Lost AAC and Cruise control by disconnecting battery
Jdobbins
Hi. As per title. Disconnected battery to work on alternator. Reconnected battery lost front assist. Just looking for any info b4 it goes in to the stealers. They’re talking about £500 to re calibrate.
2018 skoda Octavia
Latest version of vcds does not allow any login or reset of auto dist module 13. Surely it can’t be out of alignment if the radar and bumper has never been touched. Security access code 14117 does not work on these second generation Bosch MQB H10 0654 modules.
I could post a full scan and the angles of misalignment in proper area later The fault code C1103 sensor for automatic distance regulation incorrectly positioned. ACC reversible error.
Just looking for any knowledgeable people on this subject to inform me what’s going on. If it is out of alignment then I will have no issues paying the dealer to fix as I realise it’s a safety feature that has to be precise if a computer controls brakes and throttle.
Regards
Westbury, UK
What type of cable do you have - HEX+CAN, HEX-V2 or HEX-NET?
A full Auto-Scan would be very helpful.
Jdobbins
Yes it’s hex can. I need to upgrade. Going to go out to car soon get a fresh scan and a screen print of the misalignment angles then read up on how to post properly again as it’s been a while.
Westbury, UK
IIRC HEX-CAN can't fully access/setup all the modules on a 2018 Octavia - at least that's what I'm reading owners posting on briskoda.net
For how to post an Auto-Scan see my signature.
For images you need to host them online, somewhere like imgur, then copy the link and paste it in img tags.
Jdobbins
Sunday,14,April,2019,11:54:04:04365
VCDS Version: 18.9.1.0 (x64)
VIN: TMBBP7NE6J03XXXXX   License Plate:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 47 52 5F 6C
VIN: TMBBP7NE6J03XXXXX   Mileage: 51140km-31776miles
Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BH    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 4038
   Revision: W1H26---
   Coding: 01250032236419081000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM10TFS01104C906026BH 002003
   ROD: EV_ECM10TFS01104C906026BH.rod
   VCID: 68DFEF689362D60A75-803C
   CAN Converter 01:
   Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501802195086
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 377D7C148E5C89F22C-8062
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60698000001032
   Coding: 24078A912420216D407F060960C5242451248402600624723621F070C002430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
   VCID: 0305D8C48A041552C0-8056
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0473395930
   Coding: 032C0C
   Shop #: WSC 73430 790 00063
   VCID: 3C776338B77AAAAAC1-8068
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 01110004000110011005000800101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 74E78B18DFAA22EAC9-8020
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001806100580
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081FCFE8B322360A95-805C
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180131  051 0916
   Serial number: 887253F0401803100811
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: S9Y18M03D09H06M09S19
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY17245295V
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223980182586
   Sun Roof:
   Subsystem 5 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.405  H04 0005
   Serial number: 0000FST001YLBKF00000
   Coding: 981803
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018058
   Coding: 0471151051
   VCID: 4B9530E4E2D41D1278-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300600141FFC728949C810520400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E736930A166B8BAEF-806A
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
                    Reset counter: 22
                    Mileage: 51140 km
                    Date: 2019.04.14
                    Time: 11:47:59
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 12.1 V
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P40ZE4Z
   Coding: 98CCC000000000005C5400CC008800000065
   VCID: 0501C6DC84302B62EE-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 002 502 18
   Serial number: 35700000000FB09D6D2+
   Subsystem 2 - Part No SW: -----------    HW: 454 002 302 18
   Serial number: 35800000000450887D2K
   Subsystem 3 - Part No SW: -----------    HW: 454 802 402 18
   Serial number: 35100EF32BC13000000R
   Subsystem 4 - Part No SW: -----------    HW: 454 802 002 18
   Serial number: 3520024DDBB13000000P
   Subsystem 5 - Part No SW: -----------    HW: 454 801 902 18
   Serial number: 355008CD58313000000N
   Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02031804400638
   Coding: 6410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7F0D5434E6EC71B2A4-802A
   Part No SW: 5E0 920 950 F    HW: 5E0 920 950 F
   Component: KOMBI         303 0310
   Coding: 23A402182580860001886A011001000000000000
   VCID: 2959AA6C48E82F02AA-807C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007518863
   Coding: 030100047F085700EB0002581C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 387F7F288342868A25-806C
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Serial number: 000000000A2191070318
   Serial number: 75886000001803110BC4
   Revision: 00000000    Serial number: 18000058674007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34674B189F2A62EA09-8060
   Serial number: 0000308203087
   Coding: 00110020D001040000001100
   VCID: 479D0CD4FEBCF9725C-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000019590172
   Coding: 1D0200
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E58804DAA425D2D0-8026
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE041G3T
   Coding: 0373010000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59B9DAAC58087F82FA-800C
   Serial number: 0000307850848
   Coding: 00110020DC01040000001100
   VCID: 468301D0F9B6E07AA7-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000019833307
   Coding: 050200
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0471
   Serial number: SKZAZ2U0475647
   Coding: 037301010000000041111202008800002F0208E601200500CF
   ROD: EV_MUStd4CTSAT_VW36.rod
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHT2113199
   Subsystem 2 - Part No SW: 5L0 051 236 AR    HW: -----------
   Component: ECE1 2019/20  --- 1115
   Coding: 0473010122002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
   VCID: 39797A2CB8489F82DA-806C
End-------------------------(Elapsed Time: 04:56)--------------------------
Jdobbins
Jdobbins
Thanks PetrolDave, I've contacted Gendan about a trade in for a nice new interface
NEtech
Denmark
C?ID=56995
Try and drive some trips, highway, above 50 km/h, 30-50 meter behind other cars.
See if DTC is not changing to intermittent.
Jdobbins
Car back from dealers. Quoted me £575 for Radar calibration. After I stopped laughing, I offered the Service manager a bare knuckle boxing match in the car park and got him down to £360. Apparently in 6 months time this could happen again. It was ready to disable this system and disconnecting battery was just a fluke
siLc
Tallinn, Estonia
C?ID=330192
Thats an absolutely insane price for only ACC radar calibration - I'm curious whats the quote contains?
Jdobbins
They're not called the stealers for nothing. I think they might have been chancing their luck as they knew it was going for a tough taxi test and just like an Mot any sort of dash warning light is a fail, was just a calibration as far as I know. Car is still under warranty. however ACC Calibration is considered a wear item like brake pads etc. For my money I also got my front control arm rear bushes fixed. I had complained about a creaking noise on poor road surfaces and speed humps. They said they had noticed Skoda taxis seem to suffer from this. Tech coated them in silicone grease and the noise has completely disappeared. So wasn't bothered about the £360 cost and was quite happy to have my ACC back and smoother suspension. I can't live with out that ACC now. One thing I have realised is that in the future these complicated cars are going to be written off a lot sooner with repair costs costing more than the cars worth. In my day I could buy a mark one fiesta and replace everything from a scrapyard for little cash, didn't have to worry about computer modules and expensive alignment equipment. I pity teenagers today buying their first motor.
