Hi Guys
A 2011 Golf 1.6 TDI here. Cluster display wasn't working and customer has fitted another cluster to check if it was working first and has wiped ABS coding.
Could anyone please help with suggestions for possible coding.
Saturday,04,August,2018,17:28:07:46000
VCDS Version: 18.2.1.2 (x64)
VIN: WVWZZZ1KZCW089425 License Plate: SA61NFN
Mileage: 146970km-91322mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 77
VIN: WVWZZZ1KZCW089425 Mileage: 146970km-91322miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 08114014030501080000
ASAM Dataset: EV_ECM16TDI02103L906023MN 003014
ROD: EV_ECM16TDI.rod
VCID: 7EF98879E144C5B455-802A
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Mileage: 146977 km
Date: 2018.08.04
Time: 00:04:54
Engine speed: 0.00 /min
Coolant temperature: 22 °C
Intake air temperature: 19 °C
Voltage terminal 30: 12.198 V
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 12.2 V
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
VCID: 7BFF816DFA56D09C72-802E
Reset counter: 6
Mileage: 146977 km
Date: 2012.12.25
Time: 00:04:56
Count: 7
Count: 2
Count: 20992
Count: 195
Count: 44288
Fault Status: 01100101
Reset counter: 6
Mileage: 146977 km
Date: 2012.12.25
Time: 00:04:55
Count: 2
Count: 2
Count: 20992
Count: 279
Count: 44288
Reset counter: 6
Mileage: 146977 km
Date: 2012.12.25
Time: 00:04:56
Count: 7
Count: 2
Count: 20992
Count: 295
Count: 44288
Reset counter: 6
Mileage: 146977 km
Date: 2012.12.25
Time: 00:04:55
Count: 2
Count: 2
Count: 20992
Count: 270
Count: 44288
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004003
VCID: 7F07757DE64ECCBC5E-802A
Part No SW: 1K0 937 085 L HW: 1K0 937 085 L
Component: BCM PQ35 B+ 110 0651
Revision: 00110 AC
Coding: 40180A3A80251890400800C0100000E44B010288424D8160648087200041
VCID: 38755E618BE03B84DF-806C
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 28071 26 0512
Coding: 009795
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA8TKJ8
Coding: 00003954
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 31636345609AEACC98-8064
Serial number: 3572MSME40011363ZZZB
Serial number: 3582MSME3F697361ZZZ1
Serial number: 3512QSME5A065D22ZZZY
Serial number: 3522QSME66032E14ZZZS
Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
Revision: -------- Serial number: 90440KH4000EE
Coding: 1082040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 71E3A345A01AAACCD8-8024
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000430759
Coding: E20000
Part No SW: 5K0 920 970 N HW: 5K0 920 970 N
Component: KOMBI H03 0305
Coding: 470900
VCID: 39735B65B8EA228C20-806C
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 070811F6001250
Coding: 350003
VCID: 37775D5D86FE34FCD6-8062
Component: IMMO H03 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1B4298DCC591499-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0131636
VCID: 31636345A89AEACC98-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346D6A515788DFE4F3-8060
Fault Status: 11100101
Mileage: 146977 km
Date: 2012.12.25
Time: 00:04:54
Battery Volts: 12.2 V
DD
Temperature: 20.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0131636
VCID: 32616C49AD9CD1D4E1-8066
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
Component: Radio RCD510 052 0208
Revision: 00000001 Serial number: VWZ1Z3L1525251
Coding: 05000400040005
VCID: 2B5F712D4AB6801CA2-807E
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 030B185A
VCID: 71E3A345A81AAACCD8-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900167763
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660642527
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 346D6A519F88DFE4F3-8060
End-------------------------(Elapsed Time: 02:09)--------------------------
