A4 B6 Steering Wheel Controller
Graham
C?ID=313609
Hi all, new to all this VCDS stuff.
I have a 2004 A4 B6 Avant which I have retrofitted cruise control to. This is all working except that it throws up the following fault code
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
I've followed the instructions to start vehicle learning, but, although the box is highlighted, it won't allow me to enter the 00111 code to start learning.
Is it something I'm doing wrong?
Cheers,
Graham.
Graham
C?ID=313609
Here's my latest Autoscan complete with Engine Management faults.
Saturday,21,October,2017,17:00:33:44933
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Chassis Type: 8E (8EH - Audi A4 B6 (2004))
Scan: 01 03 08 09 15 16 17 45 46
VIN: WAUZZZ8E44A202712   Mileage: 215610km-133973miles
Address 01: Engine        Labels: 06D-906-018-AWA.lbl
   Part No SW: 8E1 910 018     HW: 8E1 906 018
   Component: 2.0L R4/4V FSI  G   0030
   Shop #: WSC 63251 000 00000
   VCID: 619CADB05D53525F344-5184
   Subsystem 1 - Part No: 8E0 907 807 B
   Component: NOX  0310090088 003 3205
   8E0907807B  NOX  0310090088 003 3205
7 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83)
            P1290 - 002 - Signal too Small - Intermittent
17480 - NOx Sensor (G295) Heater Control
            P1072 - 008 - Circuit Malfunction
16990 - Internal Control Module
            P0606 - 004 - Processor Fault - Intermittent
17987 - Throttle Actuator (J338)
            P1579 - 001 - Adaptation Not Started - Intermittent
17966 - Throttle Actuator (G186)
            P1558 - 002 - Electrical Malfunction - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
            P1171 - 008 -  - Intermittent
17976 - Throttle Actuator (J338)
            P1568 - 001 - Mechanical Failure
Readiness: 1010 0000
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0606
   Coding: 00101
   Shop #: WSC 63251
   VCID: 323E12FC4D3599C79DE-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   VCID: 3E2636CC8C6D4DA7696-5184
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 01042
   Shop #: WSC 06325
   VCID: 41DC4D30F893325F144-4B00
            35-00 -  -
   Part No: 8E0 920 950 N
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 02401
   Shop #: WSC 00186
   VCID: 343214E4B72197F78F2-5184
   WAUZZZ8E44A202712     AUZ6Z0C0460567
01304 - Radio
            49-00 - No Communications
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0704
   Coding: 00001
   Shop #: WSC 00186
   VCID: 6B80CF98AA9F080F9E8-5118
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 BD
   Component: Komfortgerát TBF    1511
   Coding: 32763
   Shop #: WSC 00186
   VCID: 74B2D4E4F7A1D7F74F2-4B00
01134 - Alarm Horn (H12)
01616 - Signal Wire to Interior Monitor
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.2V)-----------
Thanks again,
Graham.
Can you please explain in more detail what you mean by, "it won't allow me to enter the 00111 code to start learning"?
Graham
C?ID=313609
Coding: 01042
Shop #: WSC 06325
35-00 - - From the VCDS instruction manual
Audi A4 (8E) Steering Wheel
Contents [hide]
1 Coding
2 Adaptation
2.1 Channel 081: Vehicle Data Learning
Coding
0?xxx: Steering Wheel
0 = Standard (without Multifunction)
1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
2 = Multifunction Steering Wheel with Radio Control
3 = Multifunction Steering Wheel with Radio/Telephone Control
4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
5 = Multifunction Steering Wheel with Radio/Voice Control
0x?xx: Options
+1 = Tiptronic
0xx?x: Board Computer & Cruise Control
0 = Board Computer & Cruise Control not installed
1 = Board Computer installed
2 = Cruise Control installed
4 = Board Computer & Cruise Control installed
0xxx?: Rear Wiper (Chassis)
1 = Rear Wiper not installed (Sedan/Cabriolet)
2 = Rear Wiper installed (Avant)
Adaptation
To start the process for vehicle data (VIN) learning, enter/save 00111 as new value.
