MK7 GTI EPC Light After CAN Gateway Replacement (AFS Lighting Retrofit)
George Ab
C?ID=232965
Performing Retrofit of Halogen to Xenon with full Adaptive Front Lighting System (AFS). Had to change CAN Gateway 5Q0907530S to 5Q0907530AC as original CAN Gateway does not have an extended BUS (pins 7 and 17 missing) which is used to provide data to AFS Module. Recoded new module with old code and changed all adaptive channels that were different. Went to dealer to have component protection removed. After which, AFS works like a charm, but get EPC (Engine Power Control) light and cruise control does not work (lights up in yellow with explanation mark behind). No failure of CAN Gateway, just the 1 engine failure 17169 Check Coding of ECU on Powertrain Data Bus. When I put old CAN Gateway back in, Engine Failure goes away, but obviously no AFS.
I have checked and re-checked adaptive channels for differences and do not see any. I did note that IDE04330-Transfer of release code for a SWaP function is 00 00 in old module and 368 sets of 00 in new module. When I attempt to change new module to just two sets of 00, VAGCOM prompts as must be 368 sets of Hex characters. In VAGCOM Basic Setting you can perform certain function of SWaP, provided a screen shot.
Also new module does not have adaptive channel IDE10735-Number requests autonomous recharging. However, that is unlikely related.
Any ideas on how to resolve? Any ideas on what SWaP is and if it could affect?
17169 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
Mileage: 50079 km
Date: 2017.03.07
Time: 22:28:08
Coolant temperature: 59 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.597 V
ACC variants (coding): CCS
CCS Switch: CCS Switch
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Main switch CAN: not activated
ACC variants: ACC
Engine: operating status: ES
PetrolDave
Westbury, UK
C?ID=1423
SWaP = SoftWare as a Product i.e. an additional software feature that must be paid for.
DV52
C?ID=194404
George: What a very interesting problem - thank you for posting!
You say that after installing the new CAN Gateway, you replicated the code-string and All the adaptation channels (except for the SWAP facility, which I suspect is a distraction to your problem). But in addition to doing this, did you tell the new CAN Gateway that you have wired the AFS modules and that you wanted this function activated? The reason why I ask is because when I look at the long coding helper screens for the CAN Gateway on my mk7 (which has the lower-order module) many of the Bit explanation dialogues are missing, so much of the module's capabilities (in terms of software switches are unknown with VCDS).
However, as we know, all (nearly all?) of the code-string Bits will have a purpose - it's just that for some reason VCDS doesn't identify many of these purposes! I've always found this aspect of VCDS odd because, the explanation for these Bits appears to be resident inside the module in some form - it just isn't extracted onto the Long Coding helper screens for some reason.
In terms of the AFS function - I can find no software switches for this activity using VCDS on any of the Bits on the CAN Gateway module on my mk7 (which admittedly is the lower order module), but many of the explanations on the Bits on my module are vacant.
However, when I search the same CAN Gateway module with "another" diagnostic device, I do indeed find reference to a software switch (a Bit) in the CAN Gateway that does enable AFS. I hope that Uwe forgives my posting a screen shot from the "other" device as an illustration of my point:
The problem with the "other" device is that whilst the software switch can be enabled/disabled, the screen doesn't tell the user which Byte/Bit each function relates-to. So alas I'm not able to tell which box to tick on the VCDS long coding helper screen. Did you enable a bit on your new module to enable AFS?
Anyhow, I thought this might be related to your problem - but I'm just guessing
What makes you think that, Don?
Dana
Western PA, USA
I think that example photo is perfectly fine Don. We might be able to locate something similar in a coding chart based on the order alone.
George, Can you post some additional data?
The original / factory condition VCDS Auto-Scan
Adaptation function Control module map from the original 19 module (if it isn't a hassle to reconnect)
The current Auto-Scan
Adaptation function Control module map from the new 19 module
That info may reveal the conflict but I don't want to get your hopes up.
DV52
C?ID=194404
Uwe: OOps... I suspect that by asking the question, you are telling me that I'm in error (again) ... Apology - my bad, but I deliberately used the word "appears to be resident inside the module in some form" because I was uncertain where this quite valuable information comes from in the "other" decvice.
DV52
C?ID=194404
Dana: Galvanized into action by your post, I fired-up my test bench to further investigate my hypothesis (and as I said, it's just a guess).
Anyhow, the AFS switch in my picture was disabled as a default setting, so I noted the code string for the CAN Gateway in this state. I then enabled the AFS switch and re-noted the new code string for the changed state. It appears that the change happens on Byte 11, Bit 1. Is there any way that you can confirm my findings?
EDIT: Ooops........... here's details of the said CAN Gateway for the test:
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000073193
   Coding: 0000003828086400EF0006481C0F00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 3326DAA49A74C0DA71-8066
End----------(Elapsed Time: 00:26, VBatt start/end: 12.6V/12.6V)-----------
Dana
Western PA, USA
Hi Don,
I'm off tomorrow so I may not be able to do so immediately but that before/after info should be helpful. I suspect the OP will be back with the scans and maps soon but .. if you guys don't hear back from me please bump this back up.
