Failed to start DPF Regeneration / audi S8 / 4.2 TDI
krisv
Poland
C?ID=326234
Hi guys,
Im trying to force the ECU to start the DPF Regeneration,
Ive tried it with the security code 12233 and 27971, but without any success.|
Below the Error msg:
Monday,29,October,2018,15:21:53:00332
VCDS Version: Release 18.9.0 Running on Windows XP x86
                Address 01: Engine       Labels: None
Control Module Part Number: 4H0 907 409 K    HW: 4H0 907 409 K
  Component and/or Version: 4.2TDI EDC17  H10 0003
           Software Coding: 0A2A4032056601030800
            Work Shop Code: WSC 77777 777 00000
              ASAM Dataset: EV_ECM42TDI1114H0907409K 001010 (AU64)
                       ROD: EV_ECM42TDI1114H0907409K.rod
                      VCID: 3424F0AC9F3A23EA01-8060
5188 - Diesel Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 57497 km
                    Date: 2018.10.27
                    Time: 12:13:20
                    Engine speed: 1576.00 /min
                    Normed load value: 76.1 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.760 V
                    Particle filter: soot mass measured: 11.65 g
                    Particle filter: kilometers since last regeneration: 1268516 m
                    Exhaust gas jet volume in particle filter: 173.5 m³/h
                    Exh.gas temp.sen 3: 349.2 °C
5453 - Starter Relay
          P3088 00 [096] - Electrical Malfunction
5177 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [032] - Open Circuit
                    Mileage: 57255 km
                    Date: 2018.10.19
                    Time: 15:16:52
                    Engine speed: 0.00 /min
                    Coolant temperature: 31 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 10.720 V
                    Unlearning counter according OBD: 33
                    Engine status: COENG_READY
25780 - Catalyst System; Bank 2
          P0430 00 [237] - Efficiency Below Threshold
                    Mileage: 55490 km
                    Date: 2018.09.27
                    Time: 02:23:50
                    Engine speed: 1812.50 /min
                    Normed load value: 81.2 %
                    Vehicle speed: 146 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.680 V
                    Shut-off timer: last engine shut-off time: 37233 s
                    Exhaust temperature sensor 1: bank 2: 527.6 °C
                    Exhaust temperature sensor 3: bank 2: 412.5 °C
                    Exhaust temperature sensor 4: bank 2: 586.4 °C
                    Outside air temperature: 13.0 °C
5189 - Particulate Trap Bank 1
          P2002 00 [047] - Efficiency Below Threshold
                    Mileage: 57497 km
                    Date: 2018.10.27
                    Time: 12:13:20
                    Particle filter: soot mass calculated: 24.90 g
                    Particle filter bank 2: soot mass calculated: 20.52 g
                    Particul.filter diff.pressure: 69 hPa
Readiness: 1 2 0 0 0
Monday,29,October,2018,16:18:17:00332
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
VIN: WAUZZZ4H8EN016262   License Plate:
                Address 01: Engine  (4H0 907 409 K)
16:18:10
  IDE00433   Particle filter: oil ash volume 0.01 l
  IDE00434   Particle filter: soot mass calculated 26.89 g
  IDE00435   Particle filter: soot mass measured 17.88 g
  IDE00436   Particle filter: kilometers since last regeneration 1420186 m
Can you please help me out with this S8, thanks in advance for any help.
