Audi A7 None start - J393 convenience module help needed
aaron carter
C?ID=231404
Hi all, I have an audi A7, that is dead. No start or authorisation is being given to the steering lock, I have found no power on row of the fuses, which is controlled by 15 terminal relay, the earth request is not being sent from the convenience module. I have bypassed to get dash lights back and the gearbox lever surround lighting is now functioning, but the car still will not start on a push start button and the electric steering lock will not deactivate and electric windows will not shut.
Can a second hand convenience module be programmed with VCDs or do i need a new unit?
Anyone got any other ideas?
Please see attached log.
Monday,04,February,2019,18:27:59:63423
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WAUZZZ4G5CN069926   License Plate: A7SKU
Mileage: 143042km-88882mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 15 16 17 19 30 3B 42 44 46 52 53 55 5F 62
          6D 72
VIN: WAUZZZ4G5CN069926   Mileage: 143042km-88882miles
03-ABS Brakes -- Status: Cannot be reached 0100
04-Steering Angle -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 G    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---
   Coding: 1A034012040401020800
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
   ROD: EV_ECM30TDI0114G0907311G.rod
   VCID: 271E27AD5E1AAB72BC-8072
5618 - Engine Off Timer Performance
          P150A 00 [096] - -
   Part No SW: 4G1 927 155 F    HW: 0AW 927 156 K
   Component: 0AW 30TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000248
   ASAM Dataset: EV_TCMVL381 A02428
   ROD: EV_TCMVL381.rod
   VCID: 2F2ECF8D76EAF33274-807A
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 07A18703E085E1C0DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 3424C0E19FCCD0EA09-8060
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01BA3000000000000000
   VCID: 76A03AE9C13082FAF7-8022
                    Fault Status: 00101101
                    Reset counter: 23
                    Mileage: 143042 km
                    Date: 2019.02.03
                    Time: 07:55:09
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 239
                    Mileage: 143042 km
                    Date: 2019.02.03
                    Time: 07:55:09
01128 - Immobilizer Pickup Coil (D2)
                    Reset counter: 239
                    Mileage: 143042 km
                    Date: 2019.02.03
                    Time: 00:03:17
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
   Component: KLIMA 2 ZONEN H10 0062
   Serial number: 19101100040289
   Coding: 3623000820
   ASAM Dataset: EV_AirCondiBasisUDS 002037
   VCID: 230633BD2A224752E0-8076
   Part No SW: 4H0 907 063 BE    HW: 4H0 907 063 E
   Component: BCM1 2.0      H12 0100
   Revision: 19012002    Serial number: 00000001251426
   Coding: 2600201040349FE00181008000001D0C0F9DC30A27090101000004602100
   VCID: 6C9418818F7C482A11-8038
   Component: WWS57X 110909  H35 0051
   Serial number:         110922024832
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11721414
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 12 10 2011  00000172
Address 15: Airbags
   Part No SW: 4H0 953 568 E    HW: 4H0 953 568 E
   Revision: --------    Serial number: 90372KJ7001VD
   Coding: 000030
   VCID: 3522FDE59CB6C9E23E-8060
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H09 0009
   Serial number: 29 08 2011  33123505
   Part No SW: 4G8 920 950 G    HW: 4G8 920 950 G
   Component: MDieGb        H34 0119
   Revision: 25450105    Serial number: 658131011593013
   Coding: 338600020B032600010100
   ASAM Dataset: EV_RBC7KMID 004040
   ROD: EV_RBC7KMID.rod
   VCID: 3326C3FD9AC2D7D210-8066
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000275800
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3228C6F965D8DEDA1B-8066
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650731333
   Voltage stabilizer:
   Serial number: 11292003077021200181
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000019853
   Coding: 01010101000000000001000203
   VCID: 648470A167AC006A59-8030
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200NK760
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6B961B9D82724F1218-803E
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0022174833
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0161122863
   Coding: 013B062220B9BC0083200A04000100000000000000000000000000000000
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA103392000000593175
Address 52: Door Elect, Pass.
   Revision: --------    Serial number: 00000000155673
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A18DE994D08961AA3-807E
Address 55: Headlight Range
   Part No SW: 4G0 035 193 C    HW: 4G0 035 193 C
   Component: RMC Cnct Nav  H51 0717
   Coding: 0101040001415947002B040301010000010001
   VCID: 230633BD22224752E0-8076
   Subsystem 1 - Part No: 8X0 919 884 C
   Component: P11-50-10.06  1006
   Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464HY0B0061757
   Subsystem 3 - Part No SW: 4G2 919 610     HW: 4G2 919 610
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KJC000G9
03405 - Bass Loudspeaker
                    Fault Status: 00101011
                    Reset counter: 24
                    Mileage: 143042 km
                    Date: 2019.01.31
                    Time: 13:18:07
                    Voltage: 11.80 V
Address 62: Door, Rear Left
   Part No SW: 4G8 959 107 N    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0039
   Revision: 11013001    Serial number: 271100362
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 40CC9C31DB747C4A9D-8014
Address 72: Door, Rear Right
End----(Elapsed Time: 01:20, VBatt start/end: 11.7V/11.7V. VIgn 0.1V)------
Since it has the Kessy module integrated in it, I would have to say: No, the only way to replace that module is on-line.
I could do a data transfer by mail of used or new modules but you are far away.
Take kessy apart and post pictures.
Overlay test the D2 for coil & transponder to kessy directly.
Dana
Western PA, USA
I'm posting here in response to the email. I absolutely agree with the above advice and a new (unused) BCM2 module (AW 05 and 46) would need to matched online dealer style if faulty but rebooting it and inspecting for internal problems can't hurt.
