Audi green screen
wuplur
C?ID=247333
Just realized this should probably be moved to “tweaks”
wuplur
C?ID=247333
Thanks Uwe. Figured out that it’s the developer mode adaptation in the 5F but it won’t accept my input and just gives me in error. Tried in both VCDS & Odis.
TBAx
C?ID=287144
Did you use the special SA (in VCDS) / switch to Engineer session (in ODIS) before changing the adaption?
wuplur
C?ID=247333
Please explain, I have no idea what either of those are. Are you referring to the module login access? I went there in VCDS but it did not have a suggested code. Not sure what engineer session is in Odis.
wuplur
C?ID=247333
Correct, thanks UWE.
Here it is to simplify.
Monday,31,December,2018,11:33:51:59771
VCDS Version: 18.9.0.2 (x64)
VIN: WAUFMAFC1GN044315   License Plate:
Mileage: 11085km-6887mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 52 53
          55 5F 62 6C 72 8F 90 AC
VIN: WAUFMAFC1GN044315   Mileage: 11085km-6887miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 AA    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0010
   Revision: 58H14---
   Coding: 0A2A4012052601050000
   Shop #: WSC 14119 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401AA 002009
   ROD: EV_ECM30TDI0114G0907401AA_002.rod
   VCID: 62CBEE0D75A6CA5AA3-8036
Readiness: 0 0 0 1 1
   Part No SW: 4G0 927 158 AQ    HW: 0BK 927 156 AM
   Component: 0BK 30TDIUSA  H19 1006
   Revision: --H19---
   VCID: 7DF1BD71EC1815A2BE-8028
   Coding: 47A79641E2E569821B00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41890181D060B1429A-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Coding: 0DA86F4E000000000000
   VCID: 7F0D4779EE1407B2AC-802A
   Serial number: 3215000104981001
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23061500041829
   Coding: 36013178490000
   VCID: 63C5EB096ABCC352A8-8036
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00001100701701
   Coding: 01050011043C9FE08100408780003800CF9CD208A608022180000814F110150200600034030000
   Shop #: WSC 44079 002 1048576
   VCID: 76E3A25DC12E46FAFF-8022
   Component: WWS57X 150531  H37 0080
   Serial number:         150616052211
   Coding: 0045F7
   Serial number: 24044822
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 18 06 2015  00001116
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01FA4865
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA121037000013741817
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: F16885B7000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56291508303015
   Coding: B83B14
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 3663625D89AE06FA3F-8062
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [009] - Open Circuit
                    Reset counter: 230
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:39
          B10FC 13 [009] - Open Circuit
                    Reset counter: 230
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:07
1080340 - Parking Aid Speaker
          B107C 14 [009] - Open or Short to Ground
                    Reset counter: 230
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:05
1111316 - Speaker for Front Parking Aid
          B10F5 14 [009] - Open or Short to Ground
                    Reset counter: 230
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:05
1113874 - Parking Aid Indicator Lamp
          B10FF 12 [009] - Short to Plus
                    Reset counter: 230
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:05
12727552 - Databus
                    Fault Frequency: 7
                    Reset counter: 232
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:10:06
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G00028K4A
   Coding: 303331343135303334394A55304C34473053
   VCID: 346758559FD214EA01-8060
   Serial number: 6940000Y150001D17500
   Serial number: 3575HRB405J3DASA4100
   Serial number: 3585HRB40553DV8QFGSF
   Serial number: 3515JRB400Q54SDQE1EY
   Serial number: 3525JRB400Q54SDQCORQ
   Serial number: 3554VRB40593F0KQ2ODZ
   Serial number: 3564VRB405L3F0KQF01P
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OFH001MA
   Coding: 000034
   VCID: 3B757369BA8CDB92C0-806E
   Serial number: 10 06 2015  G0028216
   Part No SW: 4G8 920 986 R    HW: 4G8 920 986 R
   Component: TDieUsa   Nv  H10 0106
   Revision: 06001087    Serial number: 658220615596042
   Coding: 03EF0A040B41D705020000
   Shop #: WSC 42403 001 104857
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 479D1F99FE448F7254-8012