George Ab
C?ID=232965
First, thanks all for taking the time and interest to think on this issue.
Yes Don, I did introduce the AFS module to the CAN Gateway.
Good thoughts on your comment on coding and AFS got me thinking, so I did a comparison of coding other CAN Gateway Modules of GTI’s in our library of reference scans. Byte 11 of my originally non-LP and one other non-LP example have 28 and other LP variants have 2A or 2B. There is no explanation of byte 11. I am considering changing that byte and seeing if that reestablishes communication with power train bus and ECU (fault goes away).
My Gateway did not come with LP from factory:
Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
This is coding of a 2017 GTI without LP. Byte 11 is also 28.
Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
2015 GTI 6MT w/LP
Coding: 0101000820085900EF00002A080F00000001000000000000000000000000
2017 GTI Sport w/LP
Coding: 0101000830085900FB00002B1C0F00000001050000000000000000000000
2017 GTI w/LP
Coding: 0101000830085900FB00002B080F00000001050000000000000000000000
Dana, no problem; appreciate your time and the brain trust taking interest.
Original Auto Scan
Monday,08,December,2014,15:58:42:51554
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 3VW4T7AUXFM024280   License Plate: ASJ1448
Mileage: 3012km-1871mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
VIN: 3VW4T7AUXFM024280   Mileage: 3012km-1871miles
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A_VW37.rod
   VCID: 2C79F7E347C25541E33-8079
Readiness: 1110 1101
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4511
   Revision: 05852204    Serial number: TFK01406072403
   ROD: EV_TCMDQ250021_SE37.rod
   VCID: 29770EF748304069185-807C
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51864000001328
   Coding: 01FA6BA1342209700079020881C32980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP.rod
   VCID: 44A9BF43CF52BD010B3-8011
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 102
                    Mileage: 2642 km
                    Date: 2014.12.03
                    Time: 00:13:56
                    Reset counter: 102
                    Mileage: 2642 km
                    Date: 2014.12.03
                    Time: 00:14:06
   Revision: 00021000    Serial number: 0338563827
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A55C1BBBD96FBF161F-806F
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SE37.rod
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580608141223
   Coding: 001118464041826969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00180
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 46ADA54BF96E8F11157-8013
   Subsystem 1 - Part No SW: 5GM 955 119     HW: 5GM 955 119
   Component: WWS    140714  043 0581
   Serial number:         140807083646
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H11M13S13
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2853977F
   Coding: 181801
6663 - Bulb for Low Beam Headlamp Left
          B1217 11 [009] - Short to Ground
                    Reset counter: 72
                    Mileage: 2642 km
                    Date: 2014.12.03
                    Time: 14:50:23
7175 - Bulb for High Beam Headlamp Left
          B1219 11 [009] - Short to Ground
                    Reset counter: 72
                    Mileage: 3009 km
                    Date: 2014.12.06
                    Time: 18:18:23
6919 - Bulb for Low Beam Headlamp Right
          B1218 11 [008] - Short to Ground
                    Reset counter: 103
                    Mileage: 2642 km
                    Date: 2014.12.03
                    Time: 13:23:05
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 62
                    Mileage: 2642 km
                    Date: 2014.12.03
                    Time: 00:14:00
329480 - Unknown Error Code
          B1806 F0 [008] - Unknown Error Elaboration
                    Fault Frequency: 10
                    Reset counter: 107
                    Mileage: 16 km
                    Date: 2014.09.30
                    Time: 08:45:52
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00NWPF
   VCID: 51878617002058A9B05-8004
   Seat occupant detection; front passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001138R0O
   Coding: 303331
   Subsystem 2 - Part No SW: -----------    HW: 480 002 406 14
   Serial number: 35700000000DD550101A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 14
   Serial number: 3580000000035228301/
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 14
   Serial number: 3510002C916DB80392A9
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 14
   Serial number: 35200029916DB80590EB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3550002991617D20A1F3
   Subsystem 7 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3560002B11617D21A22U
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140616400091
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04297F438FD27D014B3-8051
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD091A2180CF0502086A001000000000000000
   VCID: 6BFB34FF824C9279AA9-803E
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2186
   Revision: --------    Serial number: 25071410001840
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti.rod
   VCID: 41A7B657D040A829205-8014
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27140001281020044216
   Coding: 29FFFF
   Revision: 00000000    Serial number: 14000160490002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449EF839FF20D81BB3-8061
   Serial number: 050814060506W6
   Coding: 003E13200000040000000000
   VCID: 40A1B353DB4AA1212FB-8015
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000002981047
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_SE37.rod
   VCID: 354FD287948814898CD-8060
   Serial number: 05081406050BS9
   VCID: 3FA3B0AFA6B4DED9561-806A
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000003143183
   Coding: 191000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00407142061
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 64E95FC36F92DD01EB3-8031
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500EN6
0023 - Tuner for Satelite Radio
          B11CF 96 [008] - Component internal failure
                    Reset counter: 109
                    Mileage: 2816 km
                    Date: 2014.12.06
                    Time: 09:33:20
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2823A017F1E06000000
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 0225795B95C6733179F-8057
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 72
                    Mileage: 1048574 km
                    Time: 00:00:00
   Component: SAS-GEN 2     H06 0013
   Serial number: 140521200176
End-------------------------(Elapsed Time: 03:26)--------------------------
Monday,08,December,2014,16:09:51:51554
UDS Adaptation Channel: Volume of structure-borne noise actuator
Stored value 0.0 %
Adaptation function of Original 5Q0-907-530-S (19) Module
;SW:5Q0-907-530-S   HW:5Q0-907-530-L ---  CAN Gateway
;Component:GW MQB Mid    211 2186	 Coding:0101000820085900EF0000281C0F00000001050000000000000000000000
;EV_GatewConti	11017	EV_GatewConti_011.rod
;Tuesday	28	February	2017	12:57:44:51554
;VCDS Version: Release 17.1.3 (x64)  Data version: 20170220 DS267.3
;VCID: 41A7B657D040A849A6-8014
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys	Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation	Deactivating
IDE00002-Transport mode	not active
IDE00820-Activating and deactivating all development messages	not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation	12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering	12.1 V
IDE01211-Static current measuring mode	not activated
IDE01457-Energy management deactivation stage	Mode not active
IDE01459-Energy management heat output control status	Mode not active
IDE01844-Increase idle speed request	Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time	--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation	Mode not active
IDE01860-Generator specified voltage value variable	10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1	coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module	coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1	coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side	Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning	coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics	coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater	Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1	Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control	Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics	Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag	coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics	coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board	coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater	Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway	1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection	Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance	Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control	Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost	Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control	Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking	coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2	Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics	Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side	Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant	Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function	Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor	Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side	coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance	coded
IDE01996-SFT00071-Installation list: specified installations-Sound System	Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module	Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side	coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation	coded
IDE01996-SFT00086-Installation list: specified installations-Radio	Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner	Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1	coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph	Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1	Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function	Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View	Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit	Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance	Not coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1	Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display	Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module	Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System	Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit	Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound	coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface	coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side	Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side	Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management	Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left	Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right	Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise	Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management	Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module	Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof	Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2	Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01	Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02	Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03	Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04	Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05	Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06	Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07	Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08	Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09	Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D	Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11	Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16	Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17	Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A	Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D	Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F	Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20	Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21	Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22	Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24	Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25	Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26	Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27	Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28	Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29	Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A	Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E	Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F	Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35	Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36	Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37	Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38	Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39	Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A	Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C	Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D	Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40	Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41	Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43	Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45	Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48	Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49	Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51	Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52	Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53	Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55	Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56	Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58	Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59	Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A	Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B	Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C	Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D	Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E	Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F	Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60	Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61	Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62	Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66	Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68	Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B	Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C	Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E	Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74	Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75	Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78	Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79	Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A	Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D	Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E	Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F	Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80	Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81	Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82	Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83	Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85	Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86	Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87	Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88	Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89	Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B	Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C	Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D	Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E	Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F	Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90	Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91	Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92	Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93	Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94	Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95	Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96	Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97	Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98	Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99	Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A	Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B	Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C	Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D	Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E	Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F	Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0	Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1	Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2	Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3	Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5	Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6	Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7	Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8	Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA	Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB	Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC	Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD	Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF	Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0	Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1	Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2	Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3	Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4	Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5	Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6	Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7	Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8	Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9	Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA	Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB	Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC	Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD	Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE	Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF	Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0	Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1	Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2	Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3	Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4	Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5	Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6	Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7	Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8	Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9	Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA	Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB	Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC	Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD	Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE	Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF	Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0	Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1	Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2	Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3	Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4	Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5	Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6	Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7	Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8	Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9	Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA	Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB	Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC	Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD	Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE	Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF	Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0	Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1	Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2	Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3	Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4	Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5	Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6	Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7	Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8	Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9	Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA	Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB	Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC	Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED	Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE	Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF	Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0	Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1	Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2	Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3	Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4	Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5	Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6	Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7	Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8	Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9	Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA	Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB	Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC	Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD	Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE	Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF	Not coded
IDE02200-Component protection showroom mode	not active
IDE02332-Deactivate production mode	0
IDE03256-MAS06105-Battery adaptation-Rated battery capacity	51 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology	Wet
IDE03256-MAS06107-Battery adaptation-Battery manufacturer	JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number	1.11E+09
IDE03903-Production process data 1	00 00
IDE04159-Deactivation of start-stop function	Mode not active
IDE04186-Battery terminal recognition	connected
IDE04330-Transfer of release code for a SWaP function	0
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages	not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states	no error
IDE06530-Distance left for deactivation of static current measuring mode	2
IDE06541-Distance left for deactivation of transport mode	50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof	activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM	activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start	activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)	activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system	activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system	activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof	not activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D	not activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill	activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)	activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill	activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C	activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater	activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater	activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater	activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation	activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater	activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light	activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light	not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission	activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater	activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater	activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater	activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater	activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation	activated
IDE07838-Counter for inconsistent states	0
IDE08348-Start/stop start voltage limit	7.6 V
IDE08624-MKE Check box	activated
IDE10735-Number requests autonomous recharging	9
IDE10736-Cyclization limitation request battery service	0
IDE10748-MAS11262-Range gain-Range gain AC system	activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater	activated
IDE10748-MAS11264-Range gain-Range gain window defogger	activated
IDE10748-MAS11265-Range gain-Range gain seat heater front	activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation	activated
IDE10748-MAS11267-Range gain-Range gain rear heater	activated
IDE10748-MAS11268-Range gain-Range gain fog light	activated
IDE10748-MAS11269-Range gain-Range gain rear fog light	activated
IDE10748-MAS11270-Range gain-Range gain windshield heating	activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater	activated
IDE10748-MAS11272-Range gain-Range gain mirror heater	activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater	activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater	activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system	not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system	activated
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption	not activated
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain	activated
IDE10748-MAS11279-Range gain-List at engine still stand	not activated
IDE10748-MAS12689-Range gain-Catalogue range display	activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display	activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung	activated
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence	100%
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold	100
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In	0 ms
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start	0 ms
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out	0 ms
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start	0 ms
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay	0 ms
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence	0 ms
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness	active
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency	active
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol	active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset	active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation	100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation	60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation	10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption	0 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption	0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation	180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation	1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation	800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption	1000 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen	Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level	Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen	Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen	Mode not active
ENG05989-EM_nominal_voltage_limitation_low_beams	12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement	0 s
ENG05991-EM_requirement_reduction_air_blowers	Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature	-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature	-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1	Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module	Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1	not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side	Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning	Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics	Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1	Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control	Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics	Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag	not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics	Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board	Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater	Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway	Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection	Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance	Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control	Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost	Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control	Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking	Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2	Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics	Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side	Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant	Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function	Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor	Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side	Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance	Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System	Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module	Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side	Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation	Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio	Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner	Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1	Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph	Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1	Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function	Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View	Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit	Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit	Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance	Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module	Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System	Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit	Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound	Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface	Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side	Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side	Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management	Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left	Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right	Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise	Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management	Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module	Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof	Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2	Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00	Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01	Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02	Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03	Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04	Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05	Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06	Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07	Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08	Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09	Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D	Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11	Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16	Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17	Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A	Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B	Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D	Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F	Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20	Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21	Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22	Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24	Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25	Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26	Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27	Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28	Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29	Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A	Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E	Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F	Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35	Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36	Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37	Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38	Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39	Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A	Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C	Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D	Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40	Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41	Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43	Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45	Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48	Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49	Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51	Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52	Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53	Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55	Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56	Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58	Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59	Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A	Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B	Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C	Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D	Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E	Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F	Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60	Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61	Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62	Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66	Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68	Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B	Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C	Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E	Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74	Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75	Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78	Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79	Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A	Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D	Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E	Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F	Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80	Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81	Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82	Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83	Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85	Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86	Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87	Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88	Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89	Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B	Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C	Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D	Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E	Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F	Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90	Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91	Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92	Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93	Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94	Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95	Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96	Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97	Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98	Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99	Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A	Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B	Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C	Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D	Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E	Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F	Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0	Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1	Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2	Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3	Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4	Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5	Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6	Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7	Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8	Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9	Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA	Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB	Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC	Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD	Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE	Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF	Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0	Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1	Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2	Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3	Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4	Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5	Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6	Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7	Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8	Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9	Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA	Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB	Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC	Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD	Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE	Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF	Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0	Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1	Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2	Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3	Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4	Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5	Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6	Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7	Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8	Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9	Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA	Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB	Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC	Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD	Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE	Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF	Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0	Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1	Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2	Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3	Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4	Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5	Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6	Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7	Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8	Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9	Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA	Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB	Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC	Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD	Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE	Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF	Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0	Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1	Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2	Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3	Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4	Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5	Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6	Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7	Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8	Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9	Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA	Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB	Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC	Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED	Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE	Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF	Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0	Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1	Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2	Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3	Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4	Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5	Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6	Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7	Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8	Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9	Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA	Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB	Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC	Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD	Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE	Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF	Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus	Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ	not active
ENG05993-GW_routing_0	00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1	00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2	00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3	00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4	00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5	00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6	00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7	00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8	00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9	00 00 00 00 00 00 00 00 00 00 00 00
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1	active
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2	not active
ENG118779-ENG118723-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW	GRA-High
ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor	not installed
ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic	installed
ENG118774-WakeUpMonitor_Activation	activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events	100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events	14 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay	0 s
Elapsed Time: 00:30
Current Auto Scan
Thursday,09,March,2017,23:40:59:51554
VCDS Version: 17.1.3.0 (x64)
VIN: 3VW4T7AUXFM024280   License Plate:
Mileage: 50259km-31229mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VW4T7AUXFM024280   Mileage: 50259km-31229miles
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 13327 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79F7E347C2552165-8078
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 50259 km
                    Date: 2017.03.09
                    Time: 23:32:04
                    Coolant temperature: 56 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 12.226 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS Switch
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ACC variants: ACC
                    Engine: operating status: ES
Readiness: 1110 1101
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4511
   Revision: 05852204    Serial number: TFK01406072403
   Coding: 0018
   Shop #: WSC 00066 790 00149
   ROD: EV_TCMDQ250021.rod
   VCID: 29770EF7483040099E-807C
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51864000001328
   Coding: 01FA6BA1342209700079020881C32980D62C9000408194B400430050C006
   Shop #: WSC 01383 790 50316
   VCID: 44A9BF43CF52BD618D-8010
   Revision: 00021000    Serial number: 0338563827
   Coding: 030C0C
   VCID: 3A55C1BBBD96FB91E7-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SK48.rod
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580608141223
   Coding: 00111A464041A26969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00180
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 46ADA54BF96E8F7193-8012
   Component: WWS    140714  043 0581
   Serial number:         140807083646
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H11M13S13
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2853977F
   Coding: 181801
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00NWPF
   VCID: 51878617002058C936-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001138R0O
   Coding: 303331
   Subsystem 2 - Part No SW: -----------    HW: 480 002 406 14
   Serial number: 35700000000DD550101A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 14
   Serial number: 3580000000035228301/
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 14
   Serial number: 3510002C916DB80392A9
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 14
   Serial number: 35200029916DB80590EB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3550002991617D20A1F3
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3560002B11617D21A22U
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140616400091
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04297F438FD27D61CD-8050
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD091A2980CF0502086A001000000000000000
   Shop #: WSC 23304 444 12345
   VCID: 6BFB34FF824C92192C-803E
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003204912
   Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
   Shop #: WSC 00049 770 00102
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72C5299BA56643D1EF-8026
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27140001281020044216
   Coding: 29FFFF
   Revision: 00000000    Serial number: 14000160490002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449EF839FF20DE13D-8060
   Serial number: 050814060506W6
   Coding: 003E13200000040000000000
   VCID: 40A1B353DB4AA141A9-8014
   Serial number: 00000000000002981047
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 354FD287948814E90A-8060
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401B7W8
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001006
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63EB5CDF6A9CDA5994-8036
   Serial number: 05081406050BS9
   Coding: 003E13200C00040000000000
   VCID: 3FA3B0AFA6B4DEB9D0-806A
   Serial number: 00000000000003143183
   Coding: 191000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 021A01000B000400
   Shop #: WSC 01608 666 28888
   VCID: 3D5FCAA7ACB8CCA9C2-8068
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00407142061
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64E95FC36F92DD616D-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500EN6
          B11CF 53 [009] - Deactivated
                    Reset counter: 119
                    Mileage: 50259 km
                    Date: 2017.03.09
                    Time: 23:35:29
                    Voltage terminal 30: 12.2 V
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2823A017F1E06000000
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 0225795B95C67351FF-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 119
                    Mileage: 1048574 km
                    Time: 00:00:00
   Component: SAS-GEN 2     H06 0013
   Serial number: 140521200176
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
End-------------------------(Elapsed Time: 03:27)--------------------------
Adaptation function of New 5Q0-907-530-AC (19) Module
Elapsed Time: 00:28
;SW:5Q0-907-530-AC   HW:5Q0-907-530-F ---  CAN Gateway
;Component:GW MQB High   128 1204	 Coding:0101000820085900EF0000281C0F00000001050000000000000000000000
;EV_GatewLear	11020	EV_GatewLear_011.rod
;Wednesday	8	March	2017	00:35:27:51554
;VCDS Version: Release 17.1.3 (x64)  Data version: 20170220 DS267.3
;VCID: 72C5299BA56643D1EF-8026
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys	Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation	Deactivating
IDE00002-Transport mode	not active
IDE00820-Activating and deactivating all development messages	not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation	12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering	12.1 V
IDE01211-Static current measuring mode	not activated
IDE01457-Energy management deactivation stage	Mode not active
IDE01459-Energy management heat output control status	Mode not active
IDE01844-Increase idle speed request	Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time	--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation	Mode not active
IDE01860-Generator specified voltage value variable	10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1	coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module	coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1	coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side	Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning	coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics	coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater	Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1	Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control	Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics	Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag	coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics	coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board	coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater	Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway	1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection	Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance	Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control	Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost	Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control	Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking	coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2	Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics	Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side	Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant	Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function	Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor	Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side	coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance	coded
