Secondary Air readiness
sfojimbo
Banned
C?ID=314013
2003 Jetta GTI Vr6
My secondary air system is not ready, so I cannot smog my vehicle. That's why I bought Ross-Tech.
The air pump runs when the engine is doing a cold start - it blows lots of air through its discharge hose.
When I run the set readiness routine it hangs.
When I run block 077 it says "abort"
There are no DTCs set.
What can I do to get readiness set or at least get some information as to why it the Ross-Tech software aborts?
TY
VCDS isn't aborting, the green text you see is from the control module in the car. Abort can happen for a number of reasons but prerequisites that aren't met, pending DTCs or sensor readings (perhaps MAF in this case) that are implausible would be most likely. In less common cases tuning (chipped control unit) may prevent a test from running.
Please let us know which DTCs were stored before the readiness was cleared in addition to any new parts that may be installed. The Auto-Scan would be helpful as well.
Gone But Not Forgotten
Hello and welcome to the VCDS forum, I am NostraJackAss........ the forums resident asshole .....I'm pleased to meet you.... :rolleyes:
I have some ideas .........PLEASE start with posting an auto-scan.
The JPPSG
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
The VR6 SAI is funny and depending on AFP ME7.1 or BDF ME7.1.1 can be in a learn loop or be difficult.
Sometimes some jerkoff reverses the vacuum lines for the intake flap with the SAI noids to combi valve..........and doing exactly what you describe but so does a MAF or brake light switch like Dana aforementioned.
sfojimbo
Banned
C?ID=314013
There were some DTCs a week or so ago that were meaningless for this question. But today (after replacing the stick transmission) when I returned to the readiness problem there were no codes set at all.
All the other readiness components come up OK. The MAF flow shows and it's something like 3.5 GPM, that seems OK.
I just ran a scan so now I'll retrieve it from my laptop and set out to posting it here. (I notice that it stopped at test 76)
Thanks for your reply
sfojimbo
Banned
C?ID=314013
Jack, here's the scan
Tuesday,05,September,2017,16:00:48:34562
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: 3VWVH69M23M147751   License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWVH69M23M147751   Mileage: 273460km-169920miles
Address 03: ABS Brakes        Labels:
   VCID: 55F489D4DD19268F58C-5184
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 2708F31CB6F5641F3A0-5160
   Part No: 1J0 920 906 J
   Component: KOMBI+WEGFAHRSP VDO V64
   Coding: 07234
   VCID: 2F381B3C9E053C5FF20-5160
   3VWVH69M23M147751     VWZ7Z0C6853944
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70BAD84043BB63A7ABA-5160
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 3728235C6655F49FAA0-4B1E
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Component: 1H Tõrsteuer.HR KLO 0009
            27-00 - Implausible Signal
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 E
   Component:    Radio ZSW        0010
   Coding: 00031
   Shop #: WSC 00066
   VCID: 221EE208DDD781376DE-5160
End----(Elapsed Time: 05:15, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
-YO yo yo....no Engine 0x01 or ABS 0x03 in the scan dude...........
Is this car modified..........?
