Error 31: Request out of range - Coding Rejected
thunder
C?ID=304147
Hello, I'm would like te recode a ecu from manual to automatic gearbox. When I do vcds gives error Error 31: Request out of range - Coding Rejected.
Any help would be appreciated.
auto-scan:
Friday,12,January,2018,13:35:37:40204
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4411.4
Workshop Code: 790 02757 050316
VIN: WV2ZZZ7HZFH036785   License Plate: DQ500
Chassis Type: 7H-VN75 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
02-Auto Trans -- Status: Not registered 0011
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6305
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 0119401A233401080000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 003004
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 0058712AAA8AD3C75A1-8054
33 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [035] - Electrical Malfunction
16703 - Gear Reconition Sensor
          P181C 00 [035] - Implausbile Signal
5270 - Output for Starter Relay
          P0615 00 [035] - Open Circuit
5457 - Control Circuit for Starter Relay 2
          P3049 00 [035] - Open Circuit
4871 - Exhaust Gas Recirculation Cooling Valve Control
          P2425 00 [039] - Open Circuit
                    Vehicle speed: 255 km/h
                    Coolant temperature: -12 °C
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 13.820 V
                    Coolant temperature at radiator outlet: actual value: 70.5 °C
                    Bypass valve for EGR cooler: status-Bit 0: 1
                    exh.gas recirc.: shut-off conditions-Bit 0: 0
                    exh.gas recirc.: shut-off conditions-Bit 16: 0
                    exh.gas recirc.: shut-off conditions-Bit 24: 0
                    exh.gas recirc.: shut-off conditions-Bit 8: 5
                    EGR cooling function: status-Bit 0: 3
                    exh.gas recirc. (EGR) cooler pump: specified value: 0.00 %
                    Exh.gas temp.sen 1: 314.0 °C
4875 - Coolant Pump 2
          P261A 00 [167] - Open circuit
                    Time: 00:00:00
                    EGR cooling function: status-Bit 0: 4
                    exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Time: 00:00:00
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 349.0 °C
                    Exh.gas temp.sen 4: 343.2 °C
                    Shut-off timer: last engine shut-off time: 5 s
4978 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [035] - Electrical Malfunction
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
          P0135 00 [039] - Malfunction
                    Time: 00:00:00
5132 - Valve for Fuel Metering (N290)
          P0090 00 [167] - Open Circuit
                    Coolant temperature: -13 °C
                    Voltage terminal 30: 13.840 V
                    Engine status: COENG_READY
13828 - Relay for Aux Coolant Pump (J496)
          P1927 00 [039] - Open Circuit
                    Voltage terminal 30: 13.800 V
                    Electric auxiliary heater: shut-off conditions-Bit 0: 0
                    Electric auxiliary heater: shut-off conditions-Bit 8: 0
                    Electric auxiliary heater: relay activation-Bit 0: 0
                    Preheat time: 2500 ms
                    Glow status-Bit 0: 0
                    Glow status-Bit 8: 0
                    Glow cycles above temperature threshold-Bit 0: 0
                    Glow cycles above temperature threshold-Bit 8: 0
                    Glow cycles below temperature threshold-Bit 0: 0
                    Glow cycles below temperature threshold-Bit 8: 0
                    Outside air temperature: -3549.9 °C
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    EGR Solen.val.: actual value: 100.00 %
                    Throttle valve adapter: actual value: 100.00 %
                    Charge air pressure specified value: 1050 hPa
                    Charge air pressure: actual value: 3000.0 hPa
                    Mean injection quantity: 0.00 mg/stroke
4881 - EGR Valve (N18)
          P1440 00 [039] - Open Circuit
                    Time: 00:00:00
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR valve: offset closed: 1.11 %
                    Actuator for high pressure EGR: status-Bit 0: 0
                    Actuator for high pressure EGR: status-Bit 16: 3
                    Actuator for high pressure EGR: status-Bit 24: 55
                    Actuator for high pressure EGR: status-Bit 8: 2
                    High press EGR actuator: actual unconditioned volt val: 3.8 mV
4900 - EGR Sensor 1
