2014 VW Touareg TPMS reset question
Dubbin’
Canada
C?ID=301509
Hey guys,
New here, hopefully someone can help! Searched online for days with no answers ...
I have a 2014 Touareg, Using my VCDS I want to have my car scan for TPMS sensors. I currently have a fault code saying the system was deactivated since I installed tires without TPMS sensors (winter wheels). Instead of having to drive the car. I want to reset the system?
How to???
Thanks,
Mark
How and by whom was it de-activated?
I just looked at the data for a 2015 Touareg TPMS, which I assume is practically the the same as yours. I do not see any way to force it to scan for sensors.
I'm still curious how it was "deactivated" though. So please post an Auto-Scan for context.
darkchina811
ITALY
C?ID=333184
when I retrofitted the active system, I was wondering how I was gonna pair the sensors to the TPMS ECU, because there is no explicit command to do that. I found out that the ECU learned the sensors automatically after I drove the car a little bit.
I had bought the ECU used, so it was originally paired to other sensors.
I assume it just scans and sees if sensors are in range, and it pairs to the strongest signal, which would mean the closest four. go figure.
long story short, just try driving.
RyMar
South Africa
C?ID=133909
I far as my knowledge is, In South Africa Touareq TPMS work through ABS contr module and there is no way one can alter/program different pressures.
I am skeptical. Have you got a scan from one that works like that?
Dubbin’
Canada
C?ID=301509
The TPMS system deactivates
Itself when it doesn’t detect any sensors present ... (winter wheels have no TPMS sensors.
I was hoping I could wake up the system using my VCDS. I guess not ;(.
Thanks,
Mark
RyMar
South Africa
C?ID=133909
Scan: Wanted to adjust TPMS shown in instrument cluster/radio but no functions available.
Thursday,22,November,2018,15:15:53:48706
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WVGZZZ7PZED046597   License Plate: DCH031L
Mileage: 122287km-75985mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 34 36 42 46 52 53 55 56
          5F 62 65 69 6C 6D 72
VIN: WVGZZZ7PZED046597   Mileage: 122287km-75985miles
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 7P1 907 401 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---
   Coding: 292A4012233E01020000
   Shop #: WSC 01753 996 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
   ROD: EV_ECM30TDI0117P1907401D.rod
   VCID: 312AF029609718C26A-8064
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 28742 001 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7CB4111DF75525AA89-8028
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 404240010EC815
   Coding: 5B6B13C30B282559DAF9C89CD0D9A450F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4AD887C5ED014B1A4B-801E
   Part No SW: 4H0 907 064 EM    HW: 4H0 907 064 EM
   Component: BCM2 2.0      H36 0521
   Coding: 01B60010000000000000
   VCID: 78BC0D0DCB6D098AED-802C
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0514000051769009
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0214000081006012
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: 36A6200A90
   VCID: 054274F9849F6462E6-8050
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001740004
   Coding: 26001010D1345D010021000300005D0C431D670807010241000000020000
   VCID: 6C94215D8F35B52A19-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140422  033 0021
   Serial number: 90243401140429215255
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20307858
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002904140357
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   VCID: 23060A61226BBA52E8-8076
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231412301050
   Coding: 318501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43C6AAE1CA2B9A5288-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag06D H06 0026
   Revision: --------    Serial number: 003L5005CTE3
   Coding: 000000000000000000000000000000003644
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42C8AFE5D531935A83-8016
   Serial number: 3575LRB40552E3MI39LD
   Serial number: 3585LRB40572E3MI6OR/
   Serial number: 3515RRB400O52JN2J0FK
   Serial number: 3525RRB400S52JN2OI1Y
   Serial number: 3555NRB400250V9SA242
   Serial number: 3565NRB400E50V9SFOD8
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NE1000S1
   Coding: 000C35
   VCID: 383CCD0D8BEDC98A2D-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0045905 TRW 20140402
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658080514592027
   Coding: 333733003B00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47DEBEF1FE13B67254-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001374592
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FCEA611A6C3FEB2EC-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 31114N33345701138474
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 14120003127011200181
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000141140089
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 76A00335C9797FFAFF-8022
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000099030547
   Coding: 0078130000004001000001010101202020202121202020
   VCID: 3424F93D97852DEA01-8060
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000100967564
   Coding: 011D0620DE01451005080002
   VCID: 7AB81705F5611B9A9B-802E
   Revision: 00002001    Serial number: 0333874429
   Coding: 019A162228B9108080200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000100984247
   Coding: 011D0620DE01451005080000
   VCID: 48DCBDCDFB0DB90A5D-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1450200505
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3620C33589F93FFA3F-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: 130000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227EV0E8002348
   Coding: 060005020100000003
   VCID: 2600137551594F7A8F-8072
   Part No SW: 7P6 035 764 E    HW: 7P6 035 764 A
   Component: H-BNT-RW      H40 0816
   Revision: --------    Serial number: 445D-0E7501268
   Coding: 010901050040E1EF41002B0E00000003F00001030000000000
   VCID: 3B36D201BADBE292C0-806E
   Subsystem 1 - Part No: 8R0 060 884 BN
   Component: ROW 2014  0605
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9PA2014VT
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  5571
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000101610730
   Coding: 011806200001251005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000133952
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 J    HW: 7P0 907 383 C
   Component: Anhaenger     H11 0130
   Revision: 5H001001    Serial number: 00008200334952
   Coding: 0106040000000000
   VCID: 3FCEA611AEC3FEB2EC-806A
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J441430
   Coding: 0030001
   VCID: 373ECE3146F3C6F224-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 114400584
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000101713126
End----------(Elapsed Time: 02:11,
Hmm, this one is different than the similar one I looked at yesterday. It has this Basic Setting:
IDE03536-ENG100805 Tire pressure sensor communication check - SchneltriggermodeStart
That looks relatively promising.
FWIW, the one I looked at yesterday was from an NAR 2015 model. I wonder if the difference, specifically the "Self De-activating" is due to the TPMS being a regulatory requirement here and not there?
