I fitted Multi-Function Steering Wheel (MFSW) with Cruise Control System (CCS) to B8 Passat.
Both coded, but now I’m stuck with fault code “17149 - Check Coding of ECUs on Powertrain Data Bus “ (Engine). Full Auto-Scan attached.
MFSW works fine, but CCS not. CCS buttons also works -> but there comes an error message to the instrument display (CCS “logo” and exclamation mark).
Is there something I have missed or could anyone help me with this one?
Wednesday,05,September,2018,10:13:36:16690
VCDS Version: 18.7.2.1 (x64) HEX-NET CB: 0.4430.4
Data version: 20180808 DS295.0
VIN: WVWZZZ3CZHE041326 License Plate:
Mileage: 12605km-7832mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 2B 42 44 52 5F 69
VIN: WVWZZZ3CZHE041326 Mileage: 12605km-7832miles
Address 01: Engine (J623-DCXA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 GK HW: 04L 907 309 R
Component: R4 1.6l TDI H23 1992
Revision: B5H23---
Coding: 0125001A04341D093000
Shop #: WSC 62836 001 104857
ASAM Dataset: EV_ECM16TDI01104L906026GK 002002
ROD: EV_ECM16TDI01104L906026GK.rod
VCID: 79BA078FF898608265-802C
P1647 00 [167] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 12605 km
Date: 2018.09.01
Time: 01:29:54
Engine speed: 0.00 /min
Coolant temperature: 21 °C
Intake air temperature: 22 °C
Voltage terminal 30: 12.740 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 1
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 0
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s²
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 049 N HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0902
Revision: 00005026 Serial number: CU501607116681
Shop #: WSC 05311 115 00093
ROD: EV_TCMDQ200021_VW27.rod
VCID: 48DCB24BF3F2C90AAA-801C
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 62016000003028
Coding: 0FEC6A8F34240B6D477A060241C949F0562CD0E2608292710042F078C20202
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 7AB81883FD9E6B9A6C-802E
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0411620483
Coding: 002F0F0F0F
Shop #: WSC 05311 115 00313
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 3B36DD87B224929237-806E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AL HW: 5G0 907 426 AL
Component: AC Manuell H03 1601
Revision: 00001K06
Coding: 12020104204111001000400000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004_VW48.rod
VCID: 75A20BBFD48004E201-8020
Part No SW: 5Q0 937 086 BG HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 865822071600CX
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 004C6A6B9B42314A22-8054
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160612 042 0607
Serial number: 160622194423
Subsystem 2 - Part No SW: 3G0 941 633 C HW: 3G0 941 633 C
Component: E1 - LDS MQB H01 0032
Serial number: 05 05 2016 10000111
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPEVAC7U
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F4EE997E6BC4EB25B-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 906 16
Serial number: 3576U0000005E085DB1M
Subsystem 2 - Part No SW: ----------- HW: 454 002 906 16
Serial number: 3586U000000E7085DB1P
Subsystem 3 - Part No SW: ----------- HW: 454 800 407 16
Serial number: 3516RCB87E70B000000Q
Subsystem 4 - Part No SW: ----------- HW: 454 800 307 16
Serial number: 3526R0793E70B0000008
Subsystem 5 - Part No SW: ----------- HW: 454 801 807 16
Serial number: 3556V1DC3410B0000009
Part No SW: 3Q0 953 521 DK HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF034034 Serial number: 20160204501234
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 7CB41E9BF7AA55AA7E-8028
Part No SW: 3G0 920 741 B HW: 3G0 920 741 B
Component: KOMBI 202 9630
Coding: 07A409182380000801080B001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 230605E72A94CA521F-8076
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3A38D883BD1EAB9A2C-806E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000081717
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2265
Revision: -------- Serial number: 17071610800027
Coding: 030300345F015900FB0000481C0F00010001070000000000000000000000
ROD: EV_GatewConti_013_VW48.rod
VCID: 7BB61D87F2A4529277-802E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 39180000453910108152
Coding: 680000
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 8822020404
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000154495017
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA3FAFA0E828C2DD-8024
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 200616EFJ12513
Coding: 00300B208000020000001000
VCID: 41CAAF6FD0C8F8426D-8014
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000004174726
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000930652
Coding: 01000010005000
Shop #: WSC 00015 115 00313
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D32D39FAC309CA209-8068
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 060716EG402291
Coding: 003001208000020000001000
VCID: 40CCAA6BDBC2F14A62-8014
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000004179504
Coding: 090000
Part No SW: 5G0 035 867 D HW: 5G0 035 867 D
Component: MU-E--ER 050 7064
Serial number: 23061600010223
Coding: 02840200FF0000004011000100000200000000040000010000
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 2D12E3DF7C500C22B9-8078
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0204
Revision: 8A001003 Serial number: 0411589680
Coding: 0100000202000000
End----------(Elapsed Time: 01:26, VBatt start/end: 12.8V/12.8V)-----------
