Audi Q5 2015 3.0 TDI (after fix)
MoSerg
Canada
C?ID=342747
Hello fellows. Just got Engine Check light on. VCDS saying that
"18193 - Temperature Sender for Particulate Sensor
P24C6 00 [175] - Electrical Malfunction
MIL ON - Confirmed - Tested Since Memory Clear" (full scan below)
Didn't fine any "sender". ElsaWin gave Temp Sensor for particulate filter.
But on picture there are two sensors.
Is there any way I can know exactly which is failed (if it is) or using VCDS can I get part number?
Thank you.
Tuesday,02,April,2019,18:04:29:01286
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WA1DMCFP6FA0XXXXXX   License Plate:
Mileage: 36790km-22860mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
          6D 72 AC
VIN: WA1DMCFP6FA036400   Mileage: 36790km-22860miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 AC    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    X14 0008
   Revision: 58X14---
   Coding: 2A2A4012052603050000
   ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008
   ROD: EV_ECM30TDI0118K5907401AC_002.rod
   VCID: 71BFD6D791294AEF613-8024
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
4695 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
          U1113 00 [032] - -
          U1113 00 [032] - -
                    Mileage: 36745 km
                    Date: 2019.04.01
                    Time: 16:46:58
                    Engine speed: 1552.00 /min
                    Vehicle speed: 33 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.560 V
                    Exh u PP Ds Batt Snsr Raw: 14.4 V
                    Com i PP Ds IDE Raw: 0.000 µA
                    Exh i PP Ds IDE Shnt Circ: 0.0 µA
                    Exh st PP Ds St Ma-Bits 0-7: 0
                    Particle sensor: surface temperature: 949.98 °C
                    Particle sensor: heat voltage: 0.00 V
Readiness: 1 1 0 0 0
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H18 1007
   Revision: --H18---
   VCID: 4BC3643FD345403F3BF-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23150C03
   Shop #: WSC 06335 000 00000
   VCID: 117FB657F1692AEF013-8044
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0DA54040000000000000
   VCID: 074B980F8F2D645FDF7-8052
   Serial number: 0214000134947013
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01200820142082
   Coding: 3621228080
   VCID: 77ABE8CFFFCD14DFAF7-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000868793001
   Coding: 26000096863CAFE00100488300003D0D0F9CC708A6090221000008004400030100000034000000
   VCID: 78A9EBF3F2D31BA7A6D-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140717  H12 0050
   Serial number: 90243014140703141916
   Coding: 01DD13
   Serial number: 23082962
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002307141332
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z009A5F31
   Serial number: FF288B37000000000001
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12CZ1I
   Coding: 30373431343238313230554A304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC16723D64B4707325-8018
   Serial number: 6334MSME483E262CO
   Serial number: 6344MSME483A507DO
   Serial number: 6352QSME3C433068G
   Serial number: 6362QSME45434F78S
   Serial number: 63732SME35434F72%
   Serial number: 63832SME3243435E
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NH1000NR
   Coding: 000037
   VCID: 48C95B33C2B3AB2716D-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00300000    Serial number: ZD456FN8F
   Coding: 8BA6220002010008020000
   VCID: 45D75207F5A1B64FEDB-8010
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y147200C5F
   Coding: 80CF07FF00
   VCID: 4ACD613BDCBF5937009-801E
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 3552144103
   Serial number: 14210001707011200181
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000113924111
   Coding: 01581B00000000000000
   VCID: 42DD491BE48F8177C89-8016
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000112231608
   Coding: 011D13205E00440004
   VCID: 4FFB702F27DD7C1F577-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0013861819
   Coding: 100000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3FDB40EF97FDEC9FA77-806A
   Revision: 00002001    Serial number: 0344262116
   Coding: 0126023A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Serial number: 00000000000000871569
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 15
                    Reset counter: 236
                    Mileage: 30116 km
                    Date: 2018.10.09
                    Time: 11:33:38
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 8
                    Reset counter: 232
                    Mileage: 30116 km
                    Date: 2018.10.09
                    Time: 12:01:47
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000113961286
   VCID: 4EC56D2B20D775175C1-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000488820
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D31FB8CDFC9B7909-806E
   Revision: AB001007    Serial number: 156H$0E8051537
   Coding: 020007020100000001
   VCID: 2411EF831EDBAF47DA5-8070
   Part No SW: 8R1 035 664 F    HW: 8R1 035 664 D
   Component: H-BN-NA       H41 0812
   Revision: --------    Serial number: 203H%0EB008785
   Coding: 16020006000581EF45028B4E00000403F40000020000000000
   VCID: 392F2EF78959C2AF993-806C
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Serial number: A130GK0E3102166
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001945822
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000114459250
   Coding: 010C13204000240004
   VCID: 46D5550BC8A7BD57E41-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J46A0SS
   Coding: 1020010
   VCID: 34311FC3A23B3FC74A5-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D273AE79D71FE8FB5B-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000114451651
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142160244
   ROD: EV_RDCMA00100_008.rod
   VCID: 2D070AA74D916E0F05B-8078
End----(Elapsed Time: 02:03, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 8K5 907 401 AC    HW: 4G0 907 401 E
  Component and/or Version: 3.0TDI FSA    X14 0008
           Software Coding: 2A2A4012052603050000
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008 (AU48)
          U1113 00 [032] - -
          U1113 00 [032] - -
          U1113 00 [032] - -
          U1113 00 [032] - -
                    Mileage: 36745 km
                    Date: 2019.04.01
                    Time: 16:46:58
          U1113 00 [032] - -
          U1113 00 [032] - -
          U1113 00 [032] - -
          U1113 00 [032] - -
                    Mileage: 36745 km
                    Date: 2019.04.01
                    Time: 16:46:58
Address 01: DTCs cleared
Address 46: DTCs cleared
Interesting. The original German text for that fault code is: "Partikelsensor Temperaturgeber: Elektrischer Fehler". So the translation is correct. However, I would imagine that "Temp Sensor for particulate filter" is the part you're looking for, and someone in the Fatherland (probably wearing a white lab coat) goofed on the fault text.
MoSerg
Canada
C?ID=342747
"Partikelsensor Temperaturgeber: Elektrischer Fehler" - for me sounds right like Temperature Giver/Provider ( exact translation ) - which means "sensor".
But Elsa shows two temperature sensors on Particulate Filter (before and after). But error saying "Tem sensor for particulate sensor", not filter.
Is Particulate sensor has Temp sensor in it ? Any thoughts?
Gone But Not Forgotten
Yeah one is TEMPERATURE and others you ref are using PRESSURE ......... :p
https://www.youtube.com/watch?v=hmUVo0xVAqE
Thermocouples get inserted into something to test the range just be careful what orifice location is important and PSI sensor have hoses to them because if the sensor was in the path VAG uses would melt.
MoSerg
Canada
C?ID=342747
But to replace this I need whole particulate sensor or as a piece Temperature Sensor only, do you know? I know it is covered by extended warranty, but just to know...
NEtech
Denmark
C?ID=56995
I would think it is the Particulate Sensor, part number 8R0 906 261 A
There should be 4 exhaust temperature sensors, the last, is after particulate filter, 8K0 906 088 B
albdiag
Albania
C?ID=154548
Hi
Did you ever find out what sensor was that?
Thx