IDE01996-SFT00071-Installation list: specified installations-Sound System	Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module	Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side	coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation	coded
IDE01996-SFT00086-Installation list: specified installations-Radio	Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner	Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1	coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph	Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1	Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function	Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View	Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit	Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance	Not coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1	Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display	Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module	Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System	Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit	Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound	coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface	coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side	Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side	Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management	Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left	Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right	Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise	Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management	Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module	Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof	Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2	Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01	Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02	Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03	Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04	Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05	Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06	Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07	Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08	Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09	Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D	Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11	Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16	Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17	Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A	Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D	Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F	Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20	Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21	Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22	Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24	Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25	Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26	Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27	Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28	Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29	Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A	Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E	Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F	Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35	Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36	Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37	Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38	Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39	Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A	Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C	Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D	Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40	Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41	Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43	Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45	Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48	Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49	Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51	Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52	Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53	Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55	Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56	Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58	Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59	Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A	Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B	Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C	Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D	Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E	Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F	Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60	Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61	Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62	Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66	Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68	Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B	Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C	Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E	Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74	Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75	Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78	Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79	Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A	Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D	Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E	Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F	Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80	Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81	Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82	Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83	Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85	Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86	Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87	Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88	Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89	Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B	Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C	Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D	Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E	Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F	Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90	Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91	Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92	Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93	Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94	Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95	Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96	Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97	Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98	Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99	Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A	Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B	Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C	Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D	Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E	Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F	Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0	Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1	Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2	Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3	Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5	Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6	Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7	Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8	Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA	Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB	Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC	Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD	Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF	Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0	Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1	Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2	Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3	Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4	Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5	Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6	Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7	Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8	Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9	Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA	Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB	Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC	Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD	Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE	Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF	Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0	Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1	Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2	Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3	Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4	Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5	Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6	Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7	Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8	Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9	Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA	Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB	Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC	Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD	Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE	Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF	Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0	Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1	Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2	Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3	Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4	Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5	Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6	Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7	Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8	Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9	Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA	Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB	Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC	Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD	Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE	Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF	Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0	Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1	Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2	Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3	Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4	Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5	Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6	Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7	Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8	Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9	Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA	Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB	Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC	Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED	Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE	Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF	Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0	Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1	Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2	Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3	Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4	Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5	Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6	Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7	Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8	Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9	Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA	Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB	Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC	Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD	Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE	Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF	Not coded
IDE02200-Component protection showroom mode	not active
IDE02332-Deactivate production mode	0
IDE03256-MAS06105-Battery adaptation-Rated battery capacity	51 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology	Wet
IDE03256-MAS06107-Battery adaptation-Battery manufacturer	JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number	1111111111
IDE03903-Production process data 1	00 00
IDE04159-Deactivation of start-stop function	Mode not active
IDE04186-Battery terminal recognition	connected
IDE04330-Transfer of release code for a SWaP function	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages	not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states	no error
IDE06530-Distance left for deactivation of static current measuring mode	2
IDE06541-Distance left for deactivation of transport mode	50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof	activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM	activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start	activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)	activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system	activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system	activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof	not activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D	not activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill	activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)	activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill	activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C	activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater	activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater	activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater	activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation	activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater	activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light	activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light	not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission	activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater	activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater	activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater	activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater	activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation	activated
IDE07838-Counter for inconsistent states	0
IDE08348-Start/stop start voltage limit	7.6 V
IDE08624-MKE Check box	activated
IDE10736-Cyclization limitation request battery service	0
IDE10748-MAS11262-Range gain-Range gain AC system	activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater	activated
IDE10748-MAS11264-Range gain-Range gain window defogger	activated
IDE10748-MAS11265-Range gain-Range gain seat heater front	activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation	activated
IDE10748-MAS11267-Range gain-Range gain rear heater	activated
IDE10748-MAS11268-Range gain-Range gain fog light	activated
IDE10748-MAS11269-Range gain-Range gain rear fog light	activated
IDE10748-MAS11270-Range gain-Range gain windshield heating	activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater	activated
IDE10748-MAS11272-Range gain-Range gain mirror heater	activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater	activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater	activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system	not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system	activated
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption	not activated
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain	activated
IDE10748-MAS11279-Range gain-List at engine still stand	not activated
IDE10748-MAS12689-Range gain-Catalogue range display	activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display	activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung	activated
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence	100%
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold	100
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In	0 ms
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start	0 ms
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out	0 ms
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start	0 ms
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay	0 ms
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence	0 ms
