P1127 & P0172 - Too Rich codes
   #21
Should be a code by second DCY or its FOD!
JPPSG.........
Please post OBD2 MODES 1,3,7 & 9 Thank you!
   #22
dodaman
C?ID=332400
   #23
dodaman
C?ID=332400
Just saw your last part of that post about I’ll take that scan and send those over to you. Thank you very much have a great night
   #24
dodaman
C?ID=332400
Hi Jack.
I ran the reports. You’ll have to excuse the novice here. I’ve never run OBD2. So I’m not exactly sure what you meant. I think is was the numbered modes you stated. But with mode 1, I wasn’t sure which numbers you wanted in the drop down menu. I did 3,7,9 since there was no #1 within mode 1. If I screwed up, let me know. Thanks. I’ll post what I did in a little bit. Thanks again.
   #27
dodaman
C?ID=332400
Mode 1-1 for readiness and MIL display.
Morning Jack,
Here are my scans. I did the following, mode 1-1, 3, 7, 9 and a mode 1 with LTFT in drop down box. I also ran regular VCDS scan just in case. I wasn't sure if it would make a difference, but I compared them with car running and off. They came out the same as you probably knew. I look forward to hearing from you. Thanks.
Monday,29,April,2019,09:05:06:29843
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN:    License Plate: MODE 1
VCDS Release 18.9.1 (x64):  Generic OBD2
Mode 1:Read Data
07:Long Term Trim - Bank 1     -14.1 %
09:Long Term Trim - Bank 2     -11.7 %
Monday,29,April,2019,09:06:16:29843 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4 Data version: 20190114 DS296.0 www.Ross-Tech.com VIN: License Plate: MODE 1-1 Mode 01 - PID 01 : Readiness -- Address 10 Number of DTCs stored: 0 -- MIL Status: MIL OFF Misfire monitoring: Passed Fuel System: Passed Comprehensive Components: Passed Catalyst monitoring: Passed Heated catalyst monitoring: Not installed. Evaporative system monitoring: Passed Secondary air system monitoring: Passed A/C system refrigerant monitoring: Not installed. Oxygen sensor monitoring: Passed Oxygen sensor heater monitoring: Passed Exhaust Gas Recirculation: Not installed.
Monday,29,April,2019,09:09:06:29843
VIN:    License Plate: MODE 3
Mode 03: Emission related fault codes
Address 10 (Engine): No fault code found.
Address 1A (Auto Trans): No fault code found.
Monday,29,April,2019,09:08:32:29843
VIN:    License Plate: MODE 7
Mode 07: Pending emission related fault codes
Monday,29,April,2019,09:08:01:29843
VIN:    License Plate: MODE 9
Type 02 - VIN : WAUDT48H35K005891 (Address 10)
Type 04 - Calibration ID : 8E1909559B  0030 (Address 10)
Type 04 - Calibration ID : 8E0927156AB 0404 (Address 1A)
Type 06 - Calibration Verification Number : 9372EBA5 (Address 10)
Type 06 - Calibration Verification Number : 0000D183 (Address 1A)
Sunday,28,April,2019,20:06:54:29843
VIN: WAUDT48H35K005891   License Plate: REG SCAN 4-28
Mileage: 46060km-28620mi   Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUDT48H35K005891   Mileage: 46060km-28620miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E1 909 559 B    HW: 8E0 909 059 A
   Component: 3.0L V6/5V      G   0030
   Revision: 00000000    Serial number: AUZ6Z0D0285717
   Coding: 0013754
   Shop #: WSC 00672 785 00200
   VCID: 3537DC2D09563F9F7DB-5160
   Part No: 8E0 927 156 AB
   Component: AG5 01V 3.0l5VT USA 0404
   Coding: 0001002
   VCID: 6E8533412C804C477C1-5160
   VCID: 55F77CADAC161F9F9DB-51A8
No Faults Found
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1424
   Coding: 00100
   Shop #: WSC 00672
   VCID: 63935275F242F12FE3F-513C
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   VCID: 3537DC2D0C563F9F7DB-4AE0
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 D
   Component: Airbag 8.4EC        0015
   Coding: 0010105
   VCID: 3B23CA152F72E9EF8BF-5160
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 02041
   Shop #: WSC 00672
   VCID: 3E25C3013960FCC7AC1-4AE0
   Part No: 8H0 920 950 H
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 01401
   Shop #: WSC 09401
   VCID: 313FE83DF83E13BF213-5160
   WAUDT48H35K005891     AUZ6Z0D0285717
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255
   Component:  VSG  B6 CABRIO     6386
   VCID: 73B3223547A261AF93F-5160
