- Feb 11, 2019
- 25
- 5
- South Africa
- C?ID=353028
I just received my Hex-V2 cable. Best thing that has ever happened to me and my car.
Now for the core of my first post. I did a scan on an '07 B7 RS4 and this is what I got. History: I had carbon clean done, changed fuel filter, replaced spark plugs 1 year ago (after injector cleaner burnt them) after misfires. Also noticed that my N276 valves were leaking on both hpfp and installed new pumps. First scan today picked up low pressure error from time the fuel was leaking from hpfp, and few other errors from the past. Cleared DTCs. Drove a bit and got the below results.
Why would N276 error come up with brand new pumps? Electrical fault?
Self-Diagnosis Log
Monday,11,February,2019,12:58:06:17755
Page 2
VIN: WUAZZZ8E47NXXXXXX License Plate:
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 B HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0040
Revision: --H13--- Serial number:
Coding: 01040000180F0160
Shop #: WSC 03163 996 87872
VCID: 2516040569E5539FCDD-8070
8 Faults Found:
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground
Fault Status: 01100010
Mileage: 134367 km
RPM: 779 /min
Load: 26.7 %
Temperature: 101.0°C
Temperature: 59.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.589 V
008201 - Intake Manifold Flap; Bank 1
P2009 - 002 - Short to Ground
Mileage: 134367 km
RPM: 779 /min
Load: 26.7 %
Temperature: 59.0°C
Voltage: 13.589 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground
Self-Diagnosis Log
Page 3
Mileage: 134367 km
RPM: 779 /min
Load: 26.7 %
Temperature: 59.0°C
Voltage: 13.716 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
Mileage: 134367 km
RPM: 779 /min
Load: 26.7 %
Temperature: 59.0°C
Voltage: 13.716 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
Mileage: 134367 km
RPM: 779 /min
Load: 26.7 %
Temperature: 59.0°C
Voltage: 13.716 V
Self-Diagnosis Log
Page 4
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground
Mileage: 134367 km
RPM: 779 /min
Load: 26.3 %
Temperature: 59.0°C
Voltage: 13.589 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground
Mileage: 134367 km
RPM: 780 /min
Load: 26.3 %
Temperature: 59.0°C
Voltage: 13.589 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground
Mileage: 134367 km
RPM: 780 /min
Load: 26.3 %
Self-Diagnosis Log
Page 5
Temperature: 59.0°C
Voltage: 13.589 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B02F23D0F0165EF1B9-807E
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BQ
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 71BE2055E8BD4F3F615-5160
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01041
Shop #: WSC 06335
VCID: 3D26CC65E465FB5FB5D-4B00
Self-Diagnosis Log
Page 6
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
Revision: --H13--- Serial number: XXXXXXXXXXXXXX
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 134360 km
RPM: 202 /min
Load: 98.4 %
Temperature: 21.0°C
Temperature: 24.0°C
Voltage: 10.668 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129C - 002 - Short to Ground
Mileage: 134360 km
RPM: 195 /min
Load: 99.2 %
Temperature: 21.0°C
Temperature: 24.0°C
Voltage: 10.668 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0051 - 002 - Short to Ground
Self-Diagnosis Log
Page 7
VIN: WUAZZZ8E47N903060 License Plate: BZ75KZGP
Mileage: 134360 km
RPM: 1249 /min
Load: 48.2 %
Temperature: 28.0°C
Temperature: 25.0°C
Voltage: 13.589 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground
Mileage: 134360 km
RPM: 1190 /min
Load: 49.0 %
Temperature: 36.0°C
Temperature: 25.0°C
Voltage: 13.589 V
Self-Diagnosis Log
Page 8
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3HAVM
Coding: 0430712
VCID: 3B22C27DFF61F56F8B9-806E
Subsystem 1 - Serial number: 6332DRB403E2CE25Z
Subsystem 2 - Serial number: 6342DRB403D51224E
Subsystem 3 - Serial number: 6352ARB4018BBE3C%
Subsystem 4 - Serial number: 6362ARB4018BD57F0
Subsystem 5 - Serial number: 63729RB401A3FFF0%
Subsystem 6 - Serial number: 63829RB401A3F6A1U
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 06021
Shop #: WSC 06335
VCID: 44D0B981878F8A97FA3-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023111
Shop #: WSC 03163 996 13764
VCID: 2C00F1210A1F62D7123-5184
Self-Diagnosis Log
Page 9
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023111
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760 A
Component: Sitzverstellung H01 0020
Coding: 00001
Shop #: WSC 06335
VCID: 323CEF592D0B342758F-4B1E
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0500
Revision: 01S Serial number: AUZBZ7F1182915
Coding: 0301114
Shop #: WSC 02195 785 00200
VCID: 2C00F1210A2F62D7123-5160
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6B82323DCA91A5EF5B9-50F4
Self-Diagnosis Log
Page 10
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07918
Shop #: WSC 03163
VCID: 79AE1875B0CD077FD95-4B00
Subsystem 1 - Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E2959801E
Component: Tõrsteuer.BF BRM 0706
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290E083505FD77FFE95-807C
Component: AFS-Modul links H03 0010
Component: AFS-Modul rechtsH03 0010
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0301114
Self-Diagnosis Log
Page 11
VIN: WUAZZZ8E47NXXXXXXX License Plate:
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No SW: 4D0 919 146 D HW: 4D0 919 146 D
Component: TV Tuner H040580
Revision: 01H04001 Serial number: 00000000015330
Coding: 0007130
VCID: 2A0CF73900DB7CE7E0F-513C
No Faults Found
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
VCID: 2A0CF73900DB7CE7E0F-5160
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120624
Coding: 0000104
VCID: 323CEF59280B342758F-5160
End----------(Elapsed Time: 04:23, VBatt start/end: 13.4V/13.6V)-----------
