Hi, I just purchased the Ross-Tech to diagnose my wife's 2007 Q7.
It has a few strange issues, the main cooling fan starts when I first start the vehicle and runs at full speed (no modulation) until well after the vehicle has been shut down, the vacuum pump also runs that entire time as well as after the vehicle has been shut down.
Because of this, the battery is always flat, I can charge the battery and leave it disconnected and it is fine, I completed a load test on the battery and it is still in good shape. The alternator also seems to be working fine, but because of the power draw by the fan and the vacuum pump the battery dies when driven normally.
I believe the lawn sprinklers hitting the front of the car might have damaged the ecu.
I will post the dump from my first diagnostic. Any advice would be great.
Saturday,05,August,2017,09:58:49:59327
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WA1BV94L97D075747 License Plate: TRICIA
Mileage: 128320km-79734mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 3C 42
46 47 4F 52 55 56 61 62 65 67 69 6C 6D 6F 72 76 77
VIN: WA1BV94L97D075747 Mileage: 128320km-79734miles
1E-Media Player 2 -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0040
Revision: 71H21--- Serial number:
Coding: 01210009190F0D60
Shop #: WSC 31414 790 00001
VCID: 280AF0C5BEFD60B733A-807C
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
012434 - Internal Control Module
P3092 - 004 - Memory Check Sum Error - MIL ON
Fault Status: 11100100
Mileage: 128328 km
Date: 2006.05.16
Time: 06:30:47
RPM: 1151 /min
Load: 55.3 %
Temperature: 32.0°C
Temperature: 32.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.208 V
P0300 - 001 -
Fault Status: 01100001
Mileage: 128328 km
Date: 2006.05.16
Time: 06:31:42
RPM: 714 /min
Load: 49.4 %
Temperature: 45.0°C
Temperature: 32.0°C
Voltage: 13.208 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected
Mileage: 128328 km
Date: 2006.05.16
Time: 06:31:42
RPM: 714 /min
Load: 49.4 %
Temperature: 45.0°C
Temperature: 32.0°C
Voltage: 13.208 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected
Mileage: 128328 km
Date: 2006.05.16
Time: 06:31:42
RPM: 714 /min
Load: 49.4 %
Temperature: 45.0°C
Temperature: 32.0°C
Voltage: 13.208 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FQ HW: 09D 927 750 FQ
Component: AL 750 6A 0999
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 025E826D78016AE74DE-8056
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0021553
Reset counter: 181
Mileage: 128328 km
Date: 2006.05.10
Time: 13:16:47
Count: 128
Count: 12549
Count: 297
Count: 49408
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:37:06
Count: 14597
Count: 128
Count: 34816
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100630142
Coding: 0000135
VCID: 6390A7E9875BC3EF268-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.10
Time: 13:32:04
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.10
Time: 13:32:04
Reset counter: 182
Reset counter: 182
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 F HW: 4E0 035 729 A
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 354LY067516085
Coding: 0002003
VCID: 2B000FC9AF0B4BAFDE8-807E
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000624011
Subsystem 3 - Serial number: 0103.01.070000000100010679ÿ
Subsystem 4 - Serial number: 010679ÿ
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:39:48
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030021428
Coding: 0786472
VCID: 619CADE19D47D1FF344-8034
02874 - Control Module 2 for Central Convenience (J773)
Fault Status: 01101000
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.10
Time: 13:24:52
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:37:11
Voltage: 9.50 V
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:40:23
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0113123
VCID: 303A18A5862D2877EBA-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Reset counter: 182
Mileage: 128320 km
Date: 2017.07.13
Time: 16:31:00
Fault Status: 00100001
Reset counter: 218
Mileage: 128320 km
Date: 2017.07.11
Time: 18:37:00
Reset counter: 182
Mileage: 128320 km
Date: 2017.07.13
Time: 16:31:00
Reset counter: 218
Mileage: 128320 km
Date: 2017.07.11
Time: 18:37:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBG1027622
VCID: 1D64D111E1BFB51F50C-8048
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0033299
VCID: 2C020CD5AA054C97D72-8078
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 72 AIRBAG AUDI8RH41 0230
Revision: 05H41000 Serial number: 0038QD0505P%
Coding: 0014130
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME1B323C39J
Subsystem 3 - Serial number: 6342QSME1C5A416DS
Subsystem 4 - Serial number: 6352QSME1C5A1477O
Subsystem 5 - Serial number: 6362QSME1B2D292DV
Subsystem 6 - Serial number: 63734SME1F33246D5
Subsystem 7 - Serial number: 63834SME19142E752
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
002 - Lower Limit Exceeded - MIL ON
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90055063360356
Coding: 0012242
VCID: 2708F3F9B3E36FCF3A0-8072
Component: E0221 H07 0090
Reset counter: 222
Mileage: 128328 km
Date: 2017.07.16
Time: 18:22:46
Reset counter: 222
Mileage: 128328 km
Date: 2017.07.16
Time: 18:23:41
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0120
Revision: 00800000 Serial number: 5HH30E817
Coding: 2673268
Shop #: WSC 22150 444 123744
VCID: 2310E7E9C7DB83EF668-8076
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:39:58
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B2780B5
Coding: F7F7FE7F747A02
Shop #: WSC 19124 444 83960
VCID: 6C82CCD56A858C97972-8038
