Security access required
jaap
C?ID=57764
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: WVWZZZ3CZHE021497   License Plate: B8
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 52 5F 69 6C
VIN: WVWZZZ3CZHE021497   Mileage: 71906km-44680miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BT    HW: 04E 907 309 AB
   Component: R4 1.4l TFS   H23 9177
   Revision: R6H23---
   Coding: 0125007224741D083000
   Shop #: WSC 51389 001 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027BT 001011
   ROD: EV_ECM14TFS01104E906027BT.rod
   VCID: 77AA1F522F48F69FAF7-8022
   CAN Converter 01:
   Part No SW: 0CW 300 049 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0902
   Revision: 00005006    Serial number: CU501606085035
   Shop #: WSC 05311 115 00062
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4BC293A20340A27F3BF-801E
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61566000000864
   Coding: 0FEC6A8F3422136D477B060941CA49F0562CC8E2608292711822F078C20202
   Shop #: WSC 00015 115 08193
   VCID: 7BA203621360D2FFCBF-802E
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0407107756
   Coding: 002F0F0F0F
   Shop #: WSC 05311 115 00312
   VCID: 3B22C36253E012FF8BF-806E
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 12020004200100011015504E00101922
   ROD: EV_ACClimaBHBVW37X_006_VW48.rod
   VCID: 76B4125628428F97B41-8022
   Air quality sensor:
   Part No SW: 5Q0 937 086 BG    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865807061600ZT
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0058748E7A86B1279ED-8054
   Component: WWS    160512  042 0607
   Serial number:         160525193416
   Component: RLHS  042 0105
   Serial number: S2Y16M06D15H13M41S38
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 29 03 2016  10000059
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331616300001
   Coding: 0071151911
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 44D0B89E2E1E6D07FA5-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200670A51FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430E85E7EBEDD874A5-8060
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 21
                    Reset counter: 176
                    Mileage: 71792 km
                    Date: 2019.02.06
                    Time: 11:22:19
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 14.1 V
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPAWG4BS
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA40A760072C7D7EC1-802A
   Belt Pretensioner left:
   Serial number: 3G1857705G0161Q00316
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G1857706G0161Q01336
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 405 16
   Serial number: 3576U000000742695B1A
   Subsystem 4 - Part No SW: -----------    HW: 454 002 305 16
   Serial number: 3586U000000426695B1A
   Subsystem 5 - Part No SW: -----------    HW: 454 800 506 16
   Serial number: 3516R1A71980B0000003
   Subsystem 6 - Part No SW: -----------    HW: 454 800 506 16
   Serial number: 3526RBB63980B000000G
   Subsystem 7 - Part No SW: -----------    HW: 454 801 605 16
   Serial number: 3556VDAFC900A000000X
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF034034    Serial number: 20160525501240
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA0007E166ED5C7C25-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Fault Frequency: 60
                    Reset counter: 176
                    Time: 00:00:00
                    Ubat 30 Voltage: 11.80 V
                    Internal error state: 0
                    LIN_Temp: 0
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 245
                    Slope: 134
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 39.00 °C
                    p_t_soll_1: 43.00 °C
                    p_t_soll_2: 47.00 °C
   Part No SW: 3G0 920 750 B    HW: 3G0 920 750 B
   Component: KOMBI         303 8311
   Coding: 07A50A182780000801886B011000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 23121B02CB504A3FA3F-8076
1048578 - No Basic Setting
          B2010 00 [009] -  -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 130
                    Mileage: 71789 km
                    Date: 2019.02.04
                    Time: 15:43:12
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 06061610802962
   Coding: 030300347F085700FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013_VW48.rod
   Serial number: 29160001128830046231
   Coding: 2FFFFF
   Serial number: 75410803001605270410
   Analog clock:
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0101000400000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B8233226300427F5BF-803E
   Serial number: 16000120720004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE214A412CA8AF613-8024
   Serial number: 020616EEV13584
   Coding: 00350B20D000028000001000
   VCID: 43D2BB822B106A3FC3F-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003870046
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000853784
   Coding: 01000010005000
   Shop #: WSC 00015 115 00312
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D26CD7A4DF41CCFB5B-8068
   Serial number: 040616EF329398
   Coding: 00350120DE00028000001000
   VCID: 42DCBE86340A6337C89-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003866024
   Coding: 090000
   Part No SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
   Component: MU-S-N-ER     H30 0356
   Serial number: VWZAZ2S0314618
   Coding: 02840201FF0000005111000100080A001F01008401200100CF
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2F3AE7329798FE5F377-807A
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H34 8074
   Serial number: VWZ6ZDS2240005
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
          B201A 00 [009] -  -
          [Check software version management]
                    Reset counter: 130
                    Mileage: 71789 km
                    Date: 2019.02.04
                    Time: 15:42:39
                    Voltage terminal 30: 11.5 V
                    Status_Software_Version_Management-module_name: D
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0392593978
   Coding: 0100000202000000
   VCID: 3E24CA7640F207D7AC1-806A
136203 - Supply Voltage
          P1757 00 [008] - Open Circuit
                    Fault Frequency: 23
                    Reset counter: 176
                    Mileage: 71789 km
                    Date: 2019.02.04
                    Time: 16:16:37
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020163002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
End----(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Address 17: DTCs cleared
Address 5F: DTCs cleared
Hello I am Jaap from the Netherlands.
I had a HEX-USB+CAN interface for years.
But with my passat B8 i had a lot off faults with the autoscan.
So i got a new HEX-V2 interface and the faults are gone.
But now i have a other problem.
In central electrics i want to make a few changes but after 3 changes it is giving me security access required.
I have put the security code 31347 in for the first changes and that was accepted.
So i gave the code in again and it is telling it is accepted but when i make a change it wants the code again.
Can anyone help me with this problem?
The interface is registerd with Ross-Tech.
What changes are you trying to make? Some changes may need a different security code...
jaap
C?ID=57764
I want to make some changes so that the rear light are on together with the DRL lights.
Please post a complete Auto-Scan (not just the Gateway Installation List) so people can see exactly what control modules are installed in your car.
Dana
Western PA, USA
Thanks for adding the complete scan. I'm going to move this to the Teaks sub-forum so you receive more views.
Next, 31347 is the most common MQB BCM SA code and I'm not aware of any alternative codes specific to that 5Q0 937 086 BG module. Please post the IDE that is showing Error Security Access Required so we can look into this.
The complete Adaptation function control module map using SA 31347 would be extremely helpful if you don't mind posting it in this thread.
Internal ref to: FS#1357
hadez16
C?ID=289891
Sometimes the unit is picky regarding multiple changes that require a security access. Hard to explain. I experienced this quite often for instrument clusters...
It can help disconnecting from the unit and re-connect again with a new login
jaap
C?ID=57764
I tried it this week again and now i could do multiple changes without any problems.