BDF it is ...... 022-906-032CS ME 7.1.1
Activated carbon canister 1E4 Activated charcoal canister acc. to ORVR and siphoning device for filling up
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B3 Child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UB Air bag for NAR
Air duct, front area VK1 Air duct, type 1
Antennas 8L3 Roof antenna
Anti-theft protection system 7AG Electronic alarm system with vehicle immobilization device (for USA)
Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Backrest release 3H0 Without backrest release for front seats
Base engine T9T 6-cylinder gasoline engine 2.8 L unit 022.A
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C1 Body measures for increased safety requirements
Body style K8B Notchback
Brackets 3P0 Without bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1ZD Disc brakes, front (Geomet D)
Brake type, rear 1KX Disc brakes, rear (Geomet D)
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JL Comfort bumpers
Carrier frequency for radio remote control 5D2 Carrier frequency 315 MHz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
CD changer/CD player 7A1 CD changer preparation
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C8 3-point seat belt, center rear with US label
Chassis 2E0 Base chassis
Child seats QA0 Without child seat
Chrome work package QJ0 Without aluminum/chrome work package
Component part sets with country-specific design requirements B0D Component parts set, complying with vehicle type for USA (without California), various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T2 Cruise control system (CCS) electronic
Cup holder 4M2 Cup holder in center console front and in tray rear
Door and lid locking system 4K0 Radio remote controlled central locking operated from inside
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GM Emission standard LEV 1
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z7 Cold country
Engine specifications MR0 6-cyl. gasoline eng. 2.8 L/147 kW 24V VR6 LEV base engine is T9T
Equipment levels A8W Luxury equipment
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Exterior noise suppression measures 2B8 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
Flame retardent materials 4Q1 Flame retardent materials
Floor coverings 3MH Dilours floor covering w/o scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W3 License plate bracket front (small, NAR)
Front seats Q4P Sports front seats
Front stabilizer 0AE Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W2 Fuel filler cap, attached (NAR)
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8BL Halogen headlight for driving on the right US design
Headlight activation 8K4 Separate daytime running lights NAR
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q0 Without headlight-range adjustment
Headrests 5ZH Headrests for front seats, articulated and height-adjustable with integrated release function
Heat accumulator system/additional heater 7E2 Heated crankcase ventilation system
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AB Manually controlled air conditioning
Horns 8Y1 Two-tone horn
Identification plates 1EB Without identification plate
Ignition/starter switch locking system 0RB Ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MA Decorative inserts
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Instrument inserts U0F Instrument insert with tachometer clock and mph speedometer
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Key for locking system 8QE Key for locking system with remote control
Left exterior mirror 5SH Left exterior mirror: flat (US)
Left vanity mirror 4SQ Left vanity mirror illuminated with cover and special mirror imprint (NAR)
Lock operation for tailgate/trunk lid 4E2 Tailgate/trunk lid release from inside (electrically)
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 3U0 Without luggage compartment cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lining 5A7 Gepäckraumauskleidung Komfort mit Serviceklappe
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Molding roof liner 6NG Molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 0NQ Nameplate set "GLI"
Nameplates for sales name QD3 Schriftzug f. Verkaufsbezeichnung
Navigation device 7Q0 Without navigation device
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Owner's manuals 0VM Information kit in American English
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K5 Transportschutzfolie (anstelle Lackkonservierung)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P1 Rear floor panel module, type 2
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KC Radiator grille
Radios 8US Radio "Premium" (double-size standard radio)
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TA Without rear fog light
Rear headrests 3Q6 Three rear headrests
Rear license plate bracket 6P2 License plate bracket, rear (NAR)
Rear seat catch 6QB Locking rear seat catch
Rear seats 3NF Rear seat bench/backrest, split folding locking
Rear stabilizer 0BB Rear stabilizer
Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
Restraint systems, front 4QQ 3-point seat belts with tensioner height adjustment and US label front
Right exterior mirror 5RR Right exterior mirror: convex (US)
Right vanity mirror 4TQ Right vanity mirror illuminated with cover and special mirror imprint (NAR)
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P7 Seat belt reminder, optical and acoustic electric contact in buckle
Seat covering N6C Fabric seat covering (NAR/Mexico)
Seat heater 4A0 Without seat heater
Service interval prolongation QG0 Without service interval prolongation
Shock absorption, chassis, front G77 Front shock absorption
Shock absorption, chassis, rear UA9 Rear shock absorption, sports version
Side air bag 4X8 Side air bag front with head air bag and optimized head impact elements (USA)
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R4 Side turn signal and marker lights (turn signal lights with white lens)
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G1 Space-saving spare wheel
Speaker installation 9VG Sound system "Monsoon"
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SC Labels/plates in English
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering QZ3 Power steering (limited steering lift mechanism)
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tire suppliers V0A Tires w/o specification of tire brand
Tires H7K All-weather tires 225/45 R17 91H (NAR)
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Tray 7N0 Without tray on roof liner
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Type approval countries/countries with special requirements B34 Legal requirements USA
Vehicle class differentiation units/platform components 0CM Vehicle class differentiation 1JM
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L39 Suspension range 39 installation control only, no requirement forecast
Wheel covers 1NL Covers for alloy wheels
Wheels CD1 Leichtmetallräder 7J x 17 1J0 601 025 J, ET 38
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PS4 SOUND SYSTEM MONSOON AND SUNROOF
Vehicle Identification No. 3VWVH69M23M147751
Model Jetta GLS VR6 JEM
Date of production 05.03.2003
Year 2003
Sales type 9M25W6
Engine Code BDF
Transmission Code FSR
Axle drive 6S
Equipment RD
Roof color 2R
Exterior color / Paint Code 2R / D7X
sfojimbo
Banned
C?ID=314013
I don't know what this means.
