1998 A6 2.5tdi won't rev beyond 3000rpm
Wooks
Pirate
Walking the Plank
HC800001 (Clone!)
Hi Guys,
So far I've replaced the air filter, MAF sensor, fuel filter and MAP sensor.
Apart from starting better the problem is still there.
I have the full version of VCDS but no experience of using it.
Could someone please advise me which channels to log etc to identify the cause.
Thanks for any advice
Andy
hmeco_
C?ID=260276
when you open your VCDS and its registered, on first window there is a auto-scan function, hit it!
once its complete save it and paste the unmodified content in code brackets, if you don´t know how to do so, please read this guide here: How-to-post-an-Auto-Scan
once auto-scan is posted it is a lot easier to track down what issues you have stored in your car, and there fore easier to solve them.
- hmeco
Wooks
Pirate
Walking the Plank
HC800001 (Clone!)
Will do, scanned for fault codes and 00575 showed up.
Still there after replacing MAP sensor.
Wooks
Pirate
Walking the Plank
HC800001 (Clone!)
Thanks for the link but I had read the description.
Problem is how do I test components that would cause the error.
Just off out to do a full scan as requested so will post the results soon.
Wooks
Pirate
Walking the Plank
HC800001 (Clone!)
Full scan as requested.
Removed.  Data from a clone/pirated copy of VCDS is not welcome here.
Wooks
Pirate
Walking the Plank
HC800001 (Clone!)
What are you talking about I bought this on amazon.co.uk
Then I suggest you file a complaint and return it to them. Let Trading Standards know too.
Uwe is the owner of Ross-Tech which develops VCDS, so if he says you have a pirate copy then you have pirate copy - no ifs, no buts, no maybes :facepalm:
