ASAM Update Loop
jemichae
Australia
C?ID=298740
I think that I've managed to get past the ROD file update loop (downloading and updating ROD file - rinse and repeat).
Used the standalone config jar, to try the update a few times, and then VCDS Mobile.
But now when attempting and completing a scan (via VCDS Mobile), I get the ASAM update required.
I updated, it seems to download and extract the files.. but per the ROD file update, just keeps telling me that an ASAM update is required.
Log includes:
No ASAM data for: "EV_ACCBOSCHVW416" (AU37)
No ASAM data for: "EV_GatewNF" (AU37)
S3 8V MY17 - Is this problem just due to the support for this car being a work in progress?
Many thanks.
Tuesday,07,February,2017,09:19:52:44359
VCDS Version: 17.1.2.0 (x64)  HEX-NET CB: 0.4334.4
Data version: 20170131 DS267.1
Dealer/Shop Name: JMMI
VIN: WAUZZZ8V2H1038043   License Plate: SEC73Y
Mileage: 1066km-662mi   Repair Order:
Chassis Type: 8V (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 6C A5 A9 BB BC CF
VIN: WAUZZZ8V2H1038043   Mileage: 1066km-662miles
Address 01: Engine (J623-DJHB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A2500322466010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 47DEBAFBFE00B37962-8012
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0GC 300 011     HW: 0DE 927 711 C
   Component: GSG DQ381     H12 0403
   Revision: 00H12V32
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 5F8E429B4690DBB9BA-800A
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 62536000000082
   Coding: 319C938D549C1BB18B910B684194698CC92AD8D1D0829677184150B482A812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 393ACC03B8F4D589E4-806C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0420810731
   Coding: 030C0C
   VCID: 3B36D60BB2C8E799F6-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001073284
   Coding: 03100014110000011000000000001500
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40CCA1E7DB2E8441A3-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 2AD8845800PAG0MUFU03
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Serial number: 02001629300258
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EB01F1FE15A32B191-802A
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160710  043 0585
   Serial number:         160722021752
   Coding: 0A47F7
   Serial number: 62377733
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 06 08 2016  00001312
   Serial number: 000000000ZY1624911C4
   Serial number: 00000000000036721081
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0018UR9300000
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417616286
   Coding: 0370167051
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 4FEE92DB16706B392A-801A
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500E7C319FFC42474988055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: N/A
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       180716006
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_002_AU37.rod
   VCID: 43C6AEEBCA389F59BE-8016
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR296E7O
   Coding: 98CCC000000000005C54000000C800000065
   VCID: 106C51A7CBCE34C173-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 002 810 16
   Serial number: 3570000000029355DE1O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 810 16
   Serial number: 358000000006A355DE1U
   Subsystem 3 - Part No SW: -----------    HW: 480 402 110 16
   Serial number: 3510001C922E94D3B65E
   Subsystem 4 - Part No SW: -----------    HW: 480 402 110 16
   Serial number: 3520001B9229A9E1A608
   Subsystem 5 - Part No SW: -----------    HW: 480 401 810 16
   Serial number: 35500029F22E8E135125
   Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23101604400872
   Coding: E818
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 166027BFE92ADAF129-8042
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H13 0045
   Coding: 248D18527F9800080181E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79BA0C03F8741589A4-802C
   Component: GW MQB High   515 5286
   Serial number: 24101610521248
   Coding: 030100043F085A005B008278BC0B00000001010000000000000000000000
   ROD: N/A
   VCID: 2F2EF25B76B00B394A-807A
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20161019085549 20575
   Serial number: 75410803001610255759
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7755
   Serial number: HA1-00005.10.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 45C2B0F3C40CA16990-8010
   Revision: 00000000    Serial number: 16000178187010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3424FD379F9628E137-8060
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 081016EJ800401
   Coding: 005D1A205C01040000001003
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A38D30FBDF2DE91ED-806E
   Part No SW: 81A 035 466 A    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0420
   Revision: 00000001    Serial number: AUZ8ZAGHX00AQT1
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C8Gen2ALPI.rod
   VCID: 23060E6B2A78BF59DE-8076
   Serial number: 071016EJ71174A
   Coding: 005D12205E01040000001003
   VCID: 42C8ABEFD5229651B5-8016
Address 55: Headlight Range (J745)       Labels: None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EE602202B100200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E30DF1FA1DAF2B1D1-806A
   Part No SW: 8V1 035 041 A    HW: 8V1 035 041
   Component: MU-P-LND-RW   053 0875
   Serial number: A838J0GB003878
   Coding: 017351080000000011511102000A00102F0027E6017001045E
   VCID: 2D12E8537CBC792978-8078
   Subsystem 1 - Part No SW: V03 959 801 FQ    HW: -----------
   Component: ROW 2017  --- 0062
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY2087GM
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL114101600010261
   Component: Gracenote2  --- 4011
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 06101612K20273
   Coding: 040307010000010101022346C048A90080000E200080
   ROD: EV_MFKBoschMQBB.rod
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 160924200755
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 041016EJ31185A
   Coding: 000C12204001040000001002
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 041016EJ311913
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 3620C73F89EA3AF109-8062
End----------(Elapsed Time: 01:49, VBatt start/end: 13.7V/13.7V)-----------
tmoe
C?ID=109772
I was able to get all of the asam updates by attaching the hex-net to my laptop via usb (this powers up the hex-net) put the hex-net into infrastructure mode (network needs access to internet), connect laptop to the same network as hex-net. Then use vcds-mobile options, check for update. For me this downloaded all of the updates I needed. You may need to check multiple times, continue till you get your ip address states that you are up to date. This worked for me.
EV_GatewNF is almost certainly not covered in VCDS-Mobile at the moment. Not sure about EV_ACCBOSCHVW416.