krisv
Poland
C?ID=326234
Monday,29,October,2018,17:52:32:00332
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 22 28 30
          34 36 3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 69 6C 6D
          6F 72 7F 81 82 84 85 88 89 8A 8B 8D 8E 8F 90 AC
VIN: WAUZZZ4H8EN016262   Mileage: 57681km-35841miles
48-Seat, Rear, DS -- Status: Malfunction 0010
5B-Seat,Rear,PS -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTEC)       Labels: None
   Part No SW: 4H0 907 409 K    HW: 4H0 907 409 K
   Component: 4.2TDI EDC17  H10 0003
   Revision: 5AH10---
   Shop #: WSC 77777 777 00000
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 57681 km
                    Date: 2018.10.29
                    Time: 17:44:46
                    Engine speed: 748.00 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.160 V
                    Particle filter: soot mass measured: 7.42 g
                    Particle filter: kilometers since last regeneration: 32339 m
                    Exhaust gas jet volume in particle filter: 61.5 m³/h
                    Exh.gas temp.sen 3: 169.1 °C
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 57681 km
                    Date: 2018.10.29
                    Time: 17:44:46
                    Particle filter: soot mass calculated: 25.14 g
                    Particle filter bank 2: soot mass calculated: 25.14 g
                    Particul.filter diff.pressure: 14 hPa
   Part No SW: 4H1 927 158 CM    HW: 0BL 927 156 J
   Component: 0BL 42 TDIRdW H18 1007
   Revision: --H18---
   ROD: EV_TCMALX51011.rod
   VCID: 7DB21588ECF022A2BE-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AC    HW: 4H0 907 379 AC
   Component: ESP PREMIUM   H10 0930
   Coding: E4EDAB8027B7D501E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005025
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 73A633B0DAB464D2D8-8026
   Part No SW: 4H0 907 064 EB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0521
   Coding: 05A76F4E000000000000
   VCID: 6D9225C8B490B2220E-8038
   Serial number: 0214000078797014
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000069411154
   Coding: C018B60085047201010001010101112131313333283333
   Shop #: WSC 02729 823 28888
   VCID: 3522CDA89C403AE236-8060
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:22
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 381101FE340000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D12E5C87C1072224E-8078
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
                    Reset counter: 122
                    Mileage: 57650 km
                    Date: 2018.10.29
                    Time: 17:12:13
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000809839501
   Coding: 0105001440349FE2E9014084A0001800009CE308AE0802218000089461011700004000000B0000
   VCID: 689C54DC9B72970A7D-803C
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 150411  H36 0090
   Serial number:         150415141308
   Coding: 0045F7
   Serial number: 21401924
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4H0 941 531 G    HW: 4H0 941 531 G
   Component: E1 - LDS  H01 0044
   Serial number: 24 04 2015  00000652
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000000094CE01E78BF4
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA108140000007185914
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: B7398B86000000000001
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:26
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   Coding: 020000
   VCID: 230603F022D4B452E8-8076
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61061308001908
   Coding: 2AC905
   Shop #: WSC 77777 777 00007
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
Address 11: Engine II (J624)       Labels: None
   Revision: 5AH10---
   ASAM Dataset: EV_ECM42TDI2114H0907409K 001010
   ROD: EV_ECM42TDI2114H0907409K.rod
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Coding: 7F04010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B16EBD042047C1250-807E
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1001DV5-
   Coding: 30333045313430303038554A305234483053
   VCID: 3B36DB90B264EC92C0-806E
   Serial number: 3575HRB400S50PASG8M6
   Serial number: 3585HRB400Q50PASHHUN
   Serial number: 3515JRB4016510A0P0MG
   Serial number: 3525JRB400K510A0J9V%
   Serial number: 3554VRB405D36K465HDA
   Serial number: 3564VRB405B36K46KGT$
   Revision: --------    Serial number: 01335OK10019S
   Coding: 0000FC
   Shop #: WSC 24460 823 28888
   VCID: 373EC7A0864CC8F224-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 04 05 2013  C0251012
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 830 R    HW: 4H0 920 830 R
   Component: TDieRDWACCNV- H53 0621
   Revision: 34081090    Serial number: 658240113592013
   Coding: 138F08009F550008000100
   Shop #: WSC 77777 777 12345
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2150323000273
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140302223905
   Coding: 551F01
   VCID: 26001AE451E6417A8F-8072
   Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001378001
   Coding: 80CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 74A430ACDFBA63EAC1-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 51113C36221911038286
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14129000768011200410
5080 - Front Left belt tensioner control module
          U107C 00 [009] - No communication
          [Steuergerät für RGS Links Keine Kommunikation]
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:58:36
                    Voltage terminal 30: 14.7 V
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 34 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
          U1101 00 [009] - Active
                    Fault Frequency: 216
                    Reset counter: 122
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:58:36
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 56
                    Mileage: 55552 km
                    Date: 2018.09.28
                    Time: 01:33:57
                    Voltage terminal 30: 12.5 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 16 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 27
