I'm sure there could be many other causes, however this one has an extended warranty for the issue.
Audi issued a TSB on August 29th, 2013. TSB 2033768
A cylinder misfire fault (DTC P0301 – P0306) with DTC P130A is stored in the engine control module (ECM),
J623 (address word 01). Audi Solution: Call the TAC for further instructions.
Carbon buildup is restricting the flow of air to the cylinders, usually 5 or 6 to the point that they don't fire under heavy load.
The car gets multiple misfires due to the air/fuel mix being off significantly enough to cause the problem.
The good news. 2011 - 2013 3.0t motors have been issued a 10 year/120K mile extended warranty for the problem. Y
ou should get a DTC for P0301, P0302, P0303, P0304, P0305, P0306 showing the misfire and then a P130A.
It only happens under heavy load, if you clear the DTC the problem goes away and it drives normally again.
Clear the code, drive normally, readiness sets, no issues. Break 4K RPM under heavy load, DTC comes back.
Has anyone tried Meth/water injection to keep the issue from reoccurring?
Andy
AZ
Andy
AZ