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness	active
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency	active
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol	active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset	active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation	100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation	60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation	10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption	0 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption	0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation	180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation	1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation	800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption	1000 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen	Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level	Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen	Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen	Mode not active
ENG05989-EM_nominal_voltage_limitation_low_beams	12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement	0 s
ENG05991-EM_requirement_reduction_air_blowers	Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature	-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature	-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1	Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module	Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1	not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side	Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning	Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics	Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1	Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control	Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics	Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag	not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics	Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board	Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater	Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway	Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection	Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance	Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control	Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost	Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control	Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking	Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2	Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics	Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side	Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant	Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function	Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor	Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side	Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance	Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System	Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module	Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side	Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation	Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio	Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner	Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1	Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph	Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1	Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function	Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View	Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit	Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit	Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance	Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module	Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System	Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit	Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound	Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface	Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side	Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side	Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management	Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left	Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right	Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise	Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management	Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module	Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof	Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2	Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00	Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01	Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02	Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03	Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04	Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05	Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06	Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07	Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08	Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09	Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D	Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11	Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16	Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17	Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A	Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B	Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D	Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F	Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20	Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21	Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22	Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24	Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25	Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26	Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27	Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28	Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29	Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A	Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E	Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F	Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35	Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36	Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37	Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38	Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39	Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A	Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C	Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D	Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40	Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41	Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43	Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45	Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48	Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49	Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51	Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52	Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53	Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55	Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56	Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58	Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59	Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A	Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B	Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C	Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D	Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E	Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F	Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60	Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61	Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62	Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66	Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68	Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B	Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C	Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E	Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74	Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75	Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78	Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79	Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A	Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D	Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E	Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F	Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80	Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81	Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82	Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83	Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85	Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86	Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87	Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88	Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89	Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B	Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C	Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D	Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E	Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F	Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90	Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91	Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92	Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93	Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94	Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95	Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96	Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97	Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98	Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99	Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A	Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B	Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C	Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D	Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E	Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F	Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0	Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1	Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2	Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3	Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4	Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5	Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6	Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7	Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8	Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9	Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA	Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB	Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC	Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD	Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE	Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF	Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0	Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1	Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2	Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3	Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4	Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5	Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6	Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7	Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8	Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9	Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA	Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB	Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC	Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD	Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE	Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF	Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0	Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1	Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2	Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3	Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4	Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5	Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6	Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7	Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8	Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9	Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA	Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB	Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC	Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD	Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE	Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF	Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0	Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1	Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2	Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3	Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4	Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5	Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6	Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7	Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8	Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9	Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA	Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB	Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC	Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD	Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE	Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF	Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0	Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1	Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2	Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3	Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4	Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5	Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6	Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7	Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8	Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9	Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA	Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB	Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC	Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED	Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE	Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF	Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0	Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1	Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2	Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3	Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4	Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5	Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6	Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7	Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8	Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9	Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA	Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB	Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC	Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD	Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE	Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF	Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus	Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ	not active
ENG05993-GW_routing_0	00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1	00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2	00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3	00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4	00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5	00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6	00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7	00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8	00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9	00 00 00 00 00 00 00 00 00 00 00 00
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1	active
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2	not active
ENG118779-ENG118723-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW	GRA-High
ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor	not installed
ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic	installed
ENG118774-WakeUpMonitor_Activation	activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events	100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events	14 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay	0 s
Elapsed Time: 00:32
Also an Autoscan with old CAN Gateway with current configuration. Will get AFS failure as it cannot be reached CAN Gateway does not support Extended CAN Bus. However, Engine fault goes away (no EPC light).