          P0405 00 [039] - Signal too Low
                    Actuator for high pressure EGR: status-Bit 16: 0
                    High press EGR actuator: actual unconditioned volt val: 9.6 mV
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [039] - Malfunction
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [167] - Signal too High
5253 - Diesel Particle Filter; Differential Pressure Sensor
          P2452 00 [039] - Elect. Malfunction
                    Sensor for particle filter differential press: raw value: 1057 hPa
                    Particle filter: difference pressure: -3 hPa
                    Particle filter: offset for differential press.: 1 hPa
                    Particle filter: differential pressure: dynamic offset: 3 hPa
                    Particle filter: soot mass measured: 1.39 g
                    Particle filter: soot mass calculated: 10.49 g
12006 - Indicator Lamp for Start-Stop Operation
          P167A 00 [039] - Electrical Malfunction
4667 - Accelerator Position Sensors (G79) / (G185)
          P2138 00 [167] - Implausible Correlation
                    Accelerator pedal: sensor voltage 1: 1371.2 mV
                    Accelerator pedal: sensor voltage 2: 1380.0 mV
                    Accelerator pedal: switch positions-Bit 0: 0
                    Starter control: Interlock- or P/N-signal-Bit 0: 81
                    Limitation: torque: 0.0 Nm
                    Control Module temperature: 34.0 °C
5282 - Intake Air Temp. Sensor (G42)
          P0113 00 [039] - Signal too High
                    Exh.gas temp.sen 4: 346.1 °C
5290 - Throttle Actuator Control Circuit
          P2100 00 [167] - Open Circuit
                    Time: 00:00:00
                    Throttle valve adapter: specified value: 100.00 %
                    Throttle valve adapter: offset closed: -0.07 %
                    Throttle valve adapter: status-Bit 0: 0
                    Throttle valve adapter: status-Bit 16: 11
                    Throttle valve adapter: status-Bit 24: 50
                    Throttle valve adapter: status-Bit 8: 2
                    Throttle valve adapter: uncond voltage actual value: 4988.0 mV
5305 - Throttle Position Sensor (G69)
          P0123 00 [167] - Signal too High
                    Throttle valve adapter: status-Bit 16: 8
                    Throttle valve adapter: uncond voltage actual value: 4993.8 mV
5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [167] - Open Circuit
                    Charge Pressure Actuator: activation: 10.00 %
                    Charge Pressure Actuator: acknowledgment: 10.88 %
                    Turbocharger boost control: offset closed: 5.60 %
                    High press turbocharger actuator: status-Bit 0: 0
                    High press turbocharger actuator: status-Bit 16: 0
                    High press turbocharger actuator: status-Bit 24: 7
                    High press turbocharger actuator: status-Bit 8: 0
                    High press turbocharger actuator: actual uncond volt value: 994.4 mV
                    Accelerator pedal travel: 5.64 %
5557 - Body Control Module (Central Electric)
          U0140 00 [035] - No Communications
11060 - Body Control Module (Central Electric)
5615 - Door Control Module - Driver's Door
          U0199 00 [035] - No Communications
10092 - Neutral Gear Sensor
          P15A0 00 [035] - Electrical Malfunction
7027 - Software Incompatibility with Transmission Control Module
          U0302 00 [167] - -
                    Neutral position sensor: current transmission angle: 20.00 °
                    Neutral position sensor: adapted transmission angle: 0.00 °
                    Transmission neutral position sensor voltage: 0 mV
                    selected gear-Bit 0: 0
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [035] - -
4710 - No Communications with Airbag Control Module
          U0151 00 [035] - -
4713 - No Communication with ABS Brake Control Module
          U0121 00 [167] - -
                    Limitation: accelerator pedal: 92.4 Nm
                    CAN status - engine control module-Bit 0: 0
                    Cruise Control System (CCS): status-Bit 0: 206
                    CAN status - transmission control module-Bit 0: 0
                    CAN status - brake control module 1-Bit 0: 0
                    CAN status - brake control module 2-Bit 0: 0
4717 - Body Control Module (Central Electric)
4729 - Steering Effort Control Module
          U0130 00 [035] - No Communications
   Part No SW: 0BT 300 045 P    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H07 1803
