Help needed to a R32 swap
Hummel
Pirate
Walking the Plank
Hi Guys
I need a bit of help with my build. I'm building a Golf mk1 with a R32 engine from a Golf mk5. The engine is from a car with DSG but i'm running manual, so I tried to code the ECU in VCDS to a manual gearbox, but it keeps telling me "Out of Range" ? Do any of you know if it is possible to code a ECU from DSG to manual ?
The engine is currently running fine in the car, but only in Idle, there is no respons when i hit the throttle, the pedal is brand new but maybe the ECU needs a pedal from a specific DSG car ? :confused:
I know you guys needs an Autoscan, but thats is really not possible, since I dont have a working Can-Bus system in the car, I only connect Via K-line. But here are a scan of the fault I'm currently working with, I hope all of them can be coded out of the ECU, but i'm not sure..
Any input is appriciated.
Removed.   Data from a clone/pirate copy of VCDS is not welcome here.