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001900500
   Coding: C0CD078110
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B757369B28CDB92C0-806E
   Serial number: 3705017003
   Voltage stabilizer:
   Serial number: 15040200000000000391
   Component: KLIMA FOND    H08 0112
   Serial number: 25061500040754
   Coding: 20
   VCID: 3D717D71AC98D5A2FE-8068
   Revision: AA000000    Serial number: 00000145760815
   VCID: 77FDAF59C6243FF2E4-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720J8AEB
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33655B499ADC13D218-8066
   Component: SWA Master    H06 0060
   Serial number: 0372927037
   Coding: 040211
   VCID: 39796961B8B0E982D2-806C
   Component: SWA Slave  H06 0060
   Serial number: 0371975844
   Coding: 040211
   Coding: 011F17015E00628002000012
   VCID: 479D1F99F6448F7254-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0012933979
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0371680308
   Coding: 0106063A00FA418583A0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000296508
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000DCACB00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93569235
   Coding: 011F17015E00628002000002
   VCID: 4683129DF14E967AAF-8012
   Revision: --------    Serial number: 00000001511441
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D514D317CF845224E-8078
   Coding: 04FA021122200400
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 025 E    HW: 4G1 035 025
   Component: MU-H-LNS-US   042 1062
   Serial number: A278F0F7504982
   Coding: 017501020000000013220002041A00102F0006E5F1700104FE
   VCID: 204FA4053B2A984AF5-8074
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY801TCZ
   Multimedia Operating Unit:
   Serial number: 90349OFP000W8
   Component: Gracenote2  --- 3006
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 15
                    Mileage: 11049 km
                    Date: 2018.12.27
                    Time: 18:06:14
                    Voltage terminal 30: 14.8 V
                    BAP-BAP_Function_ID: 01
   VCID: 499919A1E050790242-801C
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027501010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_VW51.rod
   VCID: 326B5E4D65C61ADA13-8066
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169514160C021C26A-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 151561097
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:41)--------------------------
wuplur
C?ID=247333
I get an error “request out of range” when the only 2 options are activated/not activated.
TBAx
C?ID=287144
Check your Private Messages for a possible fix for the Security Access.
Dana
Western PA, USA
I added that 5F module to our redirect file. It should make it to the next VCDS Dataversion but you can drop an e-mail to Support with a link to this thread if you need it sooner.
wuplur
C?ID=247333
Not sure what this means Dana, what is a redirect file? The next data version means the next update? I downloaded the beta and i can’t use it because my older cable is not compatible. Didn’t think the issue was with VCDS because I get denied with a similar error when using ODIS.
Dana
Western PA, USA
Hi Manny,
I believe Daniel (TBAx) set you up with the manual instructions but you need the latest VCDS Beta which requires a current interface. I'm not sure if civilian level ODIS allows you to change diagnostic modes but you would receive an error if it wasn't in developer mode.
We can resolve this easily. I'll send you a redirect file via email so you can use VCDS Release. :thumbs:
wuplur
C?ID=247333
Daniels file worked! Thanks you 2!
wuplur
C?ID=247333
Does this feature expire somehow? Developer mode reverted back to “not activated” and I tried to change it back and the 5F won’t accept the S12345 log in anymore.
TBAx
C?ID=287144
Normally it should not. I got this once, after the dealer installed an firmware update to the main unit. Other than that (and obviously a swap of the unit) I do not see a reason for this to happen.
wuplur
C?ID=247333
It may have reverted back after I had CarPlay installed. How about the user label file you sent me, any reason why that would not work again?
TBAx
C?ID=287144
Yes, it should still work. Has the part number changed in the CarPlay activation process? Or asked in another way: the SW part number is still "4G1 035 025 E"?
wuplur
C?ID=247333
Looks like it did. 4G1035025F
