2005 VW Transporter - 2.5Tdi PD
DGMotors
C?ID=57532
Hi
We have a VW Transporter with an uneven tickover when warm I've been checking all the readings and the KW reading in MVB 04.4 seem very low at -4.9
Has anyone got an acceptable range for this please?
Cheers
Toby
;SW:070-906-016-BA   HW:028-101-166-4 ---  Engine
;Component:R5 2	5L EDC G000SG  7001	 Coding:0000132
;Thursday	3	January	2019	16:09:13:06091
;VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
;VCID: D0EC264142F478CA86-5184
Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4
1	819 /min		4.9 mg/str		7.1°KW		86.4°C
2	798 /min		0.00%		 0 01  0		86.4°C
3	777 /min		245.0 mg/str		240.0 mg/str		43.00%
4	777 /min		5.0 °BTDC		7.7°KW		-4.9°KW
5	798 /min		20.6 mg/str		48		86.4°C
6	0.0 km/h		1000		0.00%		10
7	66.6°C		 		22.5°C		87.3°C
8	819 /min		0.0 Nm		187.9 Nm		126.9 Nm
9	798 /min		-1280.0 Nm		500.2 Nm		126.9 Nm
10	240.0 mg/str		1030.2 mbar		1030.2 mbar		0.00%
11	777 /min		1020.0 mbar		1030.2 mbar		80.50%
12	11111111		0.00 s		14.52 V		87.3°C
13	0.16 mg/str		0.47 mg/str		0.05 mg/str		0.00 mg/str
14	-0.71 mg/str
15	819 /min		36.6 Nm		0.60 l/h		0.0 Nm
16	35.70%		 		 		14.59 V
17	0		0		0		0
18	0		0		0		0
19	0
20	777 /min		51.2 Nm		1270.0 Nm		-1280.0 Nm
21	0		 		0		100
22	1		1		0		16
23	-28		-23		-45		-23
24	-57
25	1848 /min		 		4		0
26	E27E
27	1		 		0.0 km/h		190.0 km/h
28	0.304 V		 		 0 01  0		0.00%
29	88.2°C		44.0 mm
51	819 /min		399 /min		48		1010000
55	0		0		100000		100000
56	100000		100000		100000		0xFF00
62	86.4°C		35.1°C		4.5°C		23.4°C
64	86.4°C		35.1°C		10.10%
80	BPG-810 31.01.05 12345678 1883 0106
81	WV1ZZZ7HZ5H078895 VWZ7Z0E1560290 1234567
82	0020078502756 <> 78  020L 79   <>
125	 		ABS 1		Instruments 1		Airbag 1
126	 		 		Cent. Elect. 1
131	16		5.2 mg/str		 		86.4°C
133	798 /min		235.0 mg/str		1030.2 mbar		0
134	35.70%		14.52 V
140	-0.56 mg/str
145	0
150	-51
213	798 /min		0.00%		0.0 km/h		0
225	0		0		0		0
226	0		 		0		0
227	0		0		0		0
228	0		0
229	 		 		0		0
252	 		 		Cent. Elect. 1
Larry Manton
C?ID=112505
TOBY, THINK FOLKS WILL WANT A. FULL SCAN HERE FOR EVALUATION, THANKS.