Friday,10,March,2017,00:11:29:51554
VCDS Version: 17.1.3.0 (x64)
VIN: 3VW4T7AUXFM024280   License Plate:
Mileage: 50263km-31231mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VW4T7AUXFM024280   Mileage: 50263km-31231miles
55-Headlight Range -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 13327 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79F7E347C2552165-8078
Readiness: 1110 1101
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4511
   Revision: 05852204    Serial number: TFK01406072403
   Coding: 0018
   Shop #: WSC 00066 790 00149
   ROD: EV_TCMDQ250021.rod
   VCID: 29770EF7483040099E-807C
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51864000001328
   Coding: 01FA6BA1342209700079020881C32980D62C9000408194B400430050C006
   Shop #: WSC 01383 790 50316
   VCID: 44A9BF43CF52BD618D-8010
   Revision: 00021000    Serial number: 0338563827
   Coding: 030C0C
   VCID: 3A55C1BBBD96FB91E7-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SK48.rod
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580608141223
   Coding: 00111A464041A26969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00180
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 46ADA54BF96E8F7193-8012
   Component: WWS    140714  043 0581
   Serial number:         140807083646
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H11M13S13
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2853977F
   Coding: 181801
540693 - Databus
                    Reset counter: 238
                    Mileage: 50263 km
                    Date: 2017.03.10
                    Time: 00:05:04
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00NWPF
   VCID: 51878617002058C936-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001138R0O
   Coding: 303331
   Subsystem 2 - Part No SW: -----------    HW: 480 002 406 14
   Serial number: 35700000000DD550101A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 14
   Serial number: 3580000000035228301/
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 14
   Serial number: 3510002C916DB80392A9
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 14
   Serial number: 35200029916DB80590EB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3550002991617D20A1F3
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3560002B11617D21A22U
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140616400091
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04297F438FD27D61CD-8050
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD091A2980CF0502086A001000000000000000
   Shop #: WSC 23304 444 12345
   VCID: 6BFB34FF824C92192C-803E
16776970 - Databus
                    Reset counter: 238
                    Mileage: 50263 km
                    Date: 2017.03.09
                    Time: 23:55:03
   Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2186
   Revision: --------    Serial number: 25071410001840
   Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_011.rod
   VCID: 41A7B657D040A849A6-8014
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27140001281020044216
   Coding: 29FFFF
131668 - Headlight Range Control Module
          U101E 00 [009] - No Communication
                    Reset counter: 238
                    Mileage: 50263 km
                    Date: 2017.03.10
                    Time: 00:05:47
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 14000160490002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449EF839FF20DE13D-8060
   Serial number: 050814060506W6
   Coding: 003E13200000040000000000
   VCID: 40A1B353DB4AA141A9-8014
   Serial number: 00000000000002981047
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 354FD287948814E90A-8060
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401B7W8
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001006
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63EB5CDF6A9CDA5994-8036
   Serial number: 05081406050BS9
   Coding: 003E13200C00040000000000
   VCID: 3FA3B0AFA6B4DEB9D0-806A
   Serial number: 00000000000003143183
   Coding: 191000
Address 55: Headlight Range
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00407142061
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64E95FC36F92DD616D-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500EN6
          B11CF 53 [009] - Deactivated
                    Reset counter: 119
                    Mileage: 50259 km
                    Date: 2017.03.09
                    Time: 23:35:29
                    Voltage terminal 30: 12.2 V
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2823A017F1E06000000
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 0225795B95C67351FF-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 238
                    Mileage: 1048574 km
                    Time: 00:00:00
   Component: SAS-GEN 2     H06 0013
   Serial number: 140521200176
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
End-------------------------(Elapsed Time: 03:33)--------------------------
DV52
C?ID=194404
George: I've done a side-by-side compare of all the adaptation channels in your two admaps and they confirm that your replication of the old settings are perfect. As you have already said, IDE10735-Number requests autonomous recharging is an unmatched channel in the new CAN Gateway, so not much that you can do about this
My results can be downloaded HERE if you have an interest
George Ab
C?ID=232965
Thanks for the verification of adaptation settings Don. Brilliant on copy and pasting old and new side by side into Excel. That is also how I proceeded when I checked; however, I did now learn how to automate the compare with =Exact(cell,cell); nice…, I’ll keep that in mind for next time.
I went forward and changed byte 11 from 29 to 2A and 2B. Coding was accepted for both attempts; however, no joy with respect to properly communicating with ECU.
I must amuse easily as I was absolutely giddy last evening watching the lights turn back to center coming out of a corner. The cornering lights are also pretty trick. Old module is back in as I would rather have Electronic Power Control and cruise control over lights that turn particular with a long drive coming up. Headed up to Canada for this weekend’s Rugby 7’s Tournament. Out of solidarity, I’ll be pulling for Australia unless their playing Samoa!