When in adaption for Module 16: Steering Wheel - Channel 081 has no stored value and it will not allow me to enter the 00111 code to enable vin code learning into either the new value or test value boxes. Also, both test and save boxes are greyed out.
Graham.
Did you click [Read] after entering 081 in the Channel box?
Graham
C?ID=313609
I did, but it still wont let me enter any value.
I will try and screen shot it tomorrow.
timknights
C?ID=330580
I am having a similar problem. Obtained a replacement steering control module 8E0 953 549 N (original was F) as part of a cruise control upgrade for my 2002 A4 B6. I got the VIN mismatch error and attempted to perform channel 81 adaption using the 00111 code in "new value". However, I found the "new value" field is grayed out (not a white input field anyway) and eventually gave up suspecting the module was defective. So I got myself another N module, and I am back in the same situation. I do not have a login code for the steering control module 16 (8E0 953 549N), is this my problem? do I need to find a login code before I can perform adaption? BTW, is it possible to post screenshots in this forum?
Lovitornot
Rwanda
C?ID=422289
I have followed this thread as I might have the same problem for my audi a4b6 avant.
I have replaced the comfort control module with a used one with same part number as in the scan report as below but when I enter the 00111 code as new value, it does not work.
Wednesday,17,March,2021,08:01:54:03107
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WAUZZZ8E63A016958 License Plate:
67 69 75 76 77
VIN: WAUZZZ8E63A016958 Mileage: 168570km-104744miles
Address 01: Engine Labels: 06B-907-557-ALT.lbl
Part No SW: 8E0 909 557 J HW: 8E0 909 057 A
Component: 2.0L R4/5VS 0001
Coding: 0011581
Shop #: WSC 63351 000 00000
VCID: 3A2CCCD8D04F5BEB817-5160
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FH
Component: V30 01J 2.0l 5V RdW 3011
Coding: 00001
Shop #: WSC 63251
VCID: 77AA15ECA6DD8683BE9-5160
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 03: ABS Brakes Labels: None
VCID: 55F67F645C1194938C5-51F2
No Faults Found
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
VCID: 2A0CFC9825EFEB6BF17-5160
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-00 - Blocked or No Voltage
35-00 - -
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
VCID: 3430E2E0F72BAD9B5BB-4B00
35-00 - -
Component: Airbag 8.4E 5001
Coding: 0010702
VCID: 74B022E0B2ABED9B9BB-5160
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
VCID: 3634D8E8E157BF8B65F-4B00
Part No: 8E0 920 930 K
Component: KOMBI+WEGFAHRS. RB4 D28
Coding: 02500
Shop #: WSC 00001
VCID: 2F3AED8C1E0D8E43269-5160
Subsystem 1 - Part No: 16958
Component: AUZ6Z0B0096908
16958 AUZ6Z0B0096908
01304 - Radio
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0619
Coding: 32767
Shop #: WSC 06802
VCID: 42DCB438BD9F132BD97-4B00
Component: Tõrsteuer.FS BRM 0002
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
VCID: 04507220E73BDD1BABB-4B5C
End----(Elapsed Time: 05:40, VBatt start/end: 12.2V/12.1V. VIgn 12.0V)-----
Lovitornot
Rwanda
C?ID=422289
67 69 75 76 77
Coding: 0011581
Coding: 00001
Shop #: WSC 63251
18265 - Load Signal
No Faults Found
Coding: 00000
Shop #: WSC 63351
35-00 - -
Coding: 00011
Shop #: WSC 63351
35-00 - -
Coding: 0010702
Coding: 00012
Coding: 02500
Shop #: WSC 00001
01304 - Radio
Coding: 32767
Shop #: WSC 06802
Coding: 00060
Shop #: WSC 63351
Yes, I did.
