I have recently had a factory trailer hitch installed on a 2013 Touareg, and would like to know how to change the coding to put power on pin 4 to charge trailer batteries, and also how do I disable the rear hatch from opening when trailer is plugged in to the Touareg?
Full scan below...
Full scan below...
VCDS Version: Release 12.12.2
Data version: 20140212
Saturday,19,April,2014,10:03:19:16316
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGEF9BP1DD010341
Address 01: Engine (J623-CGRA) Labels: None
Part No SW: 03H 906 023 BC HW: 03H 907 309 E
Component: 3,6 FSI ULEV H16 3947
Revision: M7H16---
Coding: 002A0012433600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023BC 002002
ROD: EV_ECM36FSI01103H906023BC.rod
VCID: 64CDA3D16F64033E1FF-8031
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 BC HW: 0C8 927 750 BC
Component: AL1000 AISIN 001 2264
Coding: 001368
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031.rod
VCID: 6ED9C1F9B1A8B96E79B-803B
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 434620010EC815
Coding: 5B7613C349252553DAF7C89792D3A4407300
ROD: EV_ESPMK25A00800.rod
VCID: 4A916D69ED80B54E053-801F
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H33 0433
Coding: 09860010000000000000
VCID: 74EDD391D78493BE8FF-8021
Subsystem 1 - Part No SW: 7P6 959 754 AD HW: 7P6 959 754 AD
Component: FBSTOUAREGIDG H04 0051
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: 4606200A80
VCID: 7EF9F1B9E1C8C9EEE9B-802B
U1101 00 [008] - Active
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001487897
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 6CDDCBF18FB44B7E57F-8039
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-
119.CLB
Component: WWS 121113 031 0021
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-
955-559.CLB
Component: RLFS H10 0020
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag02F H05 0025
Revision: -------- Serial number: 003L00061D45
Coding: 000000000000000000000000000000003246
ROD: EV_AirbaVW10BPAVW526_VW52.rod
VCID: 41834A45D0B67616D49-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1262909XDD
Serial number: 3575LRB40124UNBC817A
Crash sensor for side airbag; passenger side:
Serial number: 3585LRB401A4UNBC60T
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB40064UPDMPGLU
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB40064UPDMO24%
Serial number: 3555NRB400E4UPTEDQ4R
Crash sensor for front airbag; passenger side:
Serial number: 3565NRB400A4UPTEG1DB
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Revision: -------- Serial number: 90815LKU0001N
Coding: 000015
VCID: 366929998178C1AE71B-8063
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 981 E HW: 7P6 920 981 E
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658171112592024
Coding: 8B7732022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 3F874CBDA64200E6A2D-806A
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: -------- Serial number: 00000000778896
Coding: 0021035600
ROD: EV_GatewUDS_VW52.rod
VCID: 3B7F38ADB25A1CC68E5-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000004190824160
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000046595309
Coding: 0058130000004001000001010101202020202121202020
VCID: 346D13919704D3BE4FF-8061
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000132615965
Coding: 011D07205E00453005080000
VCID: 448D4351C7A4633EFFF-8011
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0188228077
Coding: 0186123A28B9509480B00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000132695352
VCID: 3B7F38ADBA5A1CC68E5-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C12B0800034
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 366929998978C1AE71B-8063
Slave 3:
Address 55: Xenon Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: FCFD7BB177D45BFE47F-80A9
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156LB0C7649466
Coding: 020007020100000001
VCID: 2143EAC538F65616B49-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 C HW: 7P6 035 664
Component: H-BN-NA H45 0544
Revision: -------- Serial number: 445L30C7542439
Coding: 010200050040E1EE41022B0C00000003F0000101
VCID: 387527A18B6C37DE637-806D
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000132904445
Coding: 011C07200000253005080000
VCID: 3A713DA9B56025CE953-806F
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 20000000006509
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H11 0110
Revision: 5A001001 Serial number: 00000188830750
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial number: 525 PA8J2X1316
Coding: 0110001
VCID: 3777249D467238A66AD-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 310200626
Coding: 0533314003
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000132904371
