Hex V2 does not register +
Modelyear 2017
Will try the scan now...
EDIT: 'No Response from Controller!'
:banghead:
Can you test your interface on some other car please? I understand it is midnight in Belgium now, so that might not be possible today.
In the meanwhile, please try some other addresses, like 01-Engine, or other common ones, like 03-ABS or 08-HVAC just to see if anything talks at all?
You do have the ignition on, right? I can tell you did earlier when you made the screen shots, but just double-checking now..
hex.v2.belgium
Belgium
C?ID=293974
VIN: WVWZZZ3CZHE0*****
Did a scan with the motor running, same result: 'No Response from Controller!'
Don't have another VW/Audi directly at hand. Perhaps this weekend I could try to find someone, but not on short term...
hex.v2.belgium
Belgium
C?ID=293974
I did a scan also on 01-Engine, 03-ABS and 08-HVAC
Same result: 'No Response from Controller!'
And yes, ignition is on, even tried with the motor running...
hex.v2.belgium
Belgium
C?ID=293974
PS. I do have such a low cost OBD2 Mini ELM327 Bluetooth adapter and that one is able to get data from my car with eg. Torque
   #25
You have another e-mail.
Have you tried generic OBD-II in VCDS?
hex.v2.belgium
Belgium
C?ID=293974
Hi Uwe,
the feature code you provided made the Gateway accessible, and I was able to do an autoscan, but have some errors...
(See mail you received yesterday + autoscan data in this post)
(The speakers of my car did 'crack' a bit during the autoscan, don't know if this is normal behavior, but wanted to mention.)
Did not try the generic OBD-II in VCDS, as I even don't know how to enable this.
Questions:
1. I assume it is now safe to use the adapter and do some adaptations, or do you first still want to do some further investigations?
2. The malfunctions in my autoscan are due to the Hex V2 / VCDS not being fully compatible yet with my car or real faults?
Regards,
Nick
Thursday,12,January,2017,07:48:29:43967
VCDS Version: 17.1.0.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170106 DS267.0
VIN: WVWZZZ3CZHE0******   License Plate:
Mileage: 4264km-2649mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 6C
          6D A5 BB BC CA
VIN: WVWZZZ3CZHE0*****   Mileage: 4264km-2649miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 1990
   Revision: B5H23---
   Coding: 011D003203641D083000
   Shop #: WSC 05311 115 00302
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026ET_002.rod
   VCID: 005A8A810A89B8F72FF-8054
   Part No SW: 0D9 300 042 M    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5013
   Revision: 06454104    Serial number: TFK01609151507
   Shop #: WSC 05311 115 00073
   ROD: EV_TCMDQ250021.rod
   VCID: 2310E50DBB5F43EF12D-8076
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62726000002035
   Coding: 0FEC6A8F34280B734777060641CA49F0562CD0E2608292713862F0F8C20202
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
   VCID: 7BA0FD6D636FDB2F7AD-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0419208479
   Coding: 0F2020070F
   VCID: 3C223E7126E11C17337-8068
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8061479
14222592 - Databus
                    Reset counter: 119
                    Mileage: 3293 km
                    Date: 2016.12.29
                    Time: 14:00:12
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 12020124202410011115500E0010182A
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 76B6EC59584D8647053-8022
   Air quality sensor:
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Reset counter: 128
                    Mileage: 3430 km
                    Date: 2017.01.01
                    Time: 01:22:48
                    Voltage terminal 30: 14.4 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 2
                    Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 8658300916000O
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015C8F850183B1FF201-8054
   Component: WWS    160908  042 0607
   Serial number:         160919141844
   Component: RLHS  042 0105
   Serial number: S6Y16M10D06H13M04S28
   Coding: 00A8EE
   Serial number: 30 06 2016  10000744
589592 - Databus
          U1201 00 [008] - No Communications
                    Fault Frequency: 6
                    Reset counter: 124
                    Mileage: 2085 km
                    Date: 2016.12.11
                    Time: 12:46:37
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616266
   Coding: 0271161851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D44A3B54DDBE59F549-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C359FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 343216510EB1D457FB7-8060
1538 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 3869 km
                    Date: 2017.01.07
                    Time: 16:46:39
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 13.0 V
                    Velocity_vehicle_reference: 23.48 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
1542 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 3869 km
                    Date: 2017.01.07
                    Time: 16:46:40
                    Velocity_vehicle_reference: 23.28 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
   Serial number: 20091641350260
   ROD: EV_DRCONTITEMIC.rod
   VCID: 382A226112D93037D7F-806C
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPKQNTV%
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F58097D7777C70F565-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 709 16
   Serial number: 3576U000000ABC3DDD1+