DV52
C?ID=194404
George: You are a very good judge of Rugby talent!!! Personally, I'd barrack for the Canadians - because I like their accents!
Please forgive my barracuda-like persistence, but I've gotten an intellectual interest in my hypothesis that just won't let go! So, to further reinforce my contention and in an attempt to convince you of the merits of setting Byte 11, Bit 1 on your new CAN Gateway module, I had a look at the Code-strings on your post to Dana.
Basically, all I have done is to pass the values that you listed through my handy dandy code-string to binary converter (it's just an Excel macro - so real easy to do)
Here's the result:
Now - if you look carefully at the binary columns in my table, you can deduce that the ONLY Bit that is ALWAYS consistent in those modules that have the L/P AND is ALWAYS different in those modules that don't have L/P is fortutiously Byte 11, Bit 1 - QED
So, I believe that I can say with a degree of certainty that whilst this Byte/Bit hasn't solved your particular problem, nevertheless there is a compelling body of evidence (the label in the "other" diagnostic device, the results from my test bench and the logic from my table above) that strongly supports the suggestion that Btye 11, Bit 1 should be set in the new CAN Gateway on your car
The problem with the ECU is clearly another issue - albeit related to the new CAN Gateway module
Phew!!!!!!!!:thanks:
George Ab
C?ID=232965
Thanks for your efforts Don.
Yes, I have changed that bit.
I found two other examples that used same module part number 5Q0 907 530 “AC” with Lighting Package so I am comfortable that the “AC” variant is compatible with my 2015 GTI SE.
On the theory that in order to play well together that the Engine Control Module needs to be properly married up to CAN Gateway, I attempted to remove Engine Control Module and then reinstall using CAN Gateway Installation List check boxes. No change, still have engine communication fault.
With software coding and adaptations being verified and having compatible module variation, I am at an impasse. Although no faults were found with Gateway itself, I am going to go on the theory that I have a CAN Gateway hardware problem with the new module. I am going forward with purchasing a new module. The module expense is minimal; however, I do need a better way to remove component protection. My local VW dealer worked on car for 2.5 hours (charged me for 2) to remove component protection, ouch. The technician mentioned having to remove component protection on all CP modules that talked to CAN Gateway (that have CP). There should be more elegant solution of coding EEPROM of CAN Gateway, but this was likely out of the norm for the tech. Additionally, the tech was trying to figure out the EPC fault that was introduced with new CAN Gateway.
DV52
C?ID=194404
Good luck with that - I would be very interested in any findings!! I've had many discussions with independent workshops here in Australia about CP removal. I have a couple of CP errors on my test bench that I want to remove, but the friendly (not) dealers here refuse because it's not a standard vehicle- so not approved by the VW mother-ship!!
I understand that overseas, it's possible for non VW dealers to attain this capability (with the required certification), but here in Australia, VW has refused to allow independent workshops to access the facility. There is currently a case before our consumer protection authority to redress this anti competitive behavior - but it's not a quick process .
Meanwhile, a service that is touted as being for the benefit of vehicle owners is restricted to just VW dealers and when they refuse to remove CP, there is no alternative!!
PS:Why does it take 2.5 hrs to remove CP? I would have thought that it was a mostly automated process -is the elapsed time because of communications traffic delays to/from FAZIT - in which case charging per hour seems a bit much?
I doubt it actually takes more than a few minutes.
Dana
Western PA, USA
Hi Don,
I'm off tomorrow so I may not be able to do so immediately but that before/after info should be helpful. I suspect the OP will be back with the scans and maps soon but .. if you guys don't hear back from me please bump this back up.
Sorry about the delay guys. Confirmed: 11/1Drive Program Function "AFS" active
FWIW that is the only bit I could locate with AFS in the description so I don't think any other bits apply. I definitely agree with Don here so when the next CAN GW is installed I would turn that on.
Wuxi, P.R.C.
C?ID=265663
After changing GW , you shoud recover the datas , must have odis
George Ab
C?ID=232965
Resolved failure. I purchased a VAS 5054A cable and reached out to a gentlemen from Poland, Jack. PM me if you need his contact information. Jack was able to change parameters of the CAN Gateway remotely to resolve failure. He told me I had purchased the wrong Gateway for my VIN and normally the parametrization would not have to be done. Based on scans I have seen the AC variant used on a 2016 GTI and a Golf 7 that had LP; however, I assume the parameters are mated to their vehicle. All is well that ends well. Thanks for your assistance all.
Alan_Harrington
Ireland
C?ID=268223
Could you pass Jacks contact details to me if possible I would be greatful, I have about 3 cars requiring CP removal on BCM1 & another needs Radio taken out of SAFE Mode, have ordered a VAS 5054 Clone, see Reviews on other Forums about his work
Riddick20
Italy
C?ID=245838
hi my friends!
i have the same problem.
i have a golf 7 gti (my2014) and i changed the bcm and the gateway ... buying it new.
I copied the long coding of the old ones and also all the adaptations, but the error remains of the EPC light on and it comes out even with the scan in the channel 1 of the engine.
I did not understand how I can solve.
I have:
Original VCDS
Original VCP
VAS5054