                    Reset counter: 161
                    Mileage: 55462 km
                    Date: 2018.09.27
                    Time: 00:17:38
                    Voltage terminal 30: 12.6 V
                    Control Module temperature: 14 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 002504140001010
   VCID: 281C14DC53F2570ABD-807C
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 L    HW: 4H0 919 158 L
   Component: Klima Fond    H16 0200
   Coding: 2700000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 393AC198B858DE82D2-806C
0089 - Voltage supply terminal 30 for actuators
          B10C1 01 [009] - Electrical Failure
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:01
0058 - Temperature Sensor for Rear Left Upper Body Vent
          B10F2 15 [009] - Open or Short to Plus
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:05
0060 - Temperature Sensor for Rear Right Upper Body Vent
          B10F3 15 [009] - Open or Short to Plus
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:05
0062 - Temperature Sensor for Rear Left Footwell Outlet
          B110E 15 [009] - Open or Short to Plus
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:05
0064 - Temperature Sensor for Rear Right Footwell Outlet
          B110F 15 [009] - Open or Short to Plus
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:05
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000059602
   Coding: 01010101000000000001000202
   VCID: 648440EC675AF36A51-8030
   Coding: 008003
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F2EFFC0761C00327C-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000069410890
   Coding: C018BF8085857201030001010101112131313333203333
03766 - Motor for Seat Belt Height Adjustment
                    Fault Status: 01100101
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:44
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:25:45
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7100FNFC
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 383CC49C8352C78A2D-806C
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H08 0040
   Serial number: 0408649982
   Coding: 040321
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3326F3B09A3424D218-8066
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0040
   Serial number: 0408713267
   Coding: 040321
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000144973716
   Coding: 011F1E015E0062C202083017
   VCID: 48DCB45CFBB2B70A5D-801C
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:26:02
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0015215632
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 3228F6B4652E2DDA13-8066
   Revision: 00002001    Serial number: 0335161371
   Coding: 011B0E2280B97981F320C7842C0316470000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000265223
   Subsystem 2 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 4 - Part No SW: 4H0 947 135 D    HW: 4H0 947 135 D
   Component: Dachelektroni  H13 0080
   Serial number: A2015000000000835161
   Subsystem 5 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0815
   Serial number: 94015820
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:14
   Part No SW: 4H1 035 465 B    HW: 4H1 035 465
   Component: BO G3 D4 ANC  H03 0150
   Revision: 11000000    Serial number: 0015855
   Coding: 010101
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 02503150029374
00529 - Engine Speed Signal Missing
            000 -  -
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:40
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
03994 - Noise reduction function limitation
            000 -  -
                    Fault Frequency: 14
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:40
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
02173 - Rear Right Microphone (R145)
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:41
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
02172 - Rear Left Microphone (R144)
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:41
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
02171 - Right Center Microphone (R143)
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:41
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
02170 - Left Center Microphone (R142)
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:27:41
                    Voltage: 14.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
                    Voltage: 11.00 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0158
   Revision: AA000000    Serial number: 00000066689776
   Coding: C01892808500700D0B00392038193A2039203B3B202020
   VCID: 3228F6B46D2E2DDA13-8066
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:22
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000145082347
   Coding: 011F1E015E0062C202083006
   VCID: 3C34D88CBF6AEBAAC9-8068
                    Reset counter: 122
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:22
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001055140
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02520220221B0200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 312AF9B8602816C26A-8064
   Coding: E00300
   Coding: E00300
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109EY0E7923800
   Coding: 010103010003000001
   VCID: 2B16EBD04A047C1250-807E
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06800800102001
   Coding: 01000400
   VCID: 2D12E5C8741072224E-8078
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0158
   Revision: AA000000    Serial number: 00000066701142
   Coding: C01896808500700D0B00392038193A2039203B3B382020
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:22
   Part No SW: 4H0 035 654     HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 0939
   Revision: --------    Serial number: 179E00E7520584
   Coding: 03010000020BFFEFFDF6AB1E00000003000001000000000000
   VCID: 638643F06254F452A8-8036
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDFY900AB50
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000123673
   Component: CD-Database  5571
