Hello guys ...
I have a TT issue with the central locks module -35 having 72 fault codes (everything ? :P )
and also maxed out SW coding that cant be changed.
The car has a problem with Dash and it couldnt start , I had to Immo off the ECU .
The car starts ,locks work fine but the Remote cant syncro at all....
Attached the Autoscan
Any ideas ?? I cant REVODE at all
Tuesday,07,October,2014,16:12:29:29510
VCDS Version: 14.8.1.0 (x64)
Data version: 20140905
Dealer/Shop Name:
VIN: License Plate:
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 03: ABS Brakes Labels: 8N0-907-379-MK20.lbl
Part No: 8N0 907 379 B
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01236
VCID: 3B75E0272916E6E2CC-4B00
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
VCID: 285F2F6BC8805D7AB1-2580
30-00 - Open or Short to Plus
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: 77FD3C1755BE0282E8-5140
Address 35: Centr. Locks Labels: None
Part No: 8N
Component: Zentralverrieg. D04
Coding: 32767
Shop #: WSC 131071
VCID: 060341D322546B0AE3-4EB2
72 Faults Found:
01366 - Opened Due to Crash Signal
35-10 - - - Intermittent
01371 - Alarm triggered by Door Contact Switch; Driver's Side
01572 - Alarm triggered by Door Contact Switch; Passenger Side
01374 - Alarm triggered by Terminal 15
01370 - Alarm triggered by Interior Monitoring
01369 - Alarm triggered by Hood Switch
01368 - Alarm triggered by Luggage Compartment Switch
01373 - Alarm triggered by Radio Ground Contact
01558 - Contact Switch in Locking Cyl; Driver Side; Close (F241)
01557 - Contact Switch in Locking Cyl; Driver Side; Open (F241)
01618 - Automatic Convertible Top Valve 2 (N272)
28-10 - Short to Plus - Intermittent
01563 - Interior Lock Switch; Driver Side (E150); Lock
01564 - Interior Lock Switch; Driver Side (E151); Unlock
00947 - Trunk Lid remote Control Switch (E188)
00991 - Interior Lights
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
01568 - Signal for Convenience Opening
01569 - Signal for Convenience Closing
01357 - Tank Flap Locking Motor (V155)
01555 - Motors for Central Locking; Save [Safe?]
01556 - Motors for Central Locking; Unlock
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
00957 - Key 3
00958 - Key 4
01570 - Turn-Off Delay; Terminal 15
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
00000 - End of output
00-10 - - - Intermittent
59-10 - Can't Unlock - Intermittent
60-10 - Won't Safe - Intermittent
61-10 - Won't De-Safe - Intermittent
01552 - Motor for Central Locking; Drivers Door (V56); Lock
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00949 - Central Locking Motor - tailgate (V53); LOCK
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
01581 - Incorrect Component Detected
01379 - Interior Monitor Switch (E183)
01109 - Hydraulic Pump Relay (J321)
01482 - Motors for Central Locking
00951 - Tailgate Central Locking Motor Relay (J398)
01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
01615 - Tank Door Remote Unlocking Switch (E204)
76-10 - Terminal 30 missing - Intermittent
77-10 - Internal Supply Voltage - Intermittent
01092 - Switch For Stowed Canopy (F171)
01091 - Switch Front Canopy (F202)
01617 - Please Check DTC Memory of Interior Monitoring
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
VCID: 7CF7233B6C9821DA85-51B6
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-00 - Supply Voltage Too Low
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00009
Shop #: WSC 01236
VCID: 65C1665FFF1280124A-51B6
End-------------------------(Elapsed Time: 03:23)--------------------------
