Results 1 to 10 of 10
Thread: Audi S4; Misfire, Cylinder disabling
    Nov 2016
    2014 Audi S4 Avant, driving normally then suddenly develops a misfire and loss of power, EPC light comes on. Fortunately just a few miles out so 'limped' home.
    Ran auto scan and got the following;
    Tuesday,14,November,2017,15:06:35:24986
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ8K7EA150192   License Plate:
    Mileage: 36420km-22630mi   Repair Order: misfire
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
              62 6D 72 A9
    VIN: WAUZZZ8K7EA150192   Mileage: 36420km-22630miles
    Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 D    HW: 4H0 907 551
       Component: 3.0l V6 TFSIX07 0004
       Revision: --X07---
       Coding: 12250034052701020800
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
       ROD: EV_ECM30TFS0218K5907551D.rod
       VCID: 377CA0AB8E2C1EFE7B-8062
    6354 - Cylinder 5
              P0305 00 [101] - Misfire Detected
                        Mileage: 36418 km
                        Date: 2017.11.14
                        Time: 14:53:26
                        Engine speed: 4950.00 /min
                        Normed load value: 91.0 %
                        Vehicle speed: 109 km/h
                        Coolant temperature: 95 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 14.218 V
                        Engine speed: actual: 4928 /min
                        MAF_ENVD: 1024.04703 mg/stroke
                        Coolant temperature (unfiltered): 95.25 C
                        Engine: operating status: PL
                        T_AST_ENVD: 642.50 s
                        Vehicle speed: actual: 109 km/h
    7948 - Cylinder Disabling
              P130A 00 [101] - -
                        Mileage: 36418 km
                        Date: 2017.11.14
                        Time: 14:53:26
                        Engine speed: 5008.00 /min
                        Normed load value: 74.5 %
                        Vehicle speed: 111 km/h
                        Voltage terminal 30: 14.319 V
                        Engine speed: actual: 5088 /min
                        MAF_ENVD: 1029.49409 mg/stroke
                        Vehicle speed: actual: 111 km/h
       Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H03 0003
       Revision: --H03---
       Coding: 000001
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDL501021.rod
       VCID: 387EA3978332118672-806C
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 291DCC01
       Shop #: WSC 06335 000 00000
       VCID: 09181653A058D80EDD-805C
       Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
       Component: BCM2 2.0      H14 0650
       Coding: 01B24040000000000000
       VCID: 7EF2758FE996EFB6F8-802A
       Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
       Serial number: 0514000046830011
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 0214000068278002
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: D1000000    Serial number: 01100420140302
       Coding: 6624028000
       VCID: 78FE6397CBB2D186B2-802C
       Revision: 08016001    Serial number: 00000789946701
       Coding: 260000108034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 010414  H06 0080
       Serial number: SWF14044015610
       Coding: 00FD11
       Serial number: 22487512
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000104144832
       Serial number: FA780227000000000001
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC0WUTP
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 60782 001 1048576
       VCID: 489ED357F3D2610602-801C
       Serial number: 6334MSME443A333AD
       Serial number: 6344MSME443C6E75T
       Serial number: 6352QSME1E400648E
       Serial number: 6362QSME1A401B6EP
       Serial number: 63732SME40404A66X
       Serial number: 63832SME4F400F689
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NDE001IC
       Coding: 000037
       VCID: 489ED357FBD2610602-801C
       Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZAE62M34F
       Coding: 33A7110003012600010000
       VCID: 4580DA63CCC07C6EF9-8010
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y143310158
       Coding: 80CF07FF00
       VCID: 4A9AE95FE5DE931614-801E
       Serial number: 9802233103
       Serial number: 14099003849011200410
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000084090
       Coding: 01010101000000000001000102
       VCID: 2D5082C37470A42E11-8078
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0077
       Revision: AA000000    Serial number: 00000097259421
       Coding: 01781300000000000000
       VCID: 3B74BC9BBA043A9E9F-806E
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000098884238
       Coding: 011C02205E21410001
       VCID: 4FACF84B1EBCB63E43-801A
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0003457337
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3560AAA39420ECEE69-8060
       Revision: 00002001    Serial number: 0332027708
       Coding: 013B0622A0B938948330023680000047
       Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J245 PS151  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
       Revision: 00005001    Serial number: 94813028507104
       Revision:             Serial number: 0000098720192
       VCID: 4E92E54F19B6BF3648-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 20000000431915
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3A7AB99FBD3E039684-806E
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109D20E7915856
       Coding: 010103010000000001
       VCID: 285E73D75B928106E2-807C
       Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
       Component: H-BN-EU       H47 0793
       Revision: --------    Serial number: 206DZ0E7560780
       Coding: 110101010206A1ED41808B5E00000403E40100020000000000
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Component: DU7 High  H42 0104
       Serial number: A130DI0E3000809
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001824649
       Component: CD-Database  5571
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000098922402
       Coding: 010C02204021210001
       VCID: 4682DD6FF1C67776F0-8012
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E72B58FA9162FB6B8-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H53 0330
       Serial number: 8K9827852C
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000098919842
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 140301200807
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 72EA51BFA5CEBBD68C-8026
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Not had any previous problem, so I reset all DTCs and it is all OK again. went for a test drive and everything seems fine.