            000 -  -
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:29:13
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 10000000 00000000
                    Bin. Bits: 01000000 00000000
02612 - Audio Wire Adapter Set
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:29:19
                    Voltage: 14.40 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0270
   Revision: --------    Serial number: 0000121325220
   Coding: 010F1E00420062C202083006
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 N    HW: 4H0 907 383 L
   Component: Anhaenger     H14 0160
   Revision: 7A001001    Serial number: 0356263965
   Coding: 0100010202000000
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0149179
   Coding: 020E000001010002010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   VCID: 2C14E8CC470A7B2A59-8078
9617993 - Proximity Camera
          B145C 54 [009] - Missing Calibration / Basic Setting
                    Fault Frequency: 40
                    Reset counter: 122
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:21
                    Voltage terminal 30: 14.4 V
                    Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 117400553
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FAE3FC0B69C40323C-803A
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Reset counter: 144
                    Mileage: 57256 km
                    Date: 2018.10.19
                    Time: 15:19:49
                    Voltage terminal 30: 14.57 V
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000149802
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 638643F06A54F452A8-8036
0006 - Front Left Footwell Lighting  Color 2
          B111D 01 [009] - Electrical Failure
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:48:12
                    Control Module temperature: 28 °C
                    Processor load: 34.5 %
                    Color setting Ambient: Red
                    Status terminal 58s: On
0014 - Rear Left Footwell Lighting  Color 2
          B1121 01 [009] - Electrical Failure
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 16:31:29
                    Control Module temperature: 32 °C
                    Processor load: 37.5 %
                    Status terminal 58s: OFF
0018 - Rear Right Footwell Lighting  Color 2
          B1123 01 [009] - Electrical Failure
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 16:31:28
                    Processor load: 37.0 %
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000146431913
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 762 N    HW: 4H0 035 762
   Component: H-B-AS        H41 0940
   Revision: --------    Serial number: 020CC0AB000091
   Coding: 03010000020100400100000400001300000000000000000000
   Shop #: WSC 06798 128 28888
   VCID: 312AF9B8682816C26A-8064
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDC1200WUMF
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDC1200WUKD
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KH20000H
   Component: CD-Database  3371
   Subsystem 5 - Part No: 8R0 060 884 ED
01043 - Control Module; Incorrect Software Version
            000 -  -
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:32:13
                    Bin. Bits: 00000000 00011010
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130617  0236
   ROD: EV_GSM2x3Mono.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4H0 919 617     HW: 4H0 919 617
   Component: HeadUpDisplay H17 0023
   Coding: D70000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 6D9225C8BC90B2220E-8038
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547     HW: 4G0 907 547
   Component: NV-ECU-Gen3   H06 0023
   Serial number: 622352400201312
   Coding: 101100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 6B962BD08284BC1210-803E
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1505000272
   Component: DPC-SG        H27 0081
   Coding: 79160000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00011983066802
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
0018 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Funktionseinschränkung wegen fehlender CAN-Botschaft]
                    Reset counter: 122
                    Mileage: 57649 km
                    Date: 2018.10.29
                    Time: 15:32:45
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00011983068502
   Coding: 366FF2
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:26
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00011982182302
   Coding: 306F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   VCID: 2E10E2C47116093A77-807A
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:26
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7F04010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 291A11D848F86E02A2-807C
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00011982028701
   Coding: 306F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 55435 km
                    Date: 2018.09.26
                    Time: 12:57:26
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0038
   Serial number: 000040180205117
   Coding: 01A09B061111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 25021DE824E04A6286-8070
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right        Labels:
   VCID: 55E26D28AC001AE2D6-FFFE
   Note: Excessive Comm Errors
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 141070748
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 04:52, VBatt start/end: 14.7V/14.8V)-----------
Gone But Not Forgotten
Remove particulate trap for manual chemical remediation of soot and ash accumulation and check PSI sensors, further clean EGR.
krisv
Poland
C?ID=326234
Thanks a lot for the advice, I was unable to start the regen because the amount of soot was to high. Took the car to a highway and drove around 100 km , the amount of soot dropped. After all I was able to start the Regen with following Access code 27971 .
Thanks again for your help and advises :)
Glad it worked out for you but keep a close eye on the DPF for becoming cherry red or observe EGT temps with pile up.
