I have been through my coding several times and still it seems that I am missing something, because it still does not work. I do see it in the setup menu and I enabled it but...
Would someone take a look?
I also have an issue were my cruse control will disengage for no apparent reason, it does not cut off it just disengages... I press resume immediately and it goes back to the set speed. I am getting "02-Auto Trans -- Status: Malfunction 0010" errors.
Wednesday,30,May,2018,14:36:42:21870
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VWCA7AU2FM500815 License Plate:
Mileage: 28069km-17441mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75
VIN: 3VWCA7AU2FM500815 Mileage: 28069km-17441miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 D HW: 04L 907 309
Component: R4 2.0l TDI H23 9283
Revision: 85H23---
Coding: 011D0012032410081000
Shop #: WSC 04908 444 00000
ASAM Dataset: EV_ECM20TDI01104L906021D 004017
ROD: EV_ECM20TDI01104L906021D_004.rod
VCID: 26150AB668625BD72BB-8072
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 03253104 Serial number: TFK01412062102
Shop #: WSC 00066 790 00201
ROD: EV_TCMDQ250021.rod
VCID: 231313A21B50AEFF4C5-8076
21182 - Clutch
P2789 00 [072] - Adaptive Learning at Limit
Mileage: 27813 km
Date: 2018.05.26
Time: 15:32:34
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53404000000896
Coding: 04FA6AA12420096C007F020181C82520562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
VCID: 47CBA732CF28A2DFF0D-8012
Revision: 00021000 Serial number: 0351474282
Coding: 030C0C
VCID: 3A2DCEC68CDACF377F3-806E
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020124200100010005004012111400
VCID: 42DDB626E40A87F7273-8016
Air quality sensor:
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Revision: -------- Serial number: 86582711140229
Coding: 00511A464041A2E969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 07031
ROD: EV_BCMBOSCH_014.rod
VCID: 4ACD9E06DC3A5FB7EF3-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141018 043 0581
Serial number: 150114084629
Component: RLHS 037 0059
Serial number: S4Y14M12D03H18M25S29
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H02 0003
Serial number: 0000FST0001HMTX00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H02 0003
Serial number: 0000FST0001HLMP00000
Coding: 191800
Fault Frequency: 22
Reset counter: 248
Mileage: 27665 km
Date: 2018.05.23
Time: 20:12:00
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR00THW7
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J140001UQ5E0H
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 001 411 14
Serial number: 3570000000015AD8E11P
Subsystem 3 - Part No SW: ----------- HW: 480 001 411 14
Serial number: 35800000000C9209E11L
Subsystem 4 - Part No SW: ----------- HW: 480 400 412 14
Serial number: 3510002BB18B3AB3B106
Subsystem 5 - Part No SW: ----------- HW: 480 400 212 14
Serial number: 35200029B18B3AB551EF
Subsystem 6 - Part No SW: ----------- HW: 480 401 411 14
Serial number: 3550002C5188FC11A057
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 411 14
Component: FrontSensor_P 001 6149
Serial number: 3560002C7188FC102231
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141203500626
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 0451703EBE9E49C755F-8050
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA5121A2980CF05020878001000000000000000
Shop #: WSC 00066 790 00195
VCID: 65974DBA55E490CFE21-8030
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 21121410000112
Coding: 0901000800087300EF00020A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ROD: EV_GatewConti_011_VW37.rod
VCID: 72BD26E6942A7777773-8026
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29140002590240094482
Coding: 29FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0017742
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000337476004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E0FEAEBE3947A5F-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 031214060502IW
Coding: 003A13200000040000000000
VCID: 40D9BC2EEA0695E7317-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000509039
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 43D3B322FB108EFF2C5-8016
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0060
Serial number: VWZ8Z1EC4022EEW
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 639353A25BD0EEFF0C5-8036
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 27121406050622
Coding: 003A13200C00040000000000
VCID: 3FDBBFD297F8EA1F48D-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000431379
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 060A00010B000400
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0645
Serial number: V7B01412140069
Coding: 027302020000000021220002001800001F0100340100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 698F418AB9FCB4AFC69-803C
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS600CNM
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Shop #: WSC 00066 790 07177
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 12.2V/12.1V)-----------
