Octavia Abs long coding (MK60EC1)
NWT
C?ID=22843
Hi Guys
Another 2013 Octavia 1.6 TDi with lost ABS coding. Dealer fitted new cluster and left customer with no ABS coding.
Can anyone please help with possible long coding for ABS.
 Friday,02,March,2018,18:10:48:46000
VCDS Version: 18.2.0.3 (x64)
VIN: TMBCT21Z5C2200765   License Plate: LOG2.3.18
Mileage: 132820km-82530mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: TMBCT21Z5C2200765   Mileage: 132820km-82530miles
   Part No SW: 03L 906 023 NJ    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8813
   Revision: --H43---    Serial number:
   Coding: 00114014032501080000
   Shop #: WSC 73430 031 00075
   ASAM Dataset: EV_ECM16TDI02103L906023NJ 003005
   ROD: EV_ECM16TDI.rod
   VCID: 7BFF816DF256D09C4D-802E
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 132811 km
                    Date: 2018.03.01
                    Time: 18:12:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 58 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 12.085 V
                    Engine speed: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 11.6 V
Readiness: 1110 1000
   Revision: 00H31001
   Shop #: WSC 73430 790 00095
   VCID: 7BFF816DFA56D09C4D-802E
            000 -  -
                    Reset counter: 205
                    Date: 2012.07.22
                    Time: 18:48:46
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 47360
                    Count: 1024
                    Fault Status: 01100101
                    Reset counter: 205
                    Mileage: 132821 km
                    Date: 2012.07.22
                    Time: 18:46:01
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 47872
                    Count: 1024
                    Reset counter: 205
                    Mileage: 132821 km
                    Date: 2012.07.22
                    Time: 18:46:01
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 47872
                    Count: 1024
   Part No SW: 3T0 820 047 AB    HW: 3T0 820 047 AB
   Component: AC Manuell    H19 0502
   Revision: 00001010
   Coding: 0000000003
   Shop #: WSC 73430 790 00075
   VCID: 6FE7A53DB62EBC3CF1-803A
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 244
                    Mileage: 132793 km
                    Date: 2018.03.01
                    Time: 00:09:35
   Part No SW: 1K0 937 085 L    HW: 1K0 937 085 L
   Component: BCM PQ35  B+  110 0651
   Revision: 00110 AC
   Coding: 48000AB8A00508904008008011000024430000AE420081605CC4C7000041
   VCID: 38755E618BE03B84E0-806C
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 02051  26  0601
   Coding: 00D7B7
                    Reset counter: 244
                    Mileage: 132793 km
                    Date: 2012.07.22
                    Time: 00:09:35
                    Voltage: 12.40 V
                        Term 50 On
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2AYUYT
   Coding: 0020788
   VCID: 3D7B4F7564C21EAC33-8068
   Subsystem 1 - Serial number: 6332MSME6E562737L
   Subsystem 2 - Serial number: 6342MSME6D414C27L
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Revision: FF010041    Serial number: 20120515801176
   Coding: 4080140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 72E1AC49A51C91D41E-8026
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H06 0608
   Coding: 410A00
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 49932BA5E80AB20C8F-801C
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 244
                    Mileage: 132793 km
                    Date: 2018.03.01
                    Time: 00:09:34
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 170512F6000022
   Coding: 351303
   VCID: 3B7F416DBAD6109C0D-806E
   Component: IMMO          H06 0608
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1B4298DCC5914A6-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0131700
   VCID: 48952EA13B004B0490-801C
00913 - Window Regulator Switch; Front Right Driver (E81)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 37775D5D46FE34FCE9-8062
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131700
   VCID: 47972D9D361E447C99-8012
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0061
   Revision: 0A001001    Serial number: SKZ1Z3M0103752
   Coding: 000002000001
   VCID: 356B57559CF2C6ECFB-8060
00625 - Vehicle Speed Signal
                    Reset counter: 244
                    Mileage: 132793 km
                    Date: 2012.07.22
                    Time: 00:09:38
   Component: Batt.regelung H43 1623
   Coding: 030B185A
   VCID: 71E3A345A81AAACCE7-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900240414
End-------------------------(Elapsed Time: 01:53)--------------------------
NWT
C?ID=22843
Hi, thanks allot for the reply. Unfortunately it didn't work.. any other suggestions?
NWT
C?ID=22843
Thanks, NEtech.. unfortunately no luck with that one either....
