Mk7 Golf Fault Code
Dave Witchdoktor
C?ID=350089
HI
Im awaiting for my cable to arrive (tomorrow) and will be verified then.
The other day i was swapping the infotainment out for my Pioneer unit with the connect2 infoadapter, everything was going to plan until the epb warning light came on.
I forgot to connect the park cable (green) to the pioneer unit.
I have the fault code :-
32837 - Lamp in Switch for Electronic Parking Brake
C1145 13 [009] - Open Circuit
Have I blown the lamp in the parking brake switch? I connected the 2 cables together after the warning light came on.
Do I need to get a new switch or can i get a replacement lamp, will i need to disconnect the battery first before i do this work?
Is this the correct diagnosis?
Thanks in advance
Dave
darkchina811
ITALY
C?ID=333184
and disconnect the battery! take it as a good habit when you perform any kind of electrical installation/repair.
Dave Witchdoktor
C?ID=350089
So my cable has arrived and here is the auto scan as requested
  Friday,11,January,2019,14:52:05:13806
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: WVWZZZAUZFW090998   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZFW090998   Mileage: 112887km-70144miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 01190012034505082000
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8371F4E1A5FAF1-8022
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62134000000140
   Coding: 01FA8AA13429096C0380060941CB2980512C90C0608294F5F4605078C009
   VCID: 074B98F76FAE6ADFDF1-8052
          C1145 13 [137] - Open Circuit
                    Reset counter: 138
                    Mileage: 112647 km
                    Date: 2019.01.07
                    Time: 15:47:00
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00120114202100011005000000101000
   VCID: 73B3DC270B36767F939-8026
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [009] -  -
          [PTC-Reduzierung durch BCM]
                    Fault Frequency: 50
                    Reset counter: 139
                    Mileage: 110633 km
                    Date: 2018.10.30
                    Time: 17:27:42
                    Voltage terminal 30: 14.0 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 149
                    Reset counter: 179
                    Mileage: 110633 km
                    Date: 2018.10.16
                    Time: 11:21:04
                    Voltage terminal 30: 13.6 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
459025 - Databus
          [Radio - kein Signal/Kommunikation]
                    Reset counter: 174
                    Mileage: 112647 km
                    Date: 2019.01.07
                    Time: 15:42:35
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011421804296
   Coding: 03100A46C24122FB0BA44080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005983EB4A805DE79EB-8054
   Component: WWS    140724  042 0551
   Serial number:         140728105227
   Component: RLHS  037 0059
   Serial number: S4Y14M08D18H02M34S13
   Coding: 00A8DD
   Serial number: 000000000ZY1420200U3
   Serial number: 00000000000060218428
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO31547633
   Coding: 181901
          B1263 01 [009] - Electrical Failure
                    Fault Frequency: 84
                    Reset counter: 116
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Reset counter: 178
                    Mileage: 112878 km
                    Date: 2019.01.09
                    Time: 16:35:16
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 178
                    Mileage: 112878 km
                    Date: 2019.01.09
                    Time: 16:35:16
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331420904094
   Coding: 0071051001
   VCID: 3D273A1F7DF2F00FB5D-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 11081477030458
   Coding: 00000300FE0739
   VCID: 38292B0B52D0D52766B-806C
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR07UDSM
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5B0017377E221FE71-802A
   Belt Pretensioner left:
   Serial number: 34169677B18081470610
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B14081441038
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 35767000000E5931A01S
   Subsystem 4 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 35867000000A4C7C901+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3516502BB16DB81391BM
   Subsystem 6 - Part No SW: -----------    HW: 480 401 208 14
   Serial number: 35265029D16FC225A35K
   Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3556502B916DB811D13I
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 12081404220638
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BA3F40723663E3FCB9-802E
   Part No SW: 5G1 920 957     HW: 5G1 920 957
   Component: KOMBI         301 4270
   Coding: 27AD09002F80260001886A011400000000000000
   VCID: 6D87CA5F6D12A08F45D-8038
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002351792
   Coding: 030100040B087300EF00027E080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 42DD49E3040C8FF7C8F-8016
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 27140001959420024324
   Coding: 2CFFFF
   Serial number: 8808324003
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 174
                    Mileage: 112647 km
                    Date: 2019.01.07
                    Time: 15:42:30
                    Supply voltage: Terminal 30: 11.2 V
                    Terminal 15: On
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 177
                    Mileage: 112861 km
                    Date: 2019.01.08
                    Time: 18:38:02
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
8526355 - Voltage Drop in Generator Leads too large
          P30DE 00 [008] - -
                    Fault Frequency: 57
                    Reset counter: 177
                    Mileage: 111317 km
                    Date: 2018.12.13
                    Time: 19:10:34
                    Supply voltage: Terminal 30: 13.6 V
                    Terminal 15: On
   Serial number: 30071401101297
   Coding: 003F0220D001048000001000
   VCID: 40D943EB0A009DE7DEB-8014
   Serial number: 00000000000003469395
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3537223F45C2284F7DD-8060
   Serial number: 30071406070075
   Coding: 003F0020DE01048000801000
   VCID: 3FDB401777FEE21FA71-806A
   Serial number: 00000000000003506153
   Coding: 050000
   Coding: 029E01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    041 0430
   Serial number: V7F00908142447
   Coding: 02730001FF00000021111201000800001F0202060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 678BB8774FEE8ADF3F1-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS402W7Y
   Subsystem 2 - Part No SW: 5G0 919 866 AG    HW: -----------
   Component:  ECE 2018  --- 0072
   Component: SAS-GEN 2     H06 0014
   Serial number: 140716200280
   VCID: 6B83C4475306AEBF5B9-803E
End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.2V)-----------
Hmm... Are you quite certain that everything is connected properly now?
darkchina811
ITALY
C?ID=333184
module 5F is still there and happy so what about the Pioneer?
Dave Witchdoktor
C?ID=350089
The Pioneer will be installed another time, im not getting the driver information on the head unit through the infoadapter, im awaiting a call back from connect2 tech support.
The other issues i have is with the HVAC, the passenger side vents are fine and blow hot from the heater but the two vents, right hand side of centre console and the vent to the right
of the steering wheel blow cold,
B10CD 00 [009] - -
P1719 00 [008] - -
459025 - Databus
How do i decipher this into a faulty component?
Over the weekend i will dl the repair manuals from erwin but any guidance would be appreciated
B10CD 00 [009] - -
P1719 00 [008] - -
459025 - Databus
None of these are directly indicative of a fault component.
