I'm having the same problem as was encountered in this thread after retrofitting a Discover Pro Nav to my Mk7 Golf.
Currently using the latest stable release of VCDS (17.8.1), auto scan as follows:
Thanks in advance <3
Friday,29,December,2017,01:18:54:15053
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWZZZAUZFW063529 License Plate: NY14EYS
Mileage: 36173km-22476mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 5F
VIN: WVWZZZAUZFW063529 Mileage: 36173km-22476miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012034505092000
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F381B8A979EE0AFF3B-807A
2813 - Accelerator Position Sensor (G79)
P2122 00 [032] - Signal too Low
Mileage: 36092 km
Date: 2017.12.28
Time: 18:08:46
Coolant temperature: 87 °C
Intake air temperature: 69 °C
Voltage terminal 30: 12.600 V
Unlearning counter according OBD: 38
Accelerator pedal travel: raw value: 0.00 %
Accelerator pedal: sensor voltage 1: 772.0 mV
Accelerator pedal: sensor voltage 2: 371.2 mV
Accelerator pedal: switch positions-Bit 0: 0
Starter control: Interlock- or P/N-signal-Bit 0: 81
Limitation: torque: 0.0 Nm
Control Module temperature: 20.9 °C
2815 - Accelerator Position Sensor 2 (G185)
P2127 00 [032] - Signal too Low
Mileage: 36092 km
Date: 2017.12.28
Time: 18:08:46
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 61924000004104
Coding: 01FA8AA11426096F037C060241CC2580512890C06082A4F3F440F078C002
VCID: 0748932A5FAE98EF1BB-8052
Part No SW: 5G0 907 426 Q HW: 5G0 907 426 Q
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 392C25D259DA3E1F5DF-806C
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 160
Mileage: 36004 km
Date: 2017.12.27
Time: 13:09:35
Voltage terminal 30: 11.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Reset counter: 160
Mileage: 36154 km
Date: 2017.12.29
Time: 00:45:50
Voltage terminal 30: 13.7 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0134
Serial number: 01011419800065
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA4F1C20D72C23F317-8028
Component: WWS 140710 042 0551
Serial number: 140712045121
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y14M07D24H06M32S31
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1416330NQ
Serial number: 00000000000030073175
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331419901969
Coding: 0071051001
VCID: 3D2431C24DF2023F717-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 18071476510203
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
VCID: 382A20D662D02717A21-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0796S.
VCID: 7F580BCA077ED02F23B-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B18071470845
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B22071441063
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 107 14
Serial number: 357670000009E46DA01%
Subsystem 4 - Part No SW: ----------- HW: 480 002 107 14
Serial number: 3586700000079C61301P
Subsystem 5 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3516502BF15F3C32C17N
Subsystem 6 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3526502AB15F3C34C23I
Subsystem 7 - Part No SW: ----------- HW: 480 401 707 14
Serial number: 3556502A515F3C328318
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21071404400531
Coding: 0C00
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 7BA0FFDA1366CC0F0F3-802E
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 941 HW: 5G1 920 941
Component: KOMBI 204 4270
Coding: 27A51A002780060001883A011400000000000000
VCID: 6696BEAE78E461E7C0D-8032
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002258229
Coding: 030100040B087300EF00005C080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 42DE423E340C7DC70C5-8016
Component: E221__MFL-DC1 H16 0038
Serial number: 27140001791070034295
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0087543903
U1101 00 [009] - Active
Reset counter: 117
Mileage: 36092 km
Date: 2017.12.28
Time: 18:31:39
Supply voltage: Terminal 30: 12.2 V
Terminal 15: On
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 13071402090651
Coding: 00110220D001048000001000
VCID: 40DA48363A006FD71A1-8014
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003258255
Coding: 1D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DC4D32310A66DF15F-8014
Address 47: Sound System
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 12071401100511
Coding: 00110020DE01048000801000
VCID: 3FD84BCA47FE102F63B-806A
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003351145
Coding: 050000
Part No SW: 3G0 000 021 D HW: 3G0 035 021 E
Component: MU-H-LND-EU 053 0814
Serial number: A710A0XX002969
Coding: 02730001FF00000051111101008808101F0207F4012001009F
Shop #: WSC 00046 000 00000
ROD: N/A
VCID: 117CBD7221EAD65FC5F-8044
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H42 0022
Serial number: VWZ8Z9M23009SW
Subsystem 2 - Part No SW: V03 959 800 QQ HW: -----------
Component: ECE 2017 --- 0157
Component: Gracenote2--- --- 1015
No ASAM data for: "EV_MUHig6C3Gen2HBAS" (VW37)
23 Faults Found:
1555 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 117
Mileage: 1048574 km
Time: 00:00:00
13697024 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
15361024 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
2571 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
0512 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 157
Mileage: 1048574 km
Time: 00:00:00
0513 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 158
Mileage: 1048574 km
Time: 00:00:00
0517 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 157
Mileage: 1048574 km
Time: 00:00:00
0518 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 158
Mileage: 1048574 km
Time: 00:00:00
0522 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 157
Mileage: 1048574 km
Time: 00:00:00
0523 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 158
Mileage: 1048574 km
Time: 00:00:00
0527 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 157
Mileage: 1048574 km
Time: 00:00:00
0528 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 158
Mileage: 1048574 km
Time: 00:00:00
1637 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 117
Mileage: 36092 km
Date: 2017.12.28
Time: 18:32:39
3073 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
3084 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
2565 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
6720 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 120
Mileage: 36092 km
Date: 2017.12.28
Time: 19:13:48
5681 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
1564 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 160
Mileage: 1048574 km
Time: 00:00:00
6666 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 109
Mileage: 1048574 km
Time: 00:00:00
7193 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 117
Mileage: 36092 km
Date: 2017.12.28
Time: 18:31:57
7194 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 117
Mileage: 36092 km
Date: 2017.12.28
Time: 18:31:57
7201 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 117
Mileage: 36092 km
Date: 2017.12.28
Time: 18:31:57
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.2V)-----------
