Isolated Instrument Fault Code
gregmurphy79
Australia
C?ID=139018
Based on the VCDS scan below, can anyone assist in locating the fault and how to fix it?
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A401002380000800086A00040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
VCID: 6597B230B5EAF16F0D0-8031
10485826 - Internal Control Module Memory Check Sum Error
B2000 41 [009] - General checksum failure
[Steuergerät defekt (CRC Check ROM)]
Mileage: 92245 km
Date: 2017.08.18
Time: 13:33:00
Steuergerät defekt = Control Module Defective.
Has anyone been into this Instrument Cluster with sketchy Immo or "mileage correction" tools?
gregmurphy79
Australia
C?ID=139018
Hi Uwe, Not that I know of. The fault just appeared one day and Ive only ever used VCDS.
Is there a way to flash it?
gregmurphy79
Australia
C?ID=139018
Hi UWE... or anyone else with any further info,
If I replace the 5G0 920 860 instrument dash, does the mileage come from either the control unit or power unit: 5Q0937084M and 04E907309A... or is it stored and generated in the instrument dash?
My car is a VW Golf Mk7 2013.
Mileage is stored in the instrument cluster and if you're installing a used one, cannot be changed with VCDS (or the dealers' tool for that matter).
