I've been testing VCDS-Mobile and its capabilities for a few weeks, and I've had some success with Auto-Scan, Advanced Measuring Values, Adaptations and Coding, but it really depends on the module being accessed. Several modules I'm interested are missing Adaptation Channels or Coding information. There are also other minor problems that I've encountered, see complete list below:
1. When I run Auto-Scan, it takes about 1 minute to scan module 08-Auto HVAC when I'm using VCDS-Mobile. With VCDS it takes about 20 seconds (which is still much longer than with any other module). If I remember correctly, it stayed long at the "Retrieving slaves..." stage. And if I directly access the 08 module with VCDS-Mobile, Functions-button is also greyed out for 1 minute, before I can select it.
2. Several modules are missing Adaptation Channels, for example 08, 09 and 17. They only show empty list with the text "Documented adaptations can be selected":
I haven't tested all modules, but at least 6D-Trunk has adaptation channels listed.
3. When I select module 5F and try to access "Cloud Functions", browser gets redirected to the VCDS Cloud login page instead of the Cloud Server Main Menu.
4. For some reason, several modules have duplicate measuring values:
5. 17-Instruments is missing Coding information/texts. I still tried to revert a change I did with VCDS (change Byte 1 from a5 back to a4 = disable Needle Sweep), but when I select "Do it!", page just hangs for about 20-30 seconds and then refreshes with the old value:
But I have successfully coded 08 module with VCDS-Mobile.
5. "Go Back" or "Continue" buttons in VCDS Cloud don't work with iPhone & Safari, but work with Windows & Firefox. When buttons are pressed, browser tries to open the following url, but immediately stops with error "Safari cannot open the page because the server cannot be found":
http://controllerfunc.shtml/?closeserver=true
So I guess it's missing the HEX-NET IP address. If I manually add the current HEX-NET IP address like this http://172.20.10.6/controllerfunc.shtml/?closeserver=true, I get the following 404 error page and I don't even see a bunny with a pancake on its head
I would really appreciate it if you could have a look into these problems. Thanks in advance!
Here's the Auto-Scan:
VCDS Mobile 0.4417.0.4
VIN: TMBJD9NE5J01xxxxx
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
4B 52 5F 6C 6D 75 A5 D6 D7
Address 01: Engine (CJSA: J623) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 H HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0005
Revision: --H13---
Coding: 0C25003A2464050B1000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
ROD: EV_ECM18TFS0208V0906264H.rod
VCID: 41C5D6076FC4429C068DCF1E11-8014
No fault codes found.
Address 02: Auto Trans (J743) Labels: 0C-02.clb
Part No SW: 0CW 300 041 G HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1003
Revision: 00005026
ROD: EV_TCMDQ200021_SK37.rod
VCID: 3935BEE707141A5C4E3D77BEA9-806C
Address 03: ABS Brakes (J104) Labels: 5Q-03.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000
Coding: 25076A913428216F4077060440C629A4562C8402600294743641F0F0C0A2430000000012121212B8586C384E4484EE
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 77B178DF7180CC2C78A921864F-8022
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000
Coding: 032C0C
Shop #: WSC 73430 790 00063
VCID: 3C3BA7F308262F74555B96C24E-8069
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 AT HW: 5E0 907 044 AT
Component: Climatronic H04 2001
Revision: 00001K00
Coding: 02010004004111011005000D0010102A
Shop #: WSC 73430 031 00063
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Address 09: Cent. Elect. (J519) Labels: 5Q-09.clb
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: --------
Shop #: WSC 73430 790 00000
ROD: EV_BodyContrModul1UDSBosc_018.rod
VCID: 864F851B866A25A4F33FC45A90-80D3
Subsystem 1 - Part No SW: 5E1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: MÝ
Subsystem 2 -
Subsystem 3 -
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12K
Coding: 0271167051
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_009_SK37.rod
VCID: 50E3E343B4AEBB14992372D252-8005
