Hi all
Looking for some help diagnosing a p2002 fault code on my Golf Mk7 TDI 1.6 Bluemotion.
I have replaced the G450 sensor and performed an adaptation. I think the differential pressure values look normal (5hPa at idle up to 100hPa at 2500RPM)
The DPF soot values look normal too (15g soot load / 21% ash load) and the DPF is performing an auto regen every 300 miles or so.
So why am I getting the p2002 fault? Any help / ideas appreciated.
Autoscan result below
Monday,04,March,2019,19:18:05:18630
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WVWZZZAUZFW093244 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW093244 Mileage: 98079km-60943miles
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FD HW: 04L 907 309 E
Component: R4 1,6L EDC H22 6544
Revision: 86H22---
Coding: 01190012030511096000
ASAM Dataset: EV_ECM16TDI01104L906021FD 002004
ROD: EV_ECM16TDI01104L906021FD.rod
VCID: 6C81C6FD860F7B07525-8038
19226 - Particulate Trap Bank 1
P2002 00 [101] - Efficiency Below Threshold
Mileage: 98060 km
Date: 2019.03.03
Time: 17:44:28
Engine speed: 1827.50 /min
Normed load value: 56.5 %
Vehicle speed: 108 km/h
Coolant temperature: 90 °C
Intake air temperature: 90 °C
Voltage terminal 30: 14.180 V
Exhaust mass flow of low-pressure EGR: calculated: 23.807
Differential pressure ratio: low-pressure EGR: 27.9 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 857.4 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1057.0 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 50.31 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 44.70 %
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 62144000002735
Coding: 01FA8AA12429096F0379060441C72580512490C06082A4F300400078C002
VCID: 074B9951BFA9B85FDF7-8052
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 Q HW: 5G0 907 426 Q
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 392F2FA9B9DD1EAF993-806C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 AF HW: 5Q0 937 084 AF
Component: BCM MQBAB B H18 0134
Serial number: 01011421700177
Coding: 03000842C20100530BA44000000403081000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7CA1F6BDF66FEB87C25-8028
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140724 042 0551
Serial number: 140728103713
B1263 01 [009] - Electrical Failure
Reset counter: 15
Mileage: 98051 km
Date: 2019.03.03
Time: 15:17:42
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0ABP7I
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 41DF4749D10D466FD13-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 408 14
Serial number: 35767000000CD969C014
Subsystem 2 - Part No SW: ----------- HW: 480 001 408 14
Serial number: 3586700000023935B01K
Subsystem 3 - Part No SW: ----------- HW: 480 401 408 14
Serial number: 3516502AF16DB804A11G
Subsystem 4 - Part No SW: ----------- HW: 480 401 408 14
Serial number: 3526502B716DB812618C
Subsystem 5 - Part No SW: ----------- HW: 480 401 408 14
Serial number: 3556502B116DB8140332
Part No SW: 5Q0 953 507 AB HW: 5Q0 953 549
Revision: -------- Serial number: 16081404400602
Coding: 0600
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 76B5E495C843B1D7B41-8022
Part No SW: 5G1 920 931 HW: 5G1 920 931
Component: KOMBI 106 5292
Coding: 27A4020023002600010808000400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 6597B3D965E54A4F0DB-8030
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal electronic failure
[Steuergerät defekt (SiLa) "Sicherheitswarnlampe"]
Mileage: 58398 km
Date: 2017.06.12
Time: 10:50:40
Part No SW: 5Q0 907 530 R HW: 5Q0 907 530 D
Component: GW MQB Low 126 1188
Revision: -------- Serial number: 0002381931
Coding: 030000040B087300EF000048080E00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011_VW37.rod
VCID: 40D9424DDA074F67DED-8014
Subsystem 2 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0261694103
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 02081402090430
Coding: 003002208001040100001000
VCID: 3E253CB5A0F33997AC1-806A
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 20061403110497
Coding: 003000208001040100801000
VCID: 3D273BB9ADF5228FB5B-8068
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 041 0421
Serial number: V5C01908142162
Coding: 02730000FF00000021111201000800001F0100060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F1BE1310739509F877-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9PS203EP4
End----------(Elapsed Time: 01:20, VBatt start/end: 14.4V/14.2V)-----------
