Operate VW Beetle Flaps with VCDS?
Spartan2381
C?ID=345716
Does VCDS have the ability to operate/test the flaps on a 2006 VW Beetle without actually operating the top?
The question would be better phrased: Does the roof module have a provision in it for that to be done using a scan-tool?
Can you post a scan from this car you can post so we can see what module it has and what we know about it?
Spartan2381
C?ID=345716
Attached is the output from when I first scanned the car.
Tuesday,28,August,2018,15:02:55:63037
VIN: 3VWSF31Y06M324226   License Plate:
Mileage: 176680km-109783mi   Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
VIN: 3VWSF31Y06M324226   Mileage: 176680km-109783miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 B    HW: Hardware No
   Component: R5              G   7828
   Revision: --------    Serial number: VWZ5Z0F2298336
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 2809FBFC2EEC7897194-513C
Readiness: 0110 1101
   Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
   Component: AQ 250 6F           0759
   Revision: 00H27000    Serial number:
   Coding: 0000008
   VCID: 78A9EBBCBECC2817494-513C
17105 - Transmission Output Speed Sensor (G195)
            P0721 - 008 - Implausible Signal - Intermittent
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 38292BBCFE4CE817894-5160
   Part No: 6Q0 909 605 AL
   Component: 01 AIRBAG VW71      0811
   Coding: 0012337
   VCID: 015F8658ED1669DF7EA-513C
   Subsystem 1 - Part No: 1C0 959 339 F
   Component: BF-Gewichtsens. 006 0007
   Part No: 1C0 920 501 T
   Component: KOMBI+WEGFAHRS. M73 V01
   Coding: 11234
   Shop #: WSC 00066
   VCID: 290FFEF830E6419F06A-4B00
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V012
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D39CD3BC7057814-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 501 T    HW: 1C0 920 501 T
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0F2298336
   VCID: 290FFEF835E6419F06A-513C
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255 C
   Component:  VSG  NBC       ¤
   VCID: 40D9435CA69CA0D7314-513C
00532 - Supply Voltage B+
Address 46: Central Conv.        Labels:
   VCID: 55F782084C0E357F722-FFFE
   Part No: 1C0 035 196 BG
   Component:  RADIO DE2         0006
   Coding: 06031
   Shop #: WSC 00066
   VCID: 6597B2C81C7EA5FFE22-51CE
            00-10 -  -  - Intermittent
End----------(Elapsed Time: 04:15, VBatt start/end: 14.0V/13.9V)-----------
Doesn't look promising. I see nothing that indicates this module supports Selective Output Tests, which would be the most probable way.
But some of the folks know these roof systems better than I do....
Jef
HQ
I'm not aware of any output test support for this Roof Electronics.
Just what issue are you having with the top other than some voltage issue. Does the Comfort Control Module, address 46, communicate? It isn't there in the Auto-Scan and it needs to talk for the top to operate.
Spartan2381
C?ID=345716
I thought that might be the case with the roof electronics.
The battery is shot and needs to be replaced so I'm pretty sure that's what's causing the low voltage. I was asking about the roof since it wont operate and was seeing if there was a way to test. I'm going to see if I can locate a diagram that shows the location of the fuse for the roof electronics. Unfortunately fuse location card is no longer with the car.