LARIMORE
DGMotors
C?ID=57532
Here is the autoscan
Tuesday,11,December,2018,09:30:55:06091
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: DG Motor Services
VIN: WV1ZZZ7HZ5H078895   License Plate:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ5H07****   Mileage: 189270km-117606miles
Address 01: Engine        Labels: 070-906-016-AXD.clb
   Part No SW: 070 906 016 BA    HW: 028 101 166 4
   Component: R5 2,5L EDC G000SG  7001
   Revision: 12345678    Serial number: VWZ7Z0E1560290
   Coding: 0000132
   Shop #: WSC 02756 785 00200
   VCID: D0EC264142F478CA85-5184
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS-A.lbl
   Part No: 7H0 907 379 B
   Component: ABS/EDS ALLRAD MK25 0102
   Coding: 0007706
   VCID: B4244AD1D62C24EA81-513C
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 K
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000229
   VCID: BA3864E9F448D29A5B-513C
00909 - Windshield Wiper Motor (V) Stage 1/2
00991 - Interior Lights
00968 - Right Turn Signals
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0008
   Coding: 13122
   Shop #: WSC 02756
   VCID: A208BC892CD8BA5A63-513C
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 850 G
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 01412
   VCID: AE1058B968000E3AF7-513C
   WV1ZZZ7HZ5H078***     VWZ7Z0E1560290
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02756
   VCID: F0AC86C1B2B458CAA5-513C
   Part No: 7H0 907 554 A
   Component: HALDEX 4Motion      0105
   Coding: 0000001
   Shop #: WSC 02771 785 00200
   VCID: AE1058B938000E3AF7-513C
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C2B Komfortgerát     0004
   Coding: 00069
   Shop #: WSC 02756
   VCID: B2284CC97C382ADA93-4B1E
   Subsystem 1 - Part No: 7H2959802
   Component: Tõrsteuer.FS KLO 0203
   Subsystem 2 - Part No: 7H2959801
   Component: Tõrsteuer.BF KLO 0203
End----(Elapsed Time: 06:05, VBatt start/end: 12.0V/10.6V. VIgn 10.9V)-----
Larry Manton
C?ID=112505
Dgmotors, noted ending battery voltage 10,6 , started at 12 after 6 minutes. DID it drop this far while obtain auto scan? Would like to see how well it rebounded once started.
This issue happens when warm, wondering if charging system just keeping up while running. What is the condition of battery?, age, conditions of post ECT.
LARIMORE
DGMotors
C?ID=57532
LARIMORE
Cheers Larry
The autoscan was done with the engine off and the battery has been replaced as the autoscan was 11 December. in the logs you can see the voltage is 14.52 volts with the engine running.
Guitarman
C?ID=56603
Have a good look at the injector loom. Running in the hot oil they can fracture (often when the engine is warm). I have the 174 HP version of that van, I could see what mine shows tomorrow if you are stuck. There is no engine label file for my AXE engine though. :(
DGMotors
C?ID=57532
Good shout on the injector loom.
If you could please check your reading that would be good, I know on the 1.9 PD the KW should be as close to 0 and if to far out from this figure causes idle problems.
On this van it starts at -3.9 when cold and works it way to -4.9 with a hot engine (86c)
Guitarman
C?ID=56603
Had a look at mine (don't know how to log that many groups together as you have) but in group 4, fields 3 and 4 are marked 'Idle stabilization'. Field 3 changes about slightly on revving but is at 7.1kw at idle. Field 4 changes just after starting for about half a second but then settles at -3.4 and will not change on revving. This was with a warm engine. There are other 'Idle Stabilization blocks' in other groups but curiously only four for the five cylinders the van has.
I thought the idle stabilization system was there to add/subtract fuel from each cylinder to smooth out variations caused by engine wear over time but I've never seen it shown in KW before and with such a range. I wonder if fields 3 and 4 refer to something else?
I did once have an idle speed problem on mine but it was more like a sudden electrical load being applied, slowing the engine occasionally rather than a misfire or an injector problem. Do you know if it's had a cam btw? Once they get past about 100-120k most are on borrowed time!
I just remembered I took this screenshot.
DGMotors
C?ID=57532
Cheers Guitarman
To make a controller channel map see this link just use 01 for engine and output as a .csv file
On the 1.9/2.0 PD this figure is changed by altering the camshaft in relation to the crankshaft, click this link to myturbodiesel.com for more info
Ive had quite a few 4 cylinder pd run bad on idle when the figure is to far out, 0 +or-3 but 2.5PD engine all seem to run quite a high negative value,
Problem van is -4.9
Guitarman -3.4
2005 AXD Van with 60K on the clock -2.9
So I'm guessing -2 to-4 is correct with the problem van being slightly out
Might pop the rocker cover off and have a look when it comes back in.
Guitarman
C?ID=56603
Interesting. I knew you could use the channel map function for making a pre-label file to send up to Ross-Tech but I didn't realize you could use it 'live' like that. I'll make a map of mine. :thumbs: I wonder why the that figure on mine is frozen once the engine is running?
If there was a reliable figure for that perhaps it could be used to confirm correct setting up of a new cam. The special tools should do that but a lot of folks seem to manage to muck it up!
Guitarman
C?ID=56603
Here's the map if anyone else needs it. It's from an '04 Transporter 2.5 5cyl AXE engine.
;SW:070-997-016-D   HW:028-101-073-3 ---  Engine
;Component:R5 2,5L EDC G000SG  7596, Coding:0001072
;Friday,18,January,2019,16:04:32:20365
;VCID: 1B3123CAD9EA4D9220-515A
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,798 /min,RPM,7.1 mg/str,Inj. Quantity,7.1°KW,Idle Stabilization,79.2°C,Temperature,
2,798 /min,RPM,0.0 %,Load, 0 01  0,Bin. Bits,79.2°C,Temperature,
3,798 /min,RPM,235.0 mg/str,Mass Air / Rev.,235.0 mg/str,Mass Air / Rev.,41.0 %,Duty Cycle,
4,798 /min,RPM,7.1 °BTDC,Ign. Timing,7.1°KW,Idle Stabilization,-3.4°KW,Idle Stabilization,
5,798 /min,RPM,12.4 mg/str,Inj. Quantity,48.0,(no units),79.2°C,Temperature,
6,0.0 km/h,Speed,00001100,Bin. Bits,0.0 %,Load,00000010,Bin. Bits,
7,59.4°C,Temperature,0.0 %,Load,19.8°C,Temperature,79.2°C,Temperature,
8,798 /min,RPM,-2.4 Nm,Torque,234.2 Nm,Torque,156.2 Nm,Torque,
9,798 /min,RPM,-1280.0 Nm,Torque,500.2 Nm,Torque,156.2 Nm,Torque,
10,240.0 mg/str,Mass Air / Rev.,999.6 mbar,Absolute Pres.,989.4 mbar,Absolute Pres.,0.0 %,Load,
11,798 /min,RPM,1009.8 mbar,Absolute Pres.,989.4 mbar,Absolute Pres.,78.9 %,Duty Cycle,
12,11111111,Bin. Bits,0.00 s,Time,14.14 V,Voltage,79.2°C,Temperature,
13,0.07 mg/str,Inj. Quantity,-0.71 mg/str,Inj. Quantity,0.54 mg/str,Inj. Quantity,-0.09 mg/str,Inj. Quantity,
14,0.16 mg/str,Inj. Quantity, , , , , , ,
15,798 /min,RPM,70.8 Nm,Torque,1.00 l/h,Fuel Consump.,-2.4 Nm,Torque,
16,38.0 %,Load, , , , ,14.06 V,Voltage,
17,00000000,Bin. Bits,01000100,Bin. Bits,10000000,Bin. Bits,10000000,Bin. Bits,
18,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
19,0.0,(no units), , , , , , ,
20,798 /min,RPM,68.3 Nm,Torque,1270.0 Nm,Torque,-1280.0 Nm,Torque,
21,00000000,Bin. Bits, , ,00000000,Bin. Bits,00000100,Bin. Bits,
22,1.0,(no units),1.0,(no units),0.0,(no units),16.0,(no units),
23,-65.0,(no units),-58.0,(no units),-49.0,(no units),-66.0,(no units),
24,-58.0,(no units), , , , , , ,
25,798 /min,RPM, , ,4.0,(no units),0.0,(no units),
26,C5C6,RPM,
27,1.0,(no units), , ,0.0 km/h,Speed,190.0 km/h,Speed,
29,79.2°C,Temperature, , , , , , ,
51,798 /min,RPM,399 /min,RPM,48.0,(no units),01010000,Bin. Bits,
55,0.0,(no units),0.0,(no units),00100000,Bin. Bits,00000000,Bin. Bits,
56,00100000,Bin. Bits,00100000,Bin. Bits,00000000,Bin. Bits,0xFF00,Hex Value,
60,798 /min,RPM,65.9 Nm,Torque,79.2°C,Temperature, , ,
johne
Southampton, UK
C?ID=380307
HI All, where do i find a following button ??
Westbury, UK
What is a "following button"?
I *think* he means how can I "follow" a thread i.e. get sent email notifications when there are new posts in a thread?
Ah. In that case, it will be toward the top of the page, Thread Tools -> Subscribe to this Thread.