   Part No: 8H0 959 760
   Component: Sitzmemory EE H06   0010
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74B12129479C66978A5-4B1E
   Part No: 8H0 959 433 E
   Component: Komfortgerát T7B    3320
   Coding: 11820
   Shop #: WSC 00672
   VCID: 3635DB2111503487741-4AE0
   Subsystem 1 - Part No: 8H1959801B
   Component: Tõrsteuer.FS BRM 3020
   Subsystem 2 - Part No: 8H1959802B
   Component: Tõrsteuer.BF BRM 3020
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
   Part No: 4Z7 907 357
   Coding: 00070
   Shop #: WSC 00672
   VCID: 045171E9173C5617BA5-4B1E
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H13   0010
   Coding: 00006
   Shop #: WSC 00065
   VCID: 3537DC2D0C663F9F7DB-4B1E
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H13   0010
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:33, VBatt start/end: 12.2V/12.2V)-----------
   #28
dodaman
C?ID=332400
Hello Jack and Uwe,
I was wondering if either one of you had any other ideas or suggestions. Sorry to push. I’m kinda new with this Audi and am not looking forward to any love/hate thing I read about so often 😃. Maybe I’m overthinking it and just need wait to see if the CEL lights comes back. I appreciate any input you both may have. Thanks. Enjoy your evenings.
   #29
Watch the fuel trims. That should give you a pretty good indication whether you've got the problem under control. Also do the MAF test again to see if it now produces values more in line with what's expected.
http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
https://www.youtube.com/watch?v=kqVSgva4lSs
Make sure no restricted exhaust or intake such as carbon too?
dodaman
C?ID=332400
Thanks. I will and report back.
Thanks for the links. I’ll watch these tomorrow. ����
   #32
Were you or are you now experiencing a drive-ability issue FMPG loss in this car & even after fixing the aforementioned vacuum leak & DTC?
   #33
dodaman
C?ID=332400
No. I’m not experiencing any driving issues. In fact, The power is better. Just filled up, so not sure about mileage yet. As of 3 days ago, the LTFT were still negative, -14 and -17 roughly but no CEL’s. I haven’t had time to hook up computer and VCDS since then. I’m planning on checking them tomorrow along with redline test
   #34
dodaman
C?ID=332400
Forgot to mention. This is just too much fun ��
   #35
dodaman
C?ID=332400
Hello, was away for a bit, but I was finally able to do the MAF test again. It was where is should be. it was over 180. I've been driving the car regularly since fixing the vacuum leak, and the check engine light has stayed off. I ran the below scan, and was watching the numbers on the fuel trims They were still rich. I'm sorry, I forgot to log that scan, but they were -9.6 & -7.8. Not enough to throw a code yet, and it is the longest it has gone without a light going off since it first started. But there still must be some issue if they keep going negative. Anyway, any other suggestions, would be greatly appreciated. Thanks again.
Have a great night
VIN: WAUDT48H35K005891   Mileage: 46630km-28974miles
   Coding: 0013754
   Coding: 0001002
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 04497
   Shop #: WSC 00672
   VCID: 26150B61C1F04407C41-51A8
   Coding: 00100
   Shop #: WSC 00672
   Coding: 01013
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
   Coding: 01401
   Shop #: WSC 09401
00532 - Supply Voltage B+
   Coding: 00002
   Shop #: WSC 00065
   Coding: 11820
   Shop #: WSC 00672
   Coding: 00070
   Shop #: WSC 00672
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:15, VBatt start/end: 12.4V/12.2V)-----------
Yeah.......... another false air leak or fueling issue evading you & moving ADP!
Find it!
Inverse in the Televerse
JPPSG for FOD!
   #37
dodaman
C?ID=332400
Thanks Jack,
I’ll keep chipping away at the possible culprits. BTW, what is ADP? Thx.
   #38
ECU 'adaption' tables, just hover thy cursor on bold characters in forum!
cpcodA4
C?ID=369209
New poster here and am really struggling with all of your abbreviations. You seem very knowledgable and willing to help, but if there is some secret ross-tech language, I don't know it.
JPPSG.........