   Revision: 00H07V01
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 42DCBB22E40601D70C5-8016
12 Faults Found:
10632 - No Communication with Gear Selector Module
          U0103 00 [047] - -
                    Time: 00:00:00
                    Coolant temperature: -40 °C
                    Clutch: primary stat: New
                    selected gear: GANG N
                    Driving position: P
                    Engine torque: 0 Nm
                    Control Module temperature: -12 °C
                    Accelerator position: 27.6 %
                    DTC memory status: 255
10633 - Selector Lever
          P0914 00 [040] - Electrical Malfunction
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10645 - Selector Lever
          P0919 00 [044] - Malfunction
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10647 - Selector Lever
          P0919 00 [040] - Malfunction
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10650 - Selector Lever
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10676 - Powertrain Databus
          U0001 00 [040] - Unspecified Malfunction
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10680 - Databus
          U1121 00 [047] - Missing Message
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10684 - Databus
          U1121 00 [044] - Missing Message
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10686 - Databus
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
10730 - Databus
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
17994 - Powertrain Databus
                    Fault Frequency: 8
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
          P1734 00 [047] - -
                    Mileage: 46739 km
                    Time: 00:00:00
                    Driving position: P
                    Engine torque: 0 Nm
Address 03: ABS Brakes
Address 08: Auto HVAC
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
   Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
   Component: J533  Gateway H43 1632
   Revision:   H43       Serial number: 020612F1000268
   Coding: 356303
   Shop #: WSC 33361 790 00075
   VCID: 40D8B12AEA8A13C71A1-8014
7 Faults Found:
01316 - ABS Control Module
                    Reset counter: 208
                    Reset counter: 208
                    Reset counter: 208
                    Reset counter: 208
00381 - Databus Instrument Cluster
                    Reset counter: 208
            000 -  -
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 208
Address 25: Immobilizer
Address 44: Steering Assist
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio
   Part No SW: 7N0 907 534     HW: 7N0 907 530 J
   Component: Batt.regelung H43 1632
   Coding: 030B185A
   VCID: 71BE24EE91A0CA4FA5F-8024
00458 - Control Module for Battery Monitoring (J367)
                    Fault Status: 01110100
                    Reset counter: 208
02252 - Generator
                    Fault Status: 00100011
                    Fault Frequency: 7
                    Reset counter: 248
                    Mileage: 33518 km
                    Date: 2027.14.00
                    Time: 08:40:57
02252 - Generator
                    Reset counter: 208
02252 - Generator
                    Fault Status: 00101100
                    Fault Frequency: 7
                    Reset counter: 248
                    Mileage: 33518 km
                    Date: 2027.14.00
                    Time: 08:40:57
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End----(Elapsed Time: 00:40, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
Many modern ECUs have transmission-specific software; i.e. the software part number will be different for an ECU that's meant to be used on a manual vs. an ECU that's meant to be used on an automatic. While these ECUs may have coding information that implies it's possible to change transmission types, if they have transmission-specific software, that software will reject a coding that it cannot accommodate with a "Request out of Range" error.
thunder
C?ID=304147
OK, so it has nothing to do with wsc and imp number etc?
In this case, I do not think so.
myounus
Northwest UK
C?ID=321059
UWE is most probably correct, although some modules are the same on both manual and auto models.
What is the part number of the module you are referring to. What model vehicle are you fitting this to? We can check the current part number and see if it is different for an auto. If it's an engine ECU then VCDS cannot code it as these are flashed with certain variables specific to the car. Contact a chipping tuner who may be able to help.
