2013 Touareg trailer hitch install, coding
veedabowlu
C?ID=56963
I have recently had a factory trailer hitch installed on a 2013 Touareg, and would like to know how to change the coding to put power on pin 4 to charge trailer batteries, and also how do I disable the rear hatch from opening when trailer is plugged in to the Touareg?
Full scan below...
VCDS Version: Release 12.12.2
Data version: 20140212
Saturday,19,April,2014,10:03:19:16316
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEF9BP1DD010341
Address 01: Engine (J623-CGRA)       Labels: None
   Part No SW: 03H 906 023 BC    HW: 03H 907 309 E
   Component: 3,6 FSI ULEV  H16 3947
   Revision: M7H16---
   Coding: 002A0012433600000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023BC 002002
   ROD: EV_ECM36FSI01103H906023BC.rod
   VCID: 64CDA3D16F64033E1FF-8031
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 BC    HW: 0C8 927 750 BC
   Component: AL1000 AISIN  001 2264
   Coding: 001368
   ASAM Dataset: EV_TCMAL991031 002114
   ROD: EV_TCMAL991031.rod
   VCID: 6ED9C1F9B1A8B96E79B-803B
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 434620010EC815
   Coding: 5B7613C349252553DAF7C89792D3A4407300
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4A916D69ED80B54E053-801F
   Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
   Component: BCM2 2.0      H33 0433
   Coding: 09860010000000000000
   VCID: 74EDD391D78493BE8FF-8021
   Subsystem 1 - Part No SW: 7P6 959 754 AD    HW: 7P6 959 754 AD
   Component: FBSTOUAREGIDG  H04 0051
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: 4606200A80
   VCID: 7EF9F1B9E1C8C9EEE9B-802B
          U1101 00 [008] - Active
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001487897
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6CDDCBF18FB44B7E57F-8039
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-
119.CLB
   Component: WWS    121113  031 0021
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-
955-559.CLB
   Component: RLFS  H10 0020
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag02F H05 0025
   Revision: --------    Serial number: 003L00061D45
   Coding: 000000000000000000000000000000003246
   ROD: EV_AirbaVW10BPAVW526_VW52.rod
   VCID: 41834A45D0B67616D49-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1262909XDD
   Serial number: 3575LRB40124UNBC817A
   Serial number: 3585LRB401A4UNBC60T
   Serial number: 3515RRB40064UPDMPGLU
   Serial number: 3525RRB40064UPDMO24%
   Serial number: 3555NRB400E4UPTEDQ4R
   Crash sensor for front airbag; passenger side:
   Serial number: 3565NRB400A4UPTEG1DB
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815LKU0001N
   Coding: 000015
   VCID: 366929998178C1AE71B-8063
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 981 E    HW: 7P6 920 981 E
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658171112592024
   Coding: 8B7732022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3F874CBDA64200E6A2D-806A
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000778896
   Coding: 0021035600
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B7F38ADB25A1CC68E5-806E
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000004190824160
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000046595309
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 346D13919704D3BE4FF-8061
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000132615965
   Coding: 011D07205E00453005080000
   VCID: 448D4351C7A4633EFFF-8011
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0188228077
   Coding: 0186123A28B9509480B00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000132695352
   VCID: 3B7F38ADBA5A1CC68E5-806E
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C12B0800034
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 366929998978C1AE71B-8063
   Slave 3:
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: FCFD7BB177D45BFE47F-80A9
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Coding: 130000
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156LB0C7649466
   Coding: 020007020100000001
   VCID: 2143EAC538F65616B49-8074
   Part No SW: 7P6 035 664 C    HW: 7P6 035 664
   Component: H-BN-NA       H45 0544
   Revision: --------    Serial number: 445L30C7542439
   Coding: 010200050040E1EE41022B0C00000003F0000101
   VCID: 387527A18B6C37DE637-806D
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000132904445
   Coding: 011C07200000253005080000
   VCID: 3A713DA9B56025CE953-806F
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 20000000006509
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00000188830750
   Coding: 020D000000000000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H06000    Serial number: 525 PA8J2X1316
   Coding: 0110001
   VCID: 3777249D467238A66AD-8062
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 310200626
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000132904371
I received your PM but I do not have any personal experience with that retrofit. I suspect those are configured online at the VW dealer using SVM (Software Version Management). If this was a retrofit kit please post the part number so we can see if installation or configuration instructions are available.
The best place to get help from the greatest variety of different people would be in our Retrofits sub-forum but you aren't a verified user at this time. Please post the short serial number from the part the plugs into the car so the guys can switch you to a VCDS Verified user.
-Dana
Ref: C?ID=56963
veedabowlu
C?ID=56963
On my Hex=CAN 429122?
It is factory installed and I have seen its possible to change the coding on the slightly earlier Touareg to change the coding to put power on pin 4 to charge trailer batteries, and also how do I disable the rear hatch from opening when trailer is plugged in to the Touareg?
I believe they were changing the coding from a 1 to a two.
Thanks Robert. We found that file, tweaked your forum account to Verified VCDS user and moved this thread to the Retrofits section yesterday.
Was this a retrofit kit from the VW dealer or did you purchase the parts individually? Any additional information you can provide would be helpful so we can see if VW installation or configuration instructions are available.
veedabowlu
C?ID=56963
100% factory install...
veedabowlu
C?ID=56963
Bump, any update for this?
OK, per the VIN PR Code 1D6 Trailer hitch is listed so it should have been properly configured from the factory. If you believe it is not when compared to other VW Touareg models I would send this vehicle to the VW dealer so they can dig into that.
I do not know if the power supply you are after is possible and the 6D: Trunk Elect. controller is coded for Trailer Hitch Installed so I do not have an explanation for the hatch operation. If you don't receive any other replies here you may want to post in one of the Touareg specific forums to see if they have solutions to either one of these concerns.
Zenerdiode
Newcastle, England
C?ID=24330
What type of trailer socket was installed? If it was the Euro 13 pin style (ISO11446) then pin 4 is not used for charging the trailer battery - it's the right turn signal indicator...
The charging function is on pin 10+ and pin 11- and even for factory installations, you 'enable' it with a small wiring harness that has a relay driven from terminal 15 (ignition switched live).
You may have 12N/12S sockets and you refer to pin 4 on 12S? Again, you need to add the harness.
andreizx12
Romania
C?ID=168333
In 08 HVAC you must go to long coding and select the trailer hitch byte .