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 330060C141FFC728949C810520400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416_002.rod
VCID: 3E3FADFB1E3A3D647B6FACFA68-806B
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Shop #: WSC 00000 000
ROD: EV_DRCONTITEMIC_SK37.rod
VCID: 3833BBE33C1E0354B1336AB29A-806D
Part No SW: 3Q0 959 655 BJ HW: 3Q0 959 655 BJ
Component: Airbag VW21 006 0703
Revision: --------
Coding: 98FCC000000000005C5400CC000840000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 8751881F81603CAC8849D1469F-80D2
Subsystem 1 - Part No SW: --------------
Component: ---
Subsystem 2 - Component: ---
Subsystem 3 - Component: ---
Subsystem 4 - Component: ---
Address 16: Steering wheel (J524) Labels: 5Q-16.lbl
Part No SW: 5Q0 953 521 LA HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0245
Revision: FF036036
Coding: 6414
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CBB67F348A6EF7415DB56C20E-8029
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Fault Status: 01110001
Fault Frequency: 8
Reset Counter: 1
Mileage: 4457021 km
Part No SW: 5E0 920 750 E HW: 5E0 920 750 E
Component: KOMBI 303 0310
Coding: 07A509187D840008018B6B0B5001000800000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 260F659BE6AA85A4137FA4DAB0-8073
Address 18: Aux. Heat (J364) Labels: 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3B39A4EF0D28284C5C518DD643-806E
Address 19: CAN Gateway (J533) Labels: 3Q-19.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 436 4304
Revision: --------
Coding: 0B0100047F085900EB00025A9C0F00010001070000000000000000000000
ROD: EV_GatewNF_SK37.rod
VCID: 33298CCF2578E00C84013576DB-8066
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Subsystem 4 -
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004.rod
VCID: 342B8FD32076E7349D0B3E62E6-8061
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0022
Coding: 0010000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_002.rod
Address 3C: Lane Change (J1086) Labels: 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3D3DAAF7133C267C6265A3CE5D-8068
Address 42: Door Elect, Driver (J386) Labels: 5Q-42.clb
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Coding: 001D0920DE00040000001100
VCID: 47D1C81F41E07CACC8C91146DF-8012
Component: EPS_MQB_ZFLS 129 1072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 45CDC2177BEC6EBC3AB5FB2EC5-8010
Address 47: Sound System (J525) Labels: 81-47.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001
Coding: 0373020000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: D9F59E6767547A5CEE7D573E49-808C
Address 4B: Multifunc. Module (J745) Labels: None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Coding: 000000070100046A06003D01010000000000000000000000000000000000
VCID: F2A7C9CB9AE22904CF77684A0C-80A7
Address 52: Door Elect, Pass. (J387) Labels: 5Q-52.clb
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Coding: 001D0120DE00040000001100
VCID: 46CFC51B46EA65A433BF045AD0-8013
Address 5F: Information Electr. (J794) Labels: 56-5f.clb
Part No SW: 565 035 043 A HW: 565 035 043
Component: MU-H-N-EU H54 1163
Coding: 037302010000000051110002000802232F0103E401200500BE
ROD: EV_MUHig4CGen2HBAS_SK37.rod
VCID: 10632343742EFB14D9A3B2D292-8045
Subsystem 1 - Part No SW: 5E0-919-606-D
Component: ABT_High-2
Subsystem 2 -
Subsystem 3 -
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Component: RVC Compact H12 0231
Coding: 047302012600201F000040
ROD: EV_CamSysRVRVCPANAMQBAB_006.rod
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001
Coding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A1791ABF2B2A1C437A7D0EA64-807F
Address 75: Telematics (J949) Labels: 5N-75.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 03730201EA421A0D3B1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_SK37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q-a5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Coding: 020307020000040100222354C150A90094000E200020
ROD: EV_MFKBoschMQBB_SK37.rod
VCID: 08530B230C7EB3D401535A722A-805D
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EBF6DFB5EBAFD643BEF6CFA28-802B
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416.rod
