https://www.dropbox.com/s/2muojbnejn...-0051.CSV?dl=0
    Anyone have insight? I am starting to think it's an issue with the Euro AUTO switch setting and light sensor (I've been troubleshooting this problem for a month now).
    Thanks!
    ^^^Hi and thanks for posting your BCM admap.
    Your leuchte-programming changes look OK (to me, at least) - assuming that the retrofitted front fogs are not LED (Nokia H11 2500k??). I wonder whether the problem is caused by your curious DoT rule that enforces a maximum of 4 x lights (I have never understood the road lighting rules in your country)
    Anyhow, I notice from the code-string on your BCM admap that the car has incandescent headlights - so, try changing IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren (my bad translation "Driving Light and parking Light -number of active head Lights ON limit 2") from limitieren (current) to not active.
  3. Likes Chimuel, Uwe liked this post
    Jan 2018
    Hi DV52!
    That is correct, I am not using any LEDs for the fog lights, Nokya and the PIAA are halogen.
    I don't have a "not active" setting but here are my two options for that channel:
    EDIT: I tried this setting and I still get the warning indicators.
    Hmm..... that's strange because I just checked the specs for your new fogs and they are 55W - the same as the factory lamps
    You could try shutting down the lamp monitoring function in the 2 x Leuchte-sets - but it addresses the affect of the fault, rather than its cause (not something that I like!)
    Anyhow, pending better advice from anyone else, it's done like this:
    • ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 > 0
    • ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 > 0
  6. Likes Chimuel liked this post
    Jan 2018
    No luck with that one --I tried inputting 0 and it gave me an error:
    I input 00 but I still get the Check Bulb Warning.
    ^^^ not "00", just enter "0"
  9. Likes Chimuel liked this post
  10. #7
    Jan 2018
    I entered 0 and the message I got was the screenshot. I entered 00 hoping it would have the same effect as 0.
  11. #8
    ^^ got me stumped - Ive changed these exact channels on ALL 35 x Leuchte-sets on the BCM on my test bench without any problems using both my HEX-NET and my HEX-CAN cables.
    And, a setting value of 0 is acceptable for the Fehlerort mittleres Byte DTC-DFCC channel on your BCM (look @ ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 on your admap)
  12. Likes Chimuel liked this post
  13. #9
    Jan 2018
    How would I go about getting a fix for this? I have set this value to zero a few times before but I only have access to the latest VCDS release or the beta release.
  14. #10
    Some difference in the firmware between the module you have on your bench and the module Chimuel has?
  15. Likes Chimuel liked this post
