'17 Jetta LED DRL retrofitting into '15 Jetta SE TDI - coding help
Tech20
C?ID=282246
Hello all,
I'm trying to retrofit headlights for a 2017 Jetta {Halogen with the LED DRL strip}. I have verified that the wiring is the same between my '15 SE TDI, and a '17 SE through erWin. I'm led to believe that it is going to be a coding isue. I have verified that the low beam, high beam, and front turn signal functions with my existing coding. The LED DRL will not turn on, and there is no side marker light as well.
Existing headlight part numbers
HEADLAMP 5C7941005
HEADLAMP 5C7941006
New headlight part numbers
HEADLAMP 5C7941005J
HEADLAMP 5C7941006J
Image of bytes and bits that appear to be related to lighting.
2017%20jetta%20headlight%20retrofit%20into%202015_zpsmpclydbt.jpg.html
Thank you all, for any help possible.
Copy of Auto-Scan
Thursday,12,January,2017,12:32:23:39605
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: 3VW3A7AJ8FM310751   License Plate: GFK8969
Mileage: 15490km-9625mi   Repair Order:
Chassis Type: AJ (6N0)
Scan: 01 03 04 05 08 09 15 17 19 25 2B 2E 44 56 75 77 0B
VIN: 3VW3A7AJ8FM310751   Mileage: 15490km-9625miles
Address 01: Engine (J623-CVCA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 016 AJ    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8418
   Revision: 8AH20---
   Coding: 01190012042410085000
   Shop #: WSC 18309 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016AJ 001009
   ROD: EV_ECM20TDI01104L906016AJ.rod
   VCID: 71C728BFA033AFC930-8024
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Revision: 00H46001
   Coding: A14B400C492300FA851202E9921A0042A1100012
   VCID: 0429716B8781AA61EB-8050
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Revision: 00092000    Serial number: 0356445866
   Coding: 000F0F
   Shop #: WSC 00066 000 00089
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 3753D6A78ED731F93E-8062
   Part No SW: 5C0 820 047 CG    HW: 5C0 820 047 CG
   Component: J301  Klimaanlage   0208
   Revision: 2001001S    Serial number: 00000002583088
   Shop #: WSC 00066 790 00016
   VCID: 67F346E756F761796E-8032
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78003043150436
   Coding: 7A994BBF08AB0B0008382080240884C50F86702E60000050B0A050022844
   Shop #: WSC 00066 123 12345
   VCID: 3041EDBB63B9E6C17F-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Serial number: 14102585141218223616
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Serial number: 14102584150129180306
   Coding: 820000
   Subsystem 3 - Part No: 5K0 959 591 A
   Component: J245 PS41.402  H02 0003
   Serial number: 0000FST0002G6D100000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 0071510421301086AD1B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Serial number: 14102587150105110833
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Serial number: 14202586150113180156
   Coding: 800000
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 1
                    Mileage: 15493 km
                    Date: 2017.01.12
                    Time: 13:10:53
                    Reset counter: 1
                    Mileage: 15493 km
                    Date: 2017.01.10
                    Time: 18:49:48
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD04PGMA
   Coding: 00004B33
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72C527B3A53594D1C9-8026
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150002BVFA0B
   Coding: 303146
   Serial number: 3572MSME5B283C4BZZZ6
   Serial number: 3582MSME66283C4BZZZ3
   Serial number: 3516KSME33316133ZZZC
   Serial number: 3526KSME144F7D33ZZZ/
   Serial number: 3556LSME041C0732ZZZN
   Serial number: 3566LSME36380732ZZZR
   Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
   Component: KOMBI         H04 0807
   Coding: 270A01
   Shop #: WSC 00066 000 00118
   VCID: 2C79F9CB4791822143-8078
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70C12DBBA339A6C13F-8024
            000 -  -  - Intermittent
                    Mileage: 15493 km
                    Date: 2017.01.08
                    Time: 16:52:55
   Component: IMMO          H04 0807
   Coding: 000007
   VCID: 6AF53FD38DE55C1171-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 15000006842005
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041EDBB6BB9E6C17F-8064
Address 2E: Media Player 3
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   VCID: 3957D09F70C32789C8-806C
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
   Component: Radio Prem-8  H08 0009
   Revision: -----13S    Serial number: VWZ4Z7R3668653
   Coding: 01000440020006
   VCID: 2D7FF4CF748B8B2954-8078
                    Reset counter: 144
                    Mileage: 6531 km
                    Date: 2015.12.19
                    Time: 17:24:17
Address 75: Telematics (J949)       Labels: 12E-035-284.clb
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140533
   Coding: 02630102C21632007F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1409412BFFE13AE17B-8040
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670001146
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 3245E7B365B5D4D109-8066
End-------------------------(Elapsed Time: 02:31)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
i'm no expert on the jetta and I don't have the ERWin wiring schemes. I do know a lot about the Polo and that might help.
In the Polo, the LED of the bi-xenon headlight is controlled by PWM. Since I don't have the scheme, I can't compare.
You could try to set byte 21 to HEX 01.
Furthermore you could try to compare byte 18, that holds some lighting functions.
