New Forum Member, MIB II Reftrofit and Mk7 Climatronic into Eos
Blade3562
C?ID=310127
Registered to hopefully help contribute to MIB II Retrofitting into A5 platform cars. I have a 2007 Eos VR6 that currently has an RCD330G+ and have a Scirocco facelift steering wheel and climatronic on the way. My friend works at a VW shop and has VCDS HEX+CAN that I currently use as I need it. I'll be purchasing my own unit here soon enough, just have other expenses at the moment!
I'd like to figure out more about the possible MFD integration and a few more kinks I haven't worked out yet. (Like the fact I can still connect to bluetooth long after the car is off and locked, but I have no battery drain?)
Anything I can do to contribute I gladly will!
I'm also working on trying to figure out which Mk7 style climatronic panel I need for my car. The Eos is a weird step-child in the VW famliy. I'm not sure if I need Auto-recirc or if I need a non auto-recirc. I'd prefer the non auto-recirc as I like the look of the buttons much more! I'll grab the auto-scan from my laptop once I get back from Carlilse Import.
Blade3562
C?ID=310127
Uwe, which version do I need of the Hex-Net? Pro or Enthusiast? I'll need unlimited vehicle use as we have 5 HEX or CAN cars right now as a family lol. I plan to add a couple more so I'm assuming Pro? My friend has the old HEX-CAN USB which can do unlimited VINs, but they are NLA. Ready to order today as I have a battery drain issue I need to track down. 90% sure it's the head unit and can gateway. Car has been parked for 2 weeks. Excited to play with the mobile version too.
Blade3562
C?ID=310127
Bought a 3 vin Hex-net to get me by for now! Got the battery drain sorted, now to solve steering wheel controls and MFD functionality with the RCD330G+ anything I can provide to help? The unit shows up in VCDS, but in long coding all the checkboxes are blank and most don't seem to make any noticeable changes lol.
I've also discovered a "immobilizer" fault code from long before I bought the car. I'm at work and don't have the auto-scan with me, but will post when I get home!
Westbury, UK
Without the full Auto-Scan it's going to be guesswork, so please post it ASAP.
Blade3562
C?ID=310127
Here ya go, I know about the TPMS, if there is a smarter way to turn off the notifications let me know. None of the sensors worked. :banghead: Probably dead batteries, but the wheels on it now are from my Mk7 which do not have direct tpms. From my understanding the TPMS not being coded is what causes the gateway error. My prior scan before disabling TPMS did not have a gateway error.
Thursday,08,June,2017,18:30:12:26249
VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4341.4
VIN: WVWDB71F57V027859   License Plate:
Mileage: 69034mi   Repair Order:
Chassis Type: 1F (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 47 4F 52 55 56 62
          63 65 72 73 76
VIN: WVWDB71F57V027859   Mileage: 111100km-69034miles
63-Entry Assist,D -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0011
73-Entry Assist, P -- Status: OK 0000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CF    HW: 022 906 032 GP
   Component: MOTRONIC ME7.1.1G   9378
   Revision: --H02---    Serial number: VWX7Z0FN3NH8ER
   Coding: 0000078
   Shop #: WSC 08056 444 100801
   VCID: 51FC7D44DDEF521FF27-8004
Readiness: 0110 1101
   Part No SW: 02E 300 043 T    HW: 02E 927 770 AE
   Component: GSG DSG         070 1302
   Revision: 04507000    Serial number: 00000611040688
   Shop #: WSC 44551 111 44551
   VCID: 2514F994F9E76EBF7EF-8070
   Revision: 00H11001
   Coding: 0021218
   Shop #: WSC 00020 000 00000
   VCID: 73B0D7CC07B3400F20B-8026
   Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: 2B000FAC9F0358CFA8B-807E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006255744
   Coding: E7048E0340041500000000000F00000000084C03640001
   VCID: 6C82CCB05A8D9FF7E11-8038
   Component: Wischer 161106 020  0501
   Coding: 00038805
   Shop #: WSC 00020
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     131106 020  0105
   Coding: 00208933
   Shop #: WSC 00020
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 14 Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3003TWA5
   Coding: 0012596
   Shop #: WSC 05095 444 173882
   VCID: 3A2E3AE86059F14723D-806E
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3Q3NM
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB40432C496 ÿ†63
   Subsystem 5 - Serial number: 2C496 ÿ†6342SRB404344D9B4ÿ†63
   Subsystem 6 - Serial number: 44D9B4ÿ†6372URB401D2147C1ÿ†63
   Subsystem 7 - Serial number: 2147C1ÿ†6382URB401D21479%ÿ
   Subsystem 8 - Serial number: 21479%ÿ
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012121
   VCID: 015C8D044D0F629F227-8054
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Revision: V0003000    Serial number: VWX7Z0FN3NH8ER
   Coding: 0021207
   Shop #: WSC 00000 000 12345
   VCID: 323E12C8B8290907EBD-8066
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 160512F1003716
   Coding: 005000
   Shop #: WSC 00079 790 12345
   VCID: 3D2431F47D77C67F06F-8068
            000 -  -
                    Mileage: 111109 km
                    Time: 18:08:34
   Component: IMMO            VDD 1610
   Shop #: WSC 08091 444 72965
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 34307 km
                    Time: 21:45:28
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
   Component: Verdecksteuergeraet 0622
   Revision: 0032000K    Serial number: 062930480
   Coding: 0655362
   VCID: 372823DC534BEC2FDC3-8062
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         004 1209
   Coding: 0001207
   VCID: 36362ED854411527C75-8062
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.071 H07 1806
   VCID: 343214D0423D0737F91-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0218
   Coding: 1B908A800186083F2804040FC0080E0488DC00
   VCID: 04528410521D77B7091-8050
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1Q0 035 456 B    HW: 1Q0 035 456 B
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000004337
   Component: EZE_2         H40 1623
   Coding: 00000000
   VCID: 6FB8DBBC679B64EFC43-803A
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0001206
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2519043
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0002
   Coding: 00000038
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000038
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4R6221314
   Coding: 16000400040005
   Shop #: WSC 00078 790 00208
   VCID: 46D65E1828A185A7575-8012
                    Reset counter: 92
                    Mileage: 111109 km
                    Time: 18:10:36
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 92
                    Mileage: 111109 km
                    Time: 18:10:36
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         004 1202
   Coding: 0000128
   Shop #: WSC 00020 000 1012544
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Coding: 0000002
   Component:    RDK              0440
   Coding: 0100101
                    Fault Status: 01110100
                    Reset counter: 92
                    Mileage: 111109 km
                    Time: 18:08:32
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
   VCID: 353429D449471E3FCEF-8060
Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
   Component: J573  EASYENTRY BFS 0603
   Coding: 0000002
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1Q0 919 283
   Component: 32 Einparkhilfe     0702
   VCID: 72BED2C878A949072BD-8026
End----------(Elapsed Time: 01:24, VBatt start/end: 13.0V/12.9V)-----------