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 6594B9F1856FBDDFC8C-8030
Reset counter: 221
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000091610
Coding: 0000006
VCID: 688AB0C57E7DA0B7F3A-803C
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.10
Time: 13:24:52
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.10
Time: 13:24:57
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:37:16
Voltage: 9.60 V
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015520
VCID: 2A0E0ACDA0F152A725E-807E
Fault Status: 11100010
Reset counter: 182
Error Code: 13
Reset counter: 222
Error Code: 12
Fault Status: 11101101
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:42:25
Error Code: 98
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Reset counter: 222
Date: 2006.01.01
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 313JW067508809
Shop #: WSC 22302 444 85830
VCID: 382A20856E5DF037A3A-806C
Reset counter: 221
Mileage: 128328 km
Date: 2017.07.16
Time: 18:23:55
Hex Value: 0x4461
Hex Value: 0xD66F
Hex Value: 0x0046
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0010001
VCID: 2D0401D1911F459FC0C-8078
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F06.12.0600H0600000010003ÿ
Subsystem 4 - Serial number: 010003ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Fault Status: 01101110
Reset counter: 178
Mileage: 128320 km
Date: 2017.07.11
Time: 19:31:41
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Reset counter: 182
Mileage: 128320 km
Date: 2017.07.11
Time: 19:31:47
Reset counter: 182
Date: 2006.01.01
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
VCID: 2F381BD99B13378FF20-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01029556740000
Coding: 7632925
VCID: 313C1DA18D27217FE44-8064
02957 - Lamp in Trunk/Hatch Lid; Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 182
Mileage: 109030 km
Date: 2016.06.25
Time: 15:45:10
Bin. Bits: 000 011
02956 - Lamp in Trunk/Hatch Lid; Left
Reset counter: 182
Mileage: 126751 km
Date: 2017.05.19
Time: 19:18:19
Bin. Bits: 000 001
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000012685
Coding: 0000026
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:43:08
Voltage: 8.40 V
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000066737
Coding: 0012001
VCID: 5EE6961DAC39EE07096-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: …t1
Coding: 0051915
Fault Frequency: 8
Reset counter: 182
Mileage: 128322 km
Date: 2017.07.11
Time: 19:31:47
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
VCID: 290CF5C1A5F759BF2C4-807C
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388L.067580521
Coding: 0000002
VCID: 2E0606DD9C193E87F96-807A
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:43:29
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000073424
VCID: 6492A4F58255C4D7DF2-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 3103066053
Coding: 344630393135313035442056413033313033303636303533
Shop #: WSC 22145 444 96597
Fault Frequency: 42
Mileage: 128322 km
Date: 2017.07.11
Time: 19:35:43
02256 - Quiescent Current
Reset counter: 222
Mileage: 128322 km
Date: 2017.07.12
Time: 02:09:06
Reset counter: 222
Mileage: 128328 km
Date: 2006.05.10
Time: 12:15:41
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Reset counter: 182
Mileage: 128322 km
Date: 2017.07.11
Time: 19:32:00
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700038945
Coding: 0062424
VCID: 221EE2EDD8C18AE76DE-8076
002 - Lower Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100010
Reset counter: 221
Mileage: 128328 km
Date: 2006.05.10
Time: 12:03:01
(no units): 255.0
Voltage: 6.90 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:40:24
(no units): 0.0
Voltage: 9.00 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000612070059
Shop #: WSC 12336 024 394758
VCID: 343214B5723514578F2-8060
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:39:54
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000002
VCID: 2412E4F5C2D584D71F2-8070
Reset counter: 187
Mileage: 262140 km
Date: 2023.06.05
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Y43E5
Coding: 1001001
Reset counter: 182
Term 15 Off
Reverse OFF
Count: 3
Reset counter: 182
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD15.12.06--H21001001A0169ÿ
Subsystem 4 - Serial number: 1A0169ÿ
Fault Frequency: 0
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:43:22
Reset counter: 182
Mileage: 128328 km
Date: 2017.07.16
Time: 18:23:40
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No HW: 4L0 907 290 A
Component: MROLLO NO RESPONSE
Revision: AAH05061 Serial number: 002275230-----
Coding: 0003595
VCID: 55F48931D90F2D5F58C-8000
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
02906 - Control Module for Sliding Roof; Rear (J392)
Fault Status: 01100101
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 05:00:01
02907 - Control Module for Roof Shade (J394)
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 05:00:01
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 05:00:01
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:40:16
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Reset counter: 182
Mileage: 128328 km
Date: 2006.05.16
Time: 22:44:20
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230633500570
Coding: 0031246
Reset counter: 221
Mileage: 128328 km
Date: 2006.05.10
Time: 12:02:51
Reset counter: 182
Mileage: 128322 km
Date: 2017.07.11
Time: 19:31:47
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005080187
Coding: 0010900
Shop #: WSC 55581 000 1048576
Reset counter: 182
Mileage: 128322 km
Date: 2017.07.13
Time: 16:31:57
End-----(Elapsed Time: 02:35, VBatt start/end: 8.9V/8.9V. VIgn 8.8V)-------
