Coding ABS module (Bosch 5.7)
Apexmaster33
C?ID=318501
Hello.
I just ordered the Ross tech cable. I need some help or how to code the ABS module on my 04 A4 Quattro.
Also with the cable is it possible to turn off the alarm or the beeping when locking/unlocking car?
Thank you
The first step to getting help is to post a full Auto-Scan once you get your cable. That gives important information on what module hardware & firmware is fitted to your car.
Yes, both of those things should be doable on a B6 A4. I would expect it to have a Bosch 5.7 ABS, so have a look at this page and watch the video linked at the bottom.
Apexmaster33
C?ID=318501
i read that I can do auto scan and copy the abs module, then paste it on the new one? but i already have the new module installed. I guess i can unplug the new one, and plug it on the old then do auto scan and copy.
Codings on those Bosch 5.7 modules are short enough that Copy & Paste isn't really necessary. However, it would not be a bad idea to see what the old module's coding was. You don't need to do a full Auto-Scan for that; just [Select] -> [03-ABS] and you'll see the coding. If you'd like to save it, go to [Fault Codes] and [Save Codes] even if there aren't any. That will record all of that control module's ID data (including coding).
Apexmaster33
C?ID=318501
Great thank you for fast reply and help.
Apexmaster33
C?ID=318501
hi guys, I received my Cable last night. im going to try to connect today . so Do I need to connect my old ABS module and do a autoscan 1st, or can I leave my new one in the car and fallow the procedure
Let's start with a scan from the car in its current condition.
Apexmaster33
C?ID=318501
Thursday,05,October,2017,17:48:59:43295
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Dealer/Shop Name: Atanas D
VIN: WAULT68E14A008323   License Plate: BFR6126
Mileage: 278430km-173008mi   Repair Order: RO#1
          67 69 75 76 77
VIN: WAULT68E14A008323   Mileage: 278430km-173008miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 L    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0010
   Coding: 0016711
   Shop #: WSC 63351 000 00000
   VCID: 3E25C0691C6D2407696-5160
8 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
            P1116 - 004 - Open Circuit - MIL ON
            P0300 - 002 -  - Intermittent
16687 - Cylinder 3
            P0303 - 002 - Misfire Detected - Intermittent
16690 - Cylinder 6
            P0306 - 008 - Misfire Detected - Intermittent
16686 - Cylinder 2
            P0302 - 002 - Misfire Detected - Intermittent
16688 - Cylinder 4
            P0304 - 008 - Misfire Detected - Intermittent
16689 - Cylinder 5
            P0305 - 008 - Misfire Detected - Intermittent
16685 - Cylinder 1
            P0301 - 002 - Misfire Detected - Intermittent
Readiness: 0110 1001
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 00000
   VCID: 26150809E1FD9CC7016-5216
            66-10 - Not Matched - Intermittent
            35-00 -  -
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 6393511DD24F29EF268-513C
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 63351
   VCID: 3537DF452C5BE75FB8C-4B00
01502 - Bulb for Rear Fog; Left (L46)
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   VCID: 372BD54D3357154FAA0-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 02041
   Shop #: WSC 63351
   VCID: 3E25C069196D2407696-4B00
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 03200
   Shop #: WSC 42336
   VCID: 323DE459DD35F0679DE-5160
   WAULT68E14A008323     AUZ6Z0C0185488
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BF2B5518838B7FA44-4B3C
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72BD24591DB5B0675DE-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
10 Faults Found:
01134 - Alarm Horn (H12)
            49-00 - No Communications
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
01559 - Drivers Door
            59-10 - Can't Unlock - Intermittent
01560 - Passenger Door
            59-00 - Can't Unlock
            80-00 - Single-Wire Operation
   Part No: 4Z7 907 357
   Coding: 00060
   Shop #: WSC 63351
   VCID: 0451728137318ED77F2-4B3C
00776 - Level Control System Sensor; Left Front (G78)
            28-10 - Short to Plus - Intermittent
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 8E0 035 195 H
   Component: symphony II NP2    0260
   Coding: 01005
   Shop #: WSC 85504
   VCID: 2C01FA21FF21A697D72-5042
00878 - Connection to Speaker Front Left
            36-10 - Open Circuit - Intermittent
End----(Elapsed Time: 05:55, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
Apexmaster33
C?ID=318501
hey guys i fallowed the video provided but i am getting the these codes
Thursday,05,October,2017,18:12:41:43295
VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
Atanas D
Control Module Part Number: 8E0 614 517 A
Component and/or Version: 8E0614517A ABS/ESP allr
Software Coding: ad 1726
Work Shop Code:
VCID: 26150809E1ED9CC7016-5216
35-00 - -
Apexmaster33
C?ID=318501
so i get pass login, and coding, i fallow video to a T I enter 12345 for the 2nd row codes. then i click do it. next i go login again and enter the 40168 for the steering angle calibration, and click do it, and it just go back to main ABS screen. it does not take me to calibrate. also how can i turn wheel with car off. its really hard
Atanas D
Work Shop Code:
35-00 - -
Huh?
I believe these would be correct for this car (assuming it has PR code 1LT or 1LF for the brakes):
Login: 09395
Coding: 04495
Apexmaster33
C?ID=318501
yes it is 1LF for brakes. i will try again today and let you know.
Apexmaster33
C?ID=318501
Hey guys so after input login and coding I get a numbers and letters on the soft code from 00000 to ad1726 but where it says shop# I still have nothing. So I'm not sure why this is happening. Im inputting the correct valued for login and code
Scratching head. Never seen or heard of "ad1726" appearing in the coding field for one of these.
stevecrk
Budapest, Hungary
C?ID=59799
In your autoscan, the component information is truncated.
"Component and/or Version: 8E0614517A ABS/ESP allrad 1726" would make sense.
Why the end of the component information is displayed in the software coding field?
Apexmaster33
C?ID=318501
Not sure. What to do next or try??
What should I do?
Every customer gets one free car-repair support ticket. I'm going to suggest you call us during business hours, open your free ticket, and have someone talk you through this over the phone. You'll need to to have your PC connected to the car when you call.
Apexmaster33
C?ID=318501
So I was able to get the correct code under soft code now and under shop# it say wsc00000. I also calibrate steering says ok. And showing no fault code but still have ABS light on.
Btw I also have issue w brake dash light flashing . book says it has to do with low brake fluid but I'm top up to max. I noticed with ignition when the brake light starts flashing it break connection between vsdc for a split second then it starts again