sfojimbo
Banned
C?ID=314013
Not that I can tell
You need to fix the communication error and I suspect something up with the ABS ....on K line please JPPSG check fuses and issues at hand with WD and RTFB.
Get the manual at Erwin
sfojimbo
Banned
C?ID=314013
Are you saying that a braking system problem can cause a secondary air system to fail to come ready?
The brakes seem fine and there are no faults after all.
sfojimbo
Banned
C?ID=314013
duplicate post
Yup it can because a COM issue can be circulating on the network preventing a test to commence or in this case the ESP is linked to the ECU for load requests which will block a path.
In this case it could be other issues but tests need to be observed not just stated.
Let's starts with the scan data which is missing.........
sfojimbo
Banned
C?ID=314013
I'll run the scan again.
I may have botched that one.
sfojimbo
Banned
C?ID=314013
Sorry about that, here's the real scan:
Tuesday,05,September,2017,17:16:49:34562
          75 76
Address 01: Engine        Labels: 022-906-032-BDF.lbl
   Part No: 022 906 032 CS
   Component: MOTRONIC ME7.1.1G   0006
   Coding: 00032
   Shop #: WSC 26078
   VCID: 5EE696F8A92FE5D7096-5184
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 3432145072231F878F2-5184
   Coding: 12340
   Shop #: WSC 00066
   Coding: 07234
   Coding: 00006
   Shop #: WSC 00066
   Coding: 00258
   Shop #: WSC 00066
   Coding: 00031
   Shop #: WSC 00066
End----(Elapsed Time: 05:13, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Component: MOTRONIC ME7.1.1G 0006 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Ahhhh Update needed for bug in controller.
Coding: 00032
Shop #: WSC 26078
Programming update 1482 or higher & which you are not at...........This is why we JPPSG!
Can you do me a favor & reset the DTC's ( fault codes ) and repost the scan one more time?
Let's default the controller too and recode with alternate WSC to verify it took please....use same coding value of 00032
CAT monitor in this controller should not be completed before the SAI test in this diagnostic stack........
sfojimbo
Banned
C?ID=314013
Rev 3 There were no faults, but I cleared faults anyway
Tuesday,05,September,2017,17:55:35:34562
          75 76
   Coding: 00032
   Shop #: WSC 26078
Readiness: 0110 1101
   Coding: 0019970
   Coding: 12340
   Shop #: WSC 00066
   Coding: 07234
   Coding: 00006
   Shop #: WSC 00066
   Coding: 00258
   Shop #: WSC 00066
   Coding: 00031
   Shop #: WSC 00066
End----(Elapsed Time: 05:09, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Okay great now change the WSC to something else anything and recode 0x01-07- code with 00032 + then go 0x01-10-00 clear save
Now also do a TV ADP 0x01-04-060
Post the new data and then run readiness test script again and tell me where it stalls.......
Report back to me if this car supports an auxiliary brake vacuum pump located behind the rack to booster?
Also battery voltage is for shit in this car.......
sfojimbo
Banned
C?ID=314013
Please clarify:
recode 0x01-07- code with 00032 + then go 0x01-10-00 clear save and Now also do a TV ADP 0x01-04-060
