- Mar 10, 2020
- 18
- 16
- Netherlands
- C?ID=376974
Hi guys,
I've noticed how the heated seats in my Audi C6.5 are feeble at best. Via my VCDS I'm able to read all the values and in Module 8, measuring blocks 27 and 28 it gives me the information on the seats. In my car it's possible to set it to 6 levels, most of which are apparently far below body temperature
Only settings 5 and 6 seems vaguely useful, where setting 6 sets the seats to 38 degrees (celcius, to be clear, that's only just above body temperature), and setting 5 sets them to 33 degrees, already below. I'm sorry, but how is that heated? It's more like lukewarm
Apparently this is simply the way they're programmed. If I briefly turn down the seats to let's say setting 3 (programmed to 17 degrees ), and then turn it back up to 6 it feels hotter for a bit, although it doesn't really ever display more than 39 degrees on VCDS.
So the question is simple: is it possible to adjust the target temperatures for these settings? I'd really be looking for something 10 degrees higher at least, I can always turn it down if it's too hot. But six settings, of which 5 are pointless... I don't get that. I know that in the pre-facelift models the heated seats were much better, but in mine they're very disappointing. I haven't been able to find anything simply browsing around...
Thanks in advance!
Edit: added the auto-scan
Thanks in advance!
Mittwoch,11,März,2020,08:30:28:24747
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: AIB 18.9.1.0 HEX-V2 CB: 0.4508.4
Datenstand: 20190215 DS296.0
www.vcds.de
Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201 KFZ-Kennzeichen:
Fahrzeugtyp: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 13 15 16 17 19 34 42 46 47 4F 52 53 55
56 5F 62 69 72 76
Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201 Kilometerstand: 269670km
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
0E-Media Player 1 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
34-Niveauregelung -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: Fehler 0010
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
76-Einparkhilfe -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAHB) Labeldatei:* Keine
Teilenummer SW: 03L 906 019 M HW: 03L 906 022 FG
Bauteil: R4 2,0L EDC X03 6417
Revision: 11X03--- Seriennummer:
Codierung: 010D002C02072220
Betriebsnr.: WSC 92521 052 00000
ASAM Datensatz: EV_ECM20TDI03L906019M A01003
ROD: EV_ECM20TDI03L906019AF.rod
VCID: 3536DAF225C77C1F7DB-8060
1 Fehler gefunden:
4799 - Luftmassenmesser (G70)
P0102 00 [032] - Signal zu klein
Sporadisch - unbestätigt - geprüft seit letzter Löschung
Adresse 02: Getriebe Labeldatei: DRV\01J-927-156.lbl
Teilenummer SW: 4F9 910 155 D HW: 01J 927 156 JG
Bauteil: V30 0AN 2.0l CR RdW 0020
Revision: --H06--- Seriennummer: 00000000000474
Codierung: 0000001
Betriebsnr.: WSC 02325 785 00200
VCID: 2C00FF96FA0D3DD7125-8078
Adresse 03: Bremsenelektronik Labeldatei: DRV\4F0-910-517.lbl
Teilenummer SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Bauteil: ESP8 front H03 0060
Revision: 00000000 Seriennummer: 00000000000000
Codierung: 0000380
VCID: 6D8632920197F4DF45B-8038
Adresse 05: Zugangs-/Startber. Labeldatei:. 4F0-910-852.clb
Teilenummer SW: 4F0 910 852 B HW: 4F0 905 852 D
Bauteil: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Seriennummer: 10602601543296
Codierung: 0000131
Betriebsnr.: WSC 02323 785 00200
VCID: 25160AB299E70C9FCDB-8070
Subsystem 1 - Teilenummer: 4F0 910 132 E
Bauteil: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Teilenummer: 4F0 910 220 D
Bauteil: FBSAUDIC6 IDG H01 0054
Adresse 08: Klima-/Heizungsel. Labeldatei: 4F0-910-043.clb
Teilenummer SW: 4F0 910 043 B HW: 4F1 820 043 AL
Bauteil: KLIMABETAETIGUNGH30 0080
Revision: 00000076 Seriennummer: 00000000691520
Codierung: 0000276
VCID: 1D662252B1B7C45F95B-8048
Adresse 09: Zentralelektrik Labeldatei: DRV\4F0-910-279.lbl
Teilenummer SW: 4F0 910 279 N HW: 4F0 907 279
Bauteil: ILM Fahrer H22 0320
Revision: 00000000 Seriennummer: 4F0907279
Codierung: 0003122
Betriebsnr.: WSC 02335 785 00200
VCID: 3430E7F6223D65174A5-8060
Subsystem 1 - Teilenummer: 4F1 910 113 D Labeldatei: DRV\1KX-955-119.CLB
Bauteil: Wischer AudiC6 H10 0040
Codierung: 00056595
Subsystem 2 - Teilenummer: 8K0 910 557 Labeldatei: DRV\8K0-955-559.CLB
Bauteil: REGENLICHTSENSORH04 0003
Codierung: 00211757
Adresse 0E: Media Player 1 (R41) Labeldatei: DRV\4E0-910-111.lbl
Teilenummer SW: 4F0 035 110 A HW: 4F0 035 110
Bauteil: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 15763A7245879C1F5DB-8040
Adresse 13: Distanzregelung Labeldatei: DRV\4F0-910-561.clb
Teilenummer SW: 4F0 910 561 C HW: 4F0 907 561 B
Bauteil: ABSTANDSREGELUNGH02 0020
Revision: -------- Seriennummer: 00000000000000
Codierung: 0061161
Betriebsnr.: WSC 00046 000 00000
VCID: 231214AA97D3F2AFA3F-8076
Adresse 15: Airbag (J234) Labeldatei:| DRV\4F0-910-655-10.clb
Teilenummer SW: 4F0 910 655 Q HW: 4F0 959 655 G
Bauteil: Airbag AU1042 H07 0200
Revision: -------- Seriennummer: 003F9002LUTN
Codierung: 30314236303630303031554A304C34463053
ASAM Datensatz: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
Seriennummer: 3574SRB40000AE19112+
Seriennummer: 3584SRB40000AE404979
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 3516HRB4035COCQ723PL
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 3526HRB402HCTBFR4J95
Seriennummer: 3554NRB40000572DFEEN
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 3564NRB4000056A3529.