   Subsystem 2 - Part No SW: -----------    HW: 454 001 709 16
   Serial number: 3586U00000048A884D1M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 409 16
   Serial number: 3516R7606DD0C000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 801 409 16
   Serial number: 3526R2D03DD0C000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 609 16
   Serial number: 3556V11FABD0C000000R
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF034034    Serial number: 20161002500321
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA2FE716661DC17737-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 143
                    Mileage: 7 km
                    Date: 2016.11.10
                    Time: 15:55:58
                    Ubat 30 Voltage: 12.10 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 251
                    Slope: 134
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    Tsoll Wert 0: 39.00 °C
                    Tsoll Wert 1: 43.00 °C
                    Tsoll Wert 2: 47.00 °C
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 07A409183F84000801886B011001000000000000
   VCID: 280AF221C279A0B747F-807C
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 30091610521617
   Coding: 030300045F087300FB00025A9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   Serial number: 29160001867260056381
   Coding: 2FFFFF
   Serial number: 75410803001610011156
   Analog clock:
   Serial number: 16000232837009
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDF453123A17FD01-8024
   Serial number: 300916EIT32753
   Coding: 003F1B20D000020000001000
   VCID: 43D0458D5B1F63EF72D-8016
   Coding: 8307
   Shop #: WSC 00015 115 00302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2E38692CD5222721B-806E
   Serial number: 140916EID33177
   Coding: 003F1120DE00020000001000
   VCID: 42DE408944056AE779B-8016
   Component: AFS-ECU       H01 0120
   Coding: 039203004F210200
   Shop #: WSC 05311 000 08193
   VCID: 3FD8497D37F7070F165-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 042     HW: 3G0 035 042
   Component: MU-H-LN-EU    H51 0814
   Serial number: A749J0GB003186
   Coding: 02840201FF00000051110001000808101F0100E4012000009E
   VCID: 58EA82E1B299D03737F-800C
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL04BPP
   Subsystem 2 - Part No SW: V03 959 800 QQ    HW: -----------
   Component: ECE 2017  --- 0157
   Component: Gracenote2---  --- 1013
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
   VCID: 77A8E15D5F47FF4F1E5-8022
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0260
   Revision: --------    Serial number: 30936315800000
   Coding: 0228
   ASAM Dataset: EV_DeckLidCONTIAU736 001013
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 05101611K10580
   Coding: 000408020000040100262344C050A10010000E300040
   ROD: EV_MFKBoschMQBB.rod
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 031016EJ205557
   Coding: 000E11200100020000001000
   VCID: 45D45B95552B5DDF5C9-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 031016EJ14280B
Address CA: Sunroof (J245)       Labels: None
   Component: SAD_STG_1     013 0005
   Coding: 008040748202
   ROD: EV_SunRoofCONTIAU736_005.rod
   VCID: 3D2433753DFB151F049-8068
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
There's an [OBD-II] button on the very first screen. But it doesn't matter now since you've got access to the car for real.
Questions:
I think so. This was a licensing issue of some sort. Should have no effect on functionality now that it's sorted. I apologize for the inconvenience.
The fact that there are some fault codes stored in your car is corroborated by the gateway's Installation List at the top of the scan. In other words, the Gateway is aware of these faults.
The only one that really bothers me is the Temperature Sensor for Heated Steering Wheel. Any problems with the steering wheel heat?
hex.v2.belgium
Belgium
C?ID=293974
Hi Uwe,
good to hear my interface should be fully functional right now, so will start to look into some adaptations later tonight.
(So the cracks I hear from my speakers is considered normal?)
For the Heated Steering Wheel, do not seems to have any problems?
How should I read this fault, it has occurred 254 times and the first/last time at 7km?
Reset counter: 143
Mileage: 7 km
Date: 2016.11.10
Time: 15:55:58
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 251
Slope: 134
kp: 13
OUT: 50
   #29
When exactly do they occur? If it's while VCDS is accessing the infotainment modules, I wouldn't let it bother me.
First time at 7 km, 245 times since then. 245 may be as high as that counter goes.
I'm a bit torn on this fault code. If it was my car, I would probably clear it and see if/when it comes back. If it keeps coming back, I would complain at next service visit to dealer that that the heated steering sometimes doesn't work (even if you don't really have any problems with it). That should get them to do a scan and find the fault code for themselves, and then address the cause. It's generally better to complain about a functional problem and let them find the fault code than it is to complain about fault codes that you found that don't cause a functional problem.
hex.v2.belgium
Belgium
C?ID=293974
Thanks Uwe,
everything seems to work now, so will start a new post in 'Tweaks' for the adaptations I'm doing on the Passat B8.
Will indeed talk to the dealer the next time I'm there for service, counter is now already at 256, so seems a recurring fault.
Steering heater does work, so I'm not bothered for now...
Thanks for the assistance, much appreciated.
One happy customer here!
