- Aug 10, 2016
- 3,769
- 4,184
- Netherlands, eastern part
- C?ID=284912
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4407.4
Data version: 20171130 DS276.6
VIN: WV2ZZZ7HZHH100285 License Plate:
Mileage: 39550km-24575mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 25 3C 55 5F 61 69 0B
VIN: WV2ZZZ7HZHH100285 Mileage: 39550km-24575miles
Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KH HW: 04L 907 445
Component: R4 2.0l TDI H02 3805
Revision: 23002001
Coding: 0025401C437401080000
Shop #: WSC 36402 001 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KH 004003
ROD: EV_ECM20TDI03004L906056BM_004.rod
VCID: 7DA609A78D7DE39F317-8028
Readiness: N/A
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01
VCID: 3D26C9A7CDFD239F717-8068
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 43396000000214
Coding: 617E40982562847E8677027EA48721D278F700
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 40D8B053BA0F4E771A1-8014
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 02121613470315
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EA40EAB807BF88728D-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 S HW: 7E0 907 040 S
Component: ClimatronicT5 H04 0510
Revision: 00001K04
Coding: 0004000103
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 3332EF9FFBB9E5EF973-8066
Slave 1:
Subsystem 1 - Part No SW: 7E7 907 049 C HW: 7E7 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0011412160015212
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 344160092
Coding: 62A8393A0B21201201284F406CEB8E54C094738960CD79603204003F0860
VCID: 2A0CF2FB2CF3A427245-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 291116 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 N HW: 7E0 959 801 N Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0654
Serial number: KU0KU024111663290047
Coding: 0400A1
Subsystem 3 - Part No SW: 7E0 959 802 N HW: 7E0 959 802 N Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0654
Serial number: KU0KU001121663363179
Coding: 1400A1
Subsystem 4 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160002298500076464
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261631000661
Coding: 11810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BE2597C12597FFA5F-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 09121604392398
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361_SK34.rod
VCID: 3634D68BE8CBF0C7B0D-8062
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01R H08 0018
Revision: -------- Serial number: 003V4001TWLZ
Coding: 000000000000000000000000000000003152
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B22C7BFD3E92DAF4F3-806E
Serial number: 3495ZRB401G579TENH37
Serial number: 3505ZRB400U578J0AHS%
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 880 S HW: 7E0 920 880 S
Component: KOMBI H04 1105
Coding: 140F010300
ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
VCID: 3A2CC2BBDCD314A7545-806E
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2_VN75.rod
VCID: 2B02F7FF2389BD2FDF3-807E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
VCID: 688848F3F27F5637F21-803C
Component: IMMO H04 1105
VCID: 6A8C32FBECF36427E45-803E
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H08 0030
Serial number: 0422754843
Coding: 030311
Shop #: WSC 02739 790 50316
ROD: EV_LaneChangAssis_VN75.rod
VCID: 3038E0930AAFDEF7EA1-8064
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7E0 907 568 C HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0422544890
Coding: 030311
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Coding: 0FCA020001000000
Shop #: WSC 02748 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0359
Serial number: VWZAZ2S5402325
Coding: 06570001FF00000011111101008808031F0100C4002001004F
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 23121FDF4B59756F673-8076
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 530B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 75410903001609191828
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000443248299
Coding: 410D000103000000
VCID: 323CEA9B0423ECE79C5-8066
Address 0B: Sec. Air Heating Labels: None
Part No: 7E0 819 006 M
Component: J604 Standheizung 0401
Revision: L100400A Serial number: 00000000000000
VCID: 313EE5970D35D7FFE5F-5160
End----------(Elapsed Time: 01:33, VBatt start/end: 12.4V/12.4V)-----------