Adresse 16: Lenkradelektronik Labeldatei: DRV\4F0-910-549.lbl
Teilenummer SW: 4F0 910 549 A HW: 4F0 953 549 D
Bauteil: J0527 0530
Revision: 00H05000 Seriennummer: 90026100700040
Codierung: 0002052
VCID: 270A00BAE3EB1E8FFF7-8072
Subsystem 1 - Teilenummer: XXXXXXXXXXX
Bauteil: E0221 H02 0100
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:. DRV\4F0-920-xxx-17.clb
Teilenummer SW: 4F0 920 934 A HW: 4F0 920 934 A
Bauteil: KOMBIINSTR. H08 0147
Revision: 00300000 Seriennummer: DH622CA3A
Codierung: 0F5F11050601000C010100
Betriebsnr.: WSC 02391 823 56573
VCID: 26140DBEE8E10787C41-8072
Adresse 19: Diagnoseinterface (J533) Labeldatei:. 4F0-907-468.clb
Teilenummer SW: 4F0 907 468 N HW: 4F0 907 468 G
Bauteil: GW-BEM 5CAN-M H06 0035
Revision: MB200030 Seriennummer: 3000M103098034
Codierung: 000B03
VCID: 3A2CC9CE0C599367909-806E
Subsystem 1 - Teilenummer SW: 8K0 915 181 C HW: 8K0 915 181 C
Bauteil: J367-BDM H07 0125
Seriennummer: 00000000002790145919
Adresse 34: Niveauregelung Labeldatei: DRV\4F0-910-553.clb
Teilenummer SW: 4F0 910 553 C HW: 4F0 907 553 A
Bauteil: J197 LUFTFEDER H17 0030
Seriennummer: 00871001568800
Codierung: 0000120
Betriebsnr.: WSC 02895 202 82454
VCID: 241017B692DDF597DA5-8070
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:. 4F0-959-793.clb
Teilenummer SW: 4F0 959 793 R HW: 8K0 959 793 D
Bauteil: TSG FA H11 0250
Revision: Seriennummer: 0000103197575
Codierung: 011C02205440410001
VCID: 46D4AD3E48A1E787E41-8012
Adresse 46: Komfortsystem Labeldatei:. 4F0-910-289.lbl
Teilenummer SW: 4F0 910 289 N HW: 4F0 907 289 N
Bauteil: Komfortgeraet H29 0250
Revision: 02500029 Seriennummer: 01283689760000
Codierung: 2237169
VCID: 3536DAF229477C1F7DB-8060
Subsystem 1 - Teilenummer: 1K0 951 605 C
Bauteil: LIN BACKUP HORN H05 1501
Subsystem 2 - Teilenummer: 4F0 910 177
Bauteil: Innenraumueberw.H01 0020
3 Fehlercodes gefunden:
00317 - Steuergerät für Heckklappe (J605)
004 - kein Signal/Kommunikation
Umgebungsbedingungen:
Fehlerstatus: 01100100
Fehlerpriorität: 5
Fehlerhäufigkeit: 254
Verlernzähler: 27
Kilometerstand: 264740 km
Zeitangabe: 0
Datum: 2019.10.24
Zeit: 11:28:40
01697 - Fußraumleuchte hinten rechts (W46)
011 - Unterbrechung
Fehlerstatus: 01101011
Fehlerpriorität: 3
Verlernzähler: 24
Kilometerstand: 262108 km
Zeitangabe: 0
Datum: 2019.08.19
Zeit: 17:15:29
01696 - Fußraumleuchte hinten links (W45)
011 - Unterbrechung
Fehlerpriorität: 3
Verlernzähler: 24
Kilometerstand: 262510 km
Zeitangabe: 0
Datum: 2019.08.25
Zeit: 17:30:39
Adresse 47: Soundsystem (J525) Labeldatei:. DRV\4F0-035-223-BO.clb
Teilenummer SW: 4F0 035 223 P HW: 4F0 035 223 P
Bauteil: BOSE G3 C6 H01 0100
Revision: AG001300 Seriennummer: 00000000117348
Codierung: 0D010000
Betriebsnr.: WSC 09581 002 1048576
VCID: 290E0682F9FF28FFE93-807C
Adresse 4F: Zentralelektrik II Labeldatei: DRV\4F0-910-280.lbl
Teilenummer SW: 4F0 910 280 HW: 4F0 907 280 A