My suggestion is 133B201C092200FAC81204EA901E0091300000
I built that based on a known good scan with the G0J5-speed manual gearbox (different spread) PR code:
CAYCMT/5L0R1K0 907 379 BJ @ 01211300200009000000C80004009000009130000013200900C804900091300000G0J0YC1N32UA1AT1ZF/1KDNARoW/UK
Gone But Not Forgotten
Revision: 00H31001
Coding: 133B001C092200FAC81200EA901E0000000000 VIN STRIP RHD
Coding: 133B201C092200FAC81204EA901E0091300000 DANA RHD OFF RD SW 1.2 280/253
Coding:
113B201C092200FA881204EA901E0091300000 NETECH RHD 1.8 280/253
Try these in green
Coding: 133B201C092200FAC81204EA901E0082300000 RHD 1.6 280/253
Coding: 133B201C092200FAC81204EA901E0092300000 RHD 1.6 280/253 OFF RD SW
Coding:
113B201C092200FA881204EA901E0051300000 LHD 1.2 280/253 OFF RD SW
Coding: 133B401C0922B0FAC81204EA901E0081300000 RHD experimental
Scans of net
Coding: 133B201C092900FBC81104EA901A00813100
Coding: 113B201C092400FC880B04E4901A51300000
Coding: 133B401C092B00FEC81102E9901F00813000
OP REPORT PLEASE....
praz1988
C?ID=303013
Hi, If you have no luck using the above long codes for address (03) I would suggest making contact with the main dealer who carried out the instrument cluster repair, they should have a log file with the initial faults listed before or while replacing the component. This will have the long code for (03).
Maybe also ask them why no serial numbers or dealer codes have been imported into either 25 - immobilizer and 17 - Instrument cluster :confused:
NWT
C?ID=22843
No luck with this one I'm afraid. Thanks allot for trying.
NWT
C?ID=22843
Thanks for help again Jack. ... none of those codes have worked though.. Any other ideas?
Is the car left or right hand drive?
Does the cluster/immobilizer contain same Advanced ID for VIN number as Engine in advanced ID?
iichel
Netherlands, eastern part
C?ID=284912
Uk is RHD I suppose
Welcome to the party jack Dana and netech
NWT
C?ID=22843
Friday,11,May,2018,14:52:38:46000
VCDS Version: Release 18.2.0 (x64)
Control Module Part Number: 3T2 920 941 K
  Component and/or Version: KOMBI         H05 0607
           Software Coding: 410F00
            Work Shop Code: WSC 45331
                      VCID: 3D7B4F75ACC21EAC33-8068
Advanced Identification/FAZIT
     Identification: VD1-048
     Date: 08.04.12
     Manufacturer number: 5250
     Test stand number: 9506
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
VCDS Info:
       Labels: 5K0-920-xxx-17.clb-SRI1
 Friday,11,May,2018,14:51:06:46000
                Address 01: Engine
Control Module Part Number: 03L 906 023 JH
  Component and/or Version: 1,6l R4 CR td H43 9966
           Software Coding: 00114014030500080000
            Work Shop Code: WSC 33361
                      VCID: 75EB9755D47286EC3B-8020
     Identification: SJ8-FST
     Revision: --H43---
     Date: 17.02.13
     Manufacturer number: 0010
     Test stand number: 0009
Flash Status
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 906 023 JH
     Workshop System Name: J623
     ASAM Dataset: EV_ECM16TDI02103L906023JH
     ASAM Dataset Revision: 003007
Car Info
     Chassis Number: TMBKJ73T7D9045782
     Engine code: CAYC
VCDS Info:
       Labels: 03L-906-023-CAY.clb
       Readiness: No script available
       ROD: EV_ECM16TDI02103L997557A.rod
NWT
C?ID=22843
Friday,11,May,2018,17:13:19:46000
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H05 0607
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Date: 08.04.12
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03009
Car Info
Immobilizer
     Transponder ID (Current val.): D20A8A21
     Transponder ID 1: D1FF5193
     Transponder ID 2: D20A8A21
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
NWT
C?ID=22843
Believe it or not I have another 2 Golfs here now with lost coding as well.
2 X 2012 VW Golf 1.6 TDI's. One has oil sensor problem that dealer has said is cluster fault. So we tried swapping clusters today to check if problem was still there (which it isn't). We never thought to back everything up first. Now both cars have no ABS coding and lost radio code.. Can I start a new thread for this? How do I source radio codes for these?
You know what I am going to recommend you go get all these cars SVM'd at dealer and in the future when cars come in no matter what please do an auto-scan first.
Thank you
