Fog light delete audi B7
tdo4h
South Africa
C?ID=142887
Good day need to switch off fog light warning as i fitted DTM bumper.
Channel 16 gives error.
Saturday,19,January,2019,16:23:57:26592
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8E56A291919   License Plate: B7 FOGLIGHT
Mileage: 210100km-130550mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E56A291919   Mileage: 210100km-130550miles
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 AR    HW: 8E0 909 018 B
   Component: 1.8L R4/5VT     G   0020
   Coding: 0004501
   Shop #: WSC 00000 000 08192
   VCID: 0005A4BF5064E34ADD-5124
Readiness: 0010 1101
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H05 0120
   Coding: 0004871
   Shop #: WSC 06335 000 00000
   VCID: 2855DC1F9B94FB0AB5-807C
   Part No: 8E0 820 043 BQ
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 71E3F17B3BCEFAC222-5124
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 01001
   VCID: 3B7F135329024092C8-4B02
            30-00 - Open or Short to Plus
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M008AVTN
   Coding: 0034622
   VCID: 3B7F13537A024092C8-806E
   Subsystem 1 - Serial number: 6332DRB402434B8BQ
   Subsystem 2 - Serial number: 6342DRB402528B9BW
   Subsystem 3 - Serial number: 6352ARB400B82B71M
   Subsystem 4 - Serial number: 6362ARB400B674DC-
   Subsystem 5 - Serial number: 63729RB400C2A987V
   Subsystem 6 - Serial number: 63829RB400C2BB19U
01218 - Side Airbag Igniter; Passenger Side (N200)
                    Fault Status: 11100001
01579 - Signal for Seat Occupied Sensor; Front Passenger Side (G128)
                    Fault Status: 11101010
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02041
   Shop #: WSC 06335
   VCID: 418361BB4BEE2A4292-4AEA
01304 - Radio
            49-00 - No Communications
   Part No SW: 8E0 920 901 C    HW: 8E0 920 901 C
   Component: KOMBI+WFS 3     H12 0110
   Revision: 0110        Serial number: AUX6Z0E0119037
   Coding: 0007141
   Shop #: WSC 01333 996 89508
   VCID: 254BD52BEF86E6628E-5124
01039 - Coolant Temperature Sensor (G2)
            007 - Short to Ground
01304 - Radio
   Coding: 0007141
01304 - Radio
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6BDFE31319E2101218-5124
01463 - Alarm triggered by Sensor for anti-theft alarm System
            81-00 - Open
   Part No: 8E0 959 433 CA
   Component: Komfortgerát T3B    3332
   Coding: 07934
   Shop #: WSC 01333
   VCID: 72E1FE773EC8C1DADB-4B02
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
End-------------------------(Elapsed Time: 06:43)--------------------------
Westbury, UK
The bulb failure warning system on the B7 cannot be programmed, so the only solution is to fit suitable value (resistance AND power) resistors in place of the now missing fog light bulbs.
Hmm...
For front fogs, there's Adaptation Channel 16:
Fog Light Cold Diagnosis
0 = Fog Light Cold Lamp Diagnosis active
1 = Fog Light Cold Lamp Diagnosis inactive (i.e. for DTM Edition)
Provided he never turns them on (ideally by installing a switch that doesn't allow it), this might get him where he needs to be.
What error? Please elaborate.
Westbury, UK
Hmm...
Good point! I had forgotten about the special case of the front fog lamp diagnosis...:facepalm:
tdo4h
South Africa
C?ID=142887
Hmm...
If i select cent.elect, adaption it shows
Error: Channel16 Not Available
Scratching head. It's possible your CECM variant simply doesn't have that channel. How about other documented channels? Do they show?
oneplank
C?ID=6979
Since this thread appears to have never been resolved, and since I am facing the same problem, I thought I would resurrect it.
I am dealing with a B7 A4 (2005.5) that had front bumper cap replaced with an aftermarket bumper cap that has no provision for fog lights, so the original fog lights were removed. This of course results in the cold diagnostics indicating that both fog lights are burned out. When I open central electronics adaption I can find all the documented setting for the various channels which display their values except Channel 16. I get the same error when opening channel 16 as tdo4h: "not available." That is all it says, there is no value.
This is where is get puzzling to me: just going into central electronics temporarily clears the cold diagnostic check for the fog lights.
Any idea what is going on and how I can activate channel 16 to turn off the diagnostics?
If I were to change the coding to the rest of the world (1) or special vehicle (5) might that activate channel 16? The vehicle is equipped with xenon headlight and daytime running lamps.
oneplank
C?ID=6979
I am going to answer my own question. Since the DTM bumpers were not available in the USA, I thought that changing the coding from 01023 to 01021 (rest of world) or 01025 (special vehicles) would enable Channel 16. I can confirm that it does not.
Any Ideas how to enable channel 16?
Zagor
Italy
C?ID=96696
The problem can only be solved with Odis Engineering or with VCP by modifying 3 memory addresses in the BCM eeprom
oneplank
C?ID=6979
Zagor,
Thank you. Not the answer I was hoping I would read, but it is good to know that the CECM for Address 09 can be rewritten. I wonder why Uwe doesn't offer this function in VCDS? Probably because too many people would brick their vehicles if he did.
I am down to the last resort, fining the original wiring for the fog lights and splicing in a big 6 Ohm power resistor.
Westbury, UK
Exactly this...
  • Agree
Zagor
Italy
C?ID=96696
Even with VCDS it is possible a mistake coding the byte 18 of a BCM and brick the controller: an encoding is still a writing in the module's eeprom.
It would be correct to always know very well what to do, or ask someone who is able to do it
Westbury, UK
Only if you ignore the message that VCDS shows that changing byte 18 is a damgerous thing to do.
  • Agree
Zagor
Italy
C?ID=96696
Certain. It was just to say that vcds already has the potential to do damage. In reality, the damage would be done by the user, not the VCDS
Cuzoe
C?ID=279487
That is the case with basically every tool, electronic or otherwise. Doesn't mean the maker of the tool should not take precaution or make the tool safer to use, within reason of course.
Zagor
Italy
C?ID=96696
This is certain, just as it is certain that when a technological and high-potential tool is created (such as vcds) it is always very frustrating to limit its field of action
Cuzoe
C?ID=279487
I suppose in this instance you are using limit as a negative where (potentially, as I don't speak for the company and am in no way affiliated) the folks at Ross Tech and indirectly some customers (here I'm speaking for myself only) may consider this limit as a positive. There being a consideration for how many customers would use this additional feature in a knowledge/responsible way versus how many people may accidentally brick/break something.
Might be a headache for customer support, potentially very expensive problem for customer, which can quite easily reflect negatively, justly or unjustly, on the product.
Zagor
Italy
C?ID=96696
I'm looking at it from the point of view of the designer who creates the tool. Knowing that the tool you created could cut steel but, out of caution, only cuts iron, must not be pleasant, especially when the limit is only set due to the incompetence of some users. That's all