Bauteil: ILM Beifahrer H13 0100
Revision: Seriennummer: 00000000697775
Codierung: 0001104
VCID: 5EE4655EFC319F47CC1-800A
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:. 4F0-959-792.clb
Teilenummer SW: 4F0 959 792 R HW: 8K0 959 792 D
Bauteil: TSG BF H11 0250
Revision: Seriennummer: 0000103221619
Codierung: 011C02205C40410001
VCID: 45D6AA3275A7EC9FEDB-8010
Adresse 53: Feststellbremse Labeldatei: DRV\4F0-910-801.clb
Teilenummer SW: 4F0 910 801 D HW: 4F0 907 801 B
Bauteil: EPB CEFC0090 H05 0090
Revision: --H05---
Codierung: 0000131
Betriebsnr.: WSC 02145 785 00200
VCID: 211E1EA28DCFE0BFB13-8074
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\8P0-907-357.lbl
Teilenummer: 8P0 907 357 H
Bauteil: Dynamische LWR H02 0010
Revision: 00000001 Seriennummer:
Codierung: 0000004
VCID: 3FDAB8DA1B7BB64FA77-806A
Adresse 56: Radio (R) Labeldatei:. DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4F0 035 053 K HW: 4F0 035 053
Bauteil: Radio U Basic H45 0074
Revision: AB001007 Seriennummer: 341C-0A7718746
Codierung: 010003010000000000
VCID: 25160AB295E70C9FCDB-8070
1 Fehler gefunden:
02984 - Verbindung zwischen Impedanzwandler 2 und Scheibenantenne
011 - Unterbrechung
Fehlerpriorität: 5
Fehlerhäufigkeit: 44
Verlernzähler: 174
Kilometerstand: 259845 km
Zeitangabe: 0
Datum: 2019.06.06
Zeit: 20:59:50
Spannung: 14.10 V
Adresse 5F: Informationselek. I (J794) Labeldatei:. DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 4E0 035 666 K HW: 4E0 035 666 C
Bauteil: H-BN-EU H47 0187
Revision: -------- Seriennummer: 454CV0A7544370
Codierung: 010100010002DBFD01000F15EF6300030001
VCID: 2E04F59EC0114FC73C1-807A
Subsystem 1 - Teilenummer: 8R0 060 884 FC
Bauteil: EUR 2018 2601
Subsystem 2 - Teilenummer SW: 4F0 919 604 HW: 4F0 919 604
Bauteil: DU7 High H43 0306
Seriennummer: 9356CP0A1223960
Subsystem 3 - Teilenummer SW: 4F0 910 609 E HW: 4F1 919 611 S
Bauteil: Bedienteil MM H01 0060
Seriennummer: 00000001540309
Subsystem 4 - Teilenummer: 8R0 906 961 A
Bauteil: CD-Database 1293
Adresse 62: Türelektr. hi. li. (J388) Labeldatei:. 4F0-959-795.clb
Teilenummer SW: 4F0 959 795 N HW: 8K0 959 795 C
Bauteil: TSG HL H10 0251
Revision: Seriennummer: 0000010191910
Codierung: 010800204040220001
VCID: 44D0B7367E9DD597FA5-8010
Adresse 69: Anhänger Labeldatei:. DRV\4F0-907-383.clb
Teilenummer SW: 4F0 907 383 D HW: 4F0 907 383 D
Bauteil: J345 Towbar module 0040
Revision: 00H06000 Seriennummer: 4F0907383D
Codierung: 0065536
Adresse 72: Türelektr. hi. re. (J389) Labeldatei:. 4F0-959-795.clb
Bauteil: TSG HR H10 0251
Revision: Seriennummer: 0000010193759
Adresse 76: Einparkhilfe Labeldatei: DRV\4Fx-910-283.lbl
Teilenummer SW: 4L0 910 283 B HW: 4L0 919 283 B
Bauteil: Parkhilfe 4-Kan H02 0500
Revision: 00H02000 Seriennummer: 12331007702218
Codierung: 0211016
VCID: 290E0682F5FF28FFE93-807C
Ende--------(Dauer: 01:59, Batt.-Spannung Start/Ende: 14.3V/14.4V)---------
