Sorry for not following protocol.
The car is 75 miles away and I'm leaving for FL in the morning so I can't get a scan until I get back.
2.0t bpg engine with 224,000 miles, in which I've put on 100,000 of. Bone stock with all GAP with the exception of motor mount and front suspension kit from Dolphi. M1 0-40 every 5-7k with audi filter. I went 10k between on accident about 15k miles ago and vacuum pump and oil filter housing gaskets started leaking, or perhaps coincidence. I replaced said gaskets, cleaned the valves, replaced IM gasket and TB gasket too. I have no record of the TC or tensioner being serviced.
100ish miles ago the ticking got louder so I changed oil but this time I used the best Fram filter walmart had due to the dealer closed on weekends. Seemed to have made it a little quieter. I did notice some metal shavings on filter which I've never noticed before.
Drove the car to work on monday and when I pulled up to work I noticed the ticking got much worse. My LUNCH I headed 1 MILE away to get food. Upon acceleration I noticed a slight hesitation and then the motor shut down as if I turn the key - no pops, clicks or snaps.
Towed the car to my parents house and started dissecting the motor. Once I got the timing cover off, the tensioner guide was in two pieces and chain obviously snapped. The guide was clearly warn down so far the chain had been riding on the metal shaft.
I should have trusted my gut and changed them both out last summer but was told "that's normal. Get used to it cause 2.0t's all do that" by a indi euro mechanic. Also seem to get that same response from most people on various vag forums.
Please let me know if I'm leaving any info out that might be pertinent.
Thanks in advance!!