    So, anyone got any ideas - spark plug, coil pack? also when looking at the engine from the front, which is cylinder 5?
    Thanks in advance for any help.
    2014 Audi S4 Avant, 'black edition'.
    Component: 3.0l V6 TFSIX07 0004 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update required 0005 or higher!
    JPPSG ............
    Nov 2016
    Thanks for the reply, can you elaborate what the firmware update is?
    Sure go to ERWIN and download the TSB's from the RTFB and observe them.
    Here is a link..........
    https://erwin.audi.com/erwin/showHome.do
    Nov 2016
    OK, might be a bit above what I'm trying to do here. It has been OK for 3 years so not sure a firmware update is going to make any difference.
    I'm thinking along the lines of a possible coil or sparkplug fault although it seems OK now it must have detected something? Just a bit worrying that it shut down the cylinder - don't know if it would have restarted with a simple off/on ignition as I reset the DTCs first - I'm not sure I'd want to drive it any distance with a cylinder shut down?
    Never hurts to check basics such as compression and normal tune up stuff but dismiss the JPPSG all you want and carry on.
    You may find yourself in a loop by skipping TSB's, or important diagnostic steps........
    So you can work longer, so you can buy more parts, so you can possibly achieve no MIL!
    Good luck or JPPSG
  7. Likes Zenerdiode liked this post
    Nov 2016
    Following up on this; I had the same fault again about a week later under exactly the same conditions, only this time it also reported "16903 - Vapor Bubble Formation in Low-Pressure Fuel Circuit" along with the cylinder 5 misfire and consequent cylinder shutdown? Don't know this is related to the misfire? (consequence, cause etc.) but again it was OK after a restart.
    Not wanting to get too deep into investigations in a cold garage, I had already bought a new coil so fitted this to cylinder 5 that day and it has been fine since.
    On the advice of another member I also logged misfires on all cylinders from engine start to engine stop on a run with plenty of hard acceleration and whilst there were a few randomly distributed recorded misfires, there was nothing serious enough to shut anything down (how many are too many?). Now in hindsight I should have done this before swapping the coil, or even swapped the coil to another cylinder? But I didn't and (for now at least) it's running fine so I'm not planning to swap it back.
    I also pulled out the spark plug whilst there and it looked fine, maybe I should change them but as it's running OK I'll wait, at least, until the next service although the schedule doesn't call for plug replacement for a good few miles anyway? and I'll enquire about the Firmware update the next time I'm at the dealer.
    Hopefully any carbon buildup issues are a good few thousand miles away yet...
  9. #8
    Mostly out of curiosity:
       Revision: --X07---
    Is the engine chipped?
  10. Likes Uwe, Jack@European_Parts liked this post
  11. #9
    Nov 2016
    Yes, stage 1 Revo map, switchable between stock and performance modes.
  12. Likes Eric, Jack@European_Parts liked this post
  13. #10
